JDM B16a2 Swap
Old Mar 17, 2004
lqdquik's Avatar
lqdquik is an unknown quantity at this point
Question JDM B16a2 Swap
I am just starting a B16a2 swap today. Does anyone have any advise? Any little bit will help.
Old Mar 17, 2004
Spider883's Avatar
9K Redline Owns U
Yes. Go shoot yourself before I do.
Old Mar 17, 2004
dragoon's Avatar
this'll be interesting
Old Mar 17, 2004
lqdquik's Avatar
Ok not what i was looking for. Let's try some constuctive critism. What other then the wiring it should't be that bad. Hasport is not going to have monuts or harnesses for another couple of months.
Old Mar 17, 2004
Spider883's Avatar
9K Redline Owns U
1. JDM B16A2.. no such thing.. that is USDM
2. Mounts and Wiring.. who is doing it?
3. What year is your "JDM B16A2" engine?
4. You say u are in the middle of the swap and u are also doing the Drag turbo kit but yet you say your future mods one of them is a DC header.. hmm interesting.. i would like to see how that works out.
Someone else take over from here i have a meeting at work so ill be back later
Old Mar 17, 2004
lqdquik's Avatar
B16A2 (1.6 DOHC V-TEC) 170HP
1.6 DOHC 16V VTEC 170HP Honda motor . Direct from Japan. Includes engine, hydraulic transmission and grey plug ECU (For 92-95 Civics & 94-95 Integras) Can also be adapted to older vehicles with transmission and harness adapters.
Specifications:
Transmission: Hydraulic
Year: 92-95
Displacement: 1600cc
Compression Ratio: 10.4:1
HP/Torque: 168hp@7800/116 lb-ft@7300
Redline: 8200 rpm
Swap includes:
Motor
Transmission
Engine Wiring Harness
All required Cables
ECU
Distributor
Complete Intake Manifold
Alternator
A/C
Power Steering Pump
All Brackets and Sensors
Shift linkage
Axles
If I do not have the cash after the swap to do the turbo too, then i am going to get some headers, a lot less expensive.
Don't be jealous cause you are driving the crappy ivtec
And if your asking what year because of the obd yes it is coming with an obd2 and a lsd tranny
Old Mar 17, 2004
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
just so you know you cant swap an older motor into a new car, its illegal in most states, ( the motor has to be the same model year as the car or newer), and uhh, yeah id definitely do a k20 b4 i did a b16, but whatever i dont believe you anyway.
Old Mar 17, 2004
lqdquik's Avatar
What don't you believe?
Old Mar 17, 2004
auto84's Avatar
I R T3H 1338
umm that youd swap an old technology motor and 5 speed into place of a d17 and not just do a k20, and in general that you are dumb enough to swap an older motor into a 2001-2004 car.
Old Mar 17, 2004
lqdquik's Avatar
Cause all I hear is bad stuff from the i vtec
I didn't have 5,000 to by a k20
and i didn't want the weight of a k24, that thing would be a nose heavy pig, old technology it is the same engine that every single person with their 2000 civic si has. The d17 was a weak engine and it would cost more to have that thing built up polished, sleeved and then turbo to it's 8 maybe 9 psi, then it is to put an already stronger motor in with less miles then i have on my d17.
Old Mar 17, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
i dont care what you do
i just want to see the finished project
sugguestions..
have a beater car to get you back and fourth to autopart store and possibly work
good luck
Old Mar 17, 2004
auto84's Avatar
I R T3H 1338
whatever, prove it.
Old Mar 17, 2004
lqdquik's Avatar
speedracer32 when it is done i will send you the pictures and the dyno sheet to prove it and you can tell these other ignorant people all about it.
Old Mar 17, 2004
HondaWhore's Avatar
HondaWhore is an unknown quantity at this point
Good luck, dont really think you can put a B16 in a 7th gen. But what do I know. By the way a K20 will blow away a B16 mod for mod. And what bad things are there about a K20. So let me get this straight, you have no harnesses, no engine mounts, pretty much you aint got ****. Well I would have to say this aint gonna happen. Im putting a chevy 350 in my 7th gen. You said you dont have the money for a k20, but yet you have thew money to custom fab a B16 swap into a 7th gen. Gonna have to say
:zbsflag:
Old Mar 17, 2004
auto84's Avatar
I R T3H 1338
^^^exactly what i was thinking only im not that blunt.lol.
Old Mar 17, 2004
RSXtypeIvtec's Avatar
Su Mo
what bad things have you heard about the K20? i haven't heard any?
Old Mar 17, 2004
lqdquik's Avatar
I admit the splicing is going to be the biggest pain but both the b16 and the d17 sit the same way in the car the k20 turns different so it sits different. The mechanic told me the custom mounts won't be a problem he deals with a machine shop that just did some for a different swap. How are you going to put a 350 in a 7th? Are you going to have more of a problem then i am.
Old Mar 17, 2004
HondaWhore's Avatar
Another thing, why would you buy a 7th gen to do a B16 swap. What a waste of money. Buy a 6th gen or older and save a buttload of money.
Old Mar 17, 2004
NaHoOnEyYa's Avatar
NaHoOnEyYa is an unknown quantity at this point
pix would help!
Old Mar 17, 2004
HondaWhore's Avatar
How are you going to put a 350 in a 7th?= Sarcasm my friend
And if you didnt pick that up and your doin a motor swap, GOOD LUCK!!!!!!!!!!!!!
Old Mar 17, 2004
auto84's Avatar
I R T3H 1338
so lets do a money count here:
how much did the "JDM" B16a2 cost you?
and the tranny?
and the motor mounts?
and the turbo?
and the custom exhaust?
and the wiring harness?
and the ecu?
and the labor?
am I missing anything?
Old Mar 17, 2004
lqdquik's Avatar
Well since i can't hear your voice it is kind of hard to hear the sarcasim. I bought the d17 in 2001 first year. Didn't really no much just wanted a new car. Found how much the engine sucks, and want to do something different that hasn't been done. And as far as I know this has not beed done.
Old Mar 17, 2004
lqdquik's Avatar
And for the person who said it was illegal! lol
How many laws do we everday.
Drinking for those not of age did you do it thats illegal ut oh you broke a law.
Not fully stopping at a stop sign. opps there is another one.
Street racing ohhh thats a big one (they impound your car for that one in philly)
Now if you don't do any of the above your a pretty good citizen but don't tell me that you don't go above the speed limit. Cause if you don't then you shouldn't even be in here talking to me.
Old Mar 17, 2004
Jodster's Avatar
Post Whore General
OK if you want to talk about doing the swap, what are you going to do about the shift linkage? They are totally different. Are you going to drill a hole in the floor?
FYI the new K-series motors are way better than the B-series. It will cost you more to install this B16 than it would for you to install a K20. Plus you can find K20A2s for $3500. And all the parts that are needed are pretty much out. And I've got the Clutch line you would need.
Old Mar 17, 2004
lqdquik's Avatar
Grow some *****!!!!!!!!!!
Old Mar 17, 2004
auto84's Avatar
I R T3H 1338
that was my point in asking him how much everything cost.
Old Mar 17, 2004
Jodster's Avatar
Post Whore General
Of course people do those things. If a cop takes the time to pop your hood, you better believe he is going to take the time to run the VIN on the motor. So don't come bitching here when you get your car impounded.
Old Mar 17, 2004
Jodster's Avatar
Post Whore General
Was that directed towards me? I started talking about your "swap" and asked some real questions and you run your mouth to me? Good luck getting people to talk techs about this with you acting lke a fu)k face.
Old Mar 17, 2004
iamboo's Avatar
Retired - SoCal FI Mod
this is getting really off topic... closed..
Old Mar 17, 2004
Su Mo
i believe this has been done before, i remember someone posting info/pics of it in a black 7thgen. i think it was done in Taiwan. I remember this cause thats where i'm from.
This was like 2 years ago or something....been awhile.
So i guess it can be done....but good luck
rallyeredem0
Nov 2, 2015 10:56 PM
Scout1
Oct 5, 2015 01:33 PM
Hatchness
Sep 14, 2015 09:02 AM
shaejb15
Sep 12, 2015 01:02 AM
NROD315
Sep 4, 2015 09:22 PM
