k24 block
Old Mar 23, 2004
Texas Rice's Avatar
Texas Rice is an unknown quantity at this point
k24 block
I haven't found a clear yes or no on this so, I will post it. I have a k24 CRV block and I want to mate it with a k20a2 head, is that possible or only with the TSX block or are they both pretty much the same? The only difference I noticed with the two engines are the HP, the torque is the same pretty much. The articles on the Skunk2 ep3 do not specify which they use and HAsport's website does not have the k24/k20 mate project car on the site. Also, has anyone documented this swap in detail? I am slowly collecting the parts such as the head, pistons, rods etc. Thank you.
Old Mar 23, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
they should bolt right up, but you are gonna need the ecu for the k20a2 head cause the valve train is totally controlled by the ecu, so in order to get the fullest out of the i-vtec, u need the ecu
Old Mar 23, 2004
xian's Avatar
Honda > Nissan
xian is on a distinguished road
You do realize the engine in the TSX is exactly what you're doing!!!
K24 block + K20 Type S head = TSX = YOU!!!
You're going to love this setup. Please, please, please keep us informed about your progress on this project!
Old Mar 23, 2004
Texas Rice's Avatar
This will not be an over night process by any means hehe. It took me a few months just to get the head, pistons, and rods because cash flow isn’t exactly plentiful right now. Although, I have not seen many members trying to do this swap, overtime I will save up enough money to be a guinea pig for this but by then I am sure the swap will be like tying your shoes.
Old Mar 23, 2004
keepin_it_clean's Avatar
keepin_it_clean is an unknown quantity at this point
You should contact HASPORT by email to see if they have any suggestions for you, they are usually one of the first to begin frankenstein projects bc of their mounts. good luck with it and keep us informed
Old Mar 23, 2004
Jodster's Avatar
Post Whore General
Hasport is working on the mounts for the K24.
"You do realize the engine in the TSX is exactly what you're doing!!!
K24 block + K20 Type S head = TSX = YOU!!!"
Wrong. He said he is using the K24 out of the CRV. Its not the same compression. And the K20A2 head is alittle different than the K24A2 head. Not much, but it is. The K24A1(CRV) motor with the K20A2 head would be the best for boost.
True DOHC IVTEC+9.6:1 Compression+Boost=tons of power and torque.
Old Mar 23, 2004
Hawk's Avatar
You boost, I-VTEC
who needs torque? high end horse power rocks
Old Mar 23, 2004
Jodster's Avatar
Post Whore General
With this setup with just I/H/E it should make about 190whp and 170wtq.
Old Mar 23, 2004
Texas Rice's Avatar
Along the road I would like to boost hense the reason for the CRV block. Although, I still have many, many questions that have not been answered due to the fact that this is a 'breakthrough' swap and still in babyland.
Old Mar 24, 2004
Jodster's Avatar
Post Whore General
Well keep asking questions. Hahaa
Old Mar 24, 2004
Texas Rice's Avatar
Well, I am debating on which chassis to use and which can take some power because If I do go through with boosting this swap it will make a good amount of power. Does anyone have a DC5 chassis? I hear the DC5 chassis has very nice suspension capabilities. Or is the 5-lug conversion worth the time and the money?
Also, If I want my lovely power steering I need to cut some of the underside of my hood. Do I need to take extra precautions with the engine being so close to the hood like insulation or scraping problems?
Would a certain kind of piston head be better than the other because I am mating engines? There prolly isn’t but just to double check before I go spend $900 on pistons and find out this these suck.
What transmissions will fit? Just the RSX 6speed or do I have some other options? If I decide to use the RSX tranny then it would be in my best interest to buy a donor RSX for wiring and the chassis but then again I still need alot from an Si so it be better the mix and match.
I have alot more but I can't think right now. haha thanks for the help guys.
Old Mar 25, 2004
whizkidz's Avatar
whizkidz is an unknown quantity at this point
you can either use a base rsx/ si tranny, as we all would suggest go with a rsx-s tranny im sure you would like 6 speeds rather to the coventional basic 5-speed, and as for the rsx chassis just stick with your current setup our cars have the mcpherson strut system too, esp if your kinda on a budget, 5 lug to me is just a "status" statement, just for "props" and let people drool at. remember guys thats just my opinion
Old Mar 26, 2004
Jodster's Avatar
Post Whore General
They make plenty of suspension setup for our car. No need to do the 5-lug unless you really want it.
You only need to cut away a little bit of the underside of your hood.
This is what Hawk had to do.
What do you mean here? Are ou asking about the head? Or piston? If its the head, the K20A2 head would work great. But remember if you get the K20A2 head you have to get the K20A2 ECU to go with it. If your talking about pistons, the stock K24A1 pistons will be fine. Just remember, even with a 8K redline(using the K20A2 head and ECU), the K24A1 motor drops the power off at 7300RPMs. So there really is not reason to take it to 8K.
You can use either the K20A, K20A2, or K20A3 tranny. It all depends on if you want a 6-speed, LSD, and how much money you want to spend. I've been told if you going to be boosting, than to just use a 5-speed tranny.
I hope I answered some of your questions. Keep asking. Someone here is going to know the answer.
Old Mar 26, 2004
Green Civic's Avatar
It will work. But I believe that the engine will stand a little taller. So you will need to cut a little more than in Hawk's pic.
Old Mar 26, 2004
Jodster's Avatar
Post Whore General
^^^^^^^Hasport is making a mount kit to make the K24 sit just a tab bit lower in the engine bay so you will not have hood issues. Well thats what I heard.
Old Mar 27, 2004
Touge_Motors's Avatar
Touge_Motors is an unknown quantity at this point
if you want a mean all-motor k20/k24 THIS is how it's done...
You get your K24 block and equipe it with:
-2004 S2000 crank (90.7mm stroke)
-Carillo billet rods
-JE High compression pistons
-Sleeved block
You get a K20a2 head and equipe it with:
-Serious cams (BUT KEEP I-VTEC)
-Heavy port polish
-port matching
-oversized valves
-IRL valve spirings
Miscelaneous:
-AIR intake manifold
-Hondata K-pro
-Custom exhaust manifold
With this block (If blue-printed) you will EASILY hit 375+whp with a 10 000+ redline... any questions?
Old Mar 27, 2004
hondaciv01's Avatar
hondaciv01 is an unknown quantity at this point
if you can actually get this swap done it would be sweet. it will be hard though since its new right now. hasport is making mounts for it though, and it is starting to become alittle more widely known.
Old Mar 28, 2004
kelemi821's Avatar
kelemi821 is an unknown quantity at this point
between swapping K20A2, K24 from CRV, and K24 from TSX... which has the most aftermarket support? or are they all about the same? also in your opinion which has the most potential of the three?
Old Mar 30, 2004
Texas Rice's Avatar
My true love is all motor. I have a CRV block atm and k20a2 head. I am putting off buying the real preformance pieces such as cams, pistons etc. and focusing on parts I need for the swap to happen like ECU(not reflashed yet) and axles. I have the same question as kelemi821. Which would be better for all motor 5 or 6 speed? I am thinking for saving up just buying a wrecked SI because I am going to use half the damn thing when I am done.
styles234
21
Nov 19, 2019 07:23 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
emiixo
Exterior
Sep 22, 2015 03:53 AM
MichaelLW
Sep 14, 2015 07:15 AM
MamaBear2015
Sep 7, 2015 06:00 PM
