tach
Old Mar 15, 2004
detroitbeats's Avatar
detroitbeats is an unknown quantity at this point
tach
can someone help me with installing a autometer tach
Old Mar 15, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
what are you having problems with
Old Mar 15, 2004
well i wanna buy 1 but i heard they dont come with a book to hook it up
Old Mar 16, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
they dont come w/ a book because its a tach dude. They might come w/basic wiring instructions but seriously there should only be like 3 wires. Power, ground, and rpm signal.
Old Mar 16, 2004
cool
i just dont wanna burn anything up
Old Mar 16, 2004
DistinctiveBP's Avatar
Shows No Remorse
DistinctiveBP is an unknown quantity at this point
i have one on my car if u need any help ill be glad to help you
Old Mar 16, 2004
BREEZE's Avatar
Yeah, i drive an EP
BREEZE is an unknown quantity at this point
directions
here
Old Mar 16, 2004
Got Boost???'s Avatar
ok there should be 4 wires
1) ground
2) power
3) revs
4) illumination
Ground Wire - The ground wire should be close to the tach itself, if you remove the panels under the steering column you'll see a 12mm bolt just sitting there. Attach the wire to this and use it as your ground.
Power - ***WARNING is you dont disconnect your battery you must wrap the end of this wire ( the end that will be fed through the fire wall) in electrical tape because any contact with metal will cause your fuse to blow out. So either disconnect the battery or wrap the exposed end in electrical tape.***
Open up your under the hood fuse box and locate the HORN STOP fuse remove the fuse and place the end of the wire under it and reinsert it.
Revs - This is the blue wire that was talked about earlier. Its over by the battery in a bundle, just pop off the cap and connect
Illumination - Open up your under the hood fuse box and remove the right headlight fuse, place the end of the wire under the fuse and reinsert the fuse.
Now that have all your lines connected you need to feed them through the firewall. If you look down past the steering column and to the passengers side you'll see a sorta of neon blue line comming through the firewall. This is the point thats easiest to feed the wires through.
Old Mar 17, 2004
thanks alot
Old Mar 17, 2004
hey wheres the blue wire?
im sorry if im being a pain i just dont wanna go cutting into wires .ive learned my lesson
Old Mar 17, 2004
Shows No Remorse
pic 1
Old Mar 17, 2004
Shows No Remorse
pic 2
Old Mar 17, 2004
pic 2
DistinctiveBP has attached this image:
(thats all i see i dont see any pic)
Old Mar 17, 2004
Shows No Remorse
here is a close up. its the one with the lil black plastic piece attached to the end of it
Old Mar 18, 2004
Shows No Remorse
can you see them now?
Old Mar 18, 2004
yes
so that the top corner of the engine bay near on the drivers side?
Old Mar 18, 2004
Shows No Remorse
no if your looking at your engine bay. look right next to the battery.
Old Mar 18, 2004
ok thanks so much i cant wait to hook it up
Old Mar 18, 2004
Shows No Remorse
no problem man. if you need any more help just lemme know
Old Mar 18, 2004
cool thanks.is there a better way to talk than this.like a chat room?
Old Mar 18, 2004
BREEZE's Avatar
Yeah, i drive an EP
my pic was right on
Old Mar 22, 2004
wow that was soooooooooo easy
thanks alot
i wanna hook up more gauges
oil pressure ,temp ,airfuel can u help
Old Mar 24, 2004
Shows No Remorse
only other guages i have installed on 7th gen civics are A/F and a VAC gauge
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
NROD315
Sep 23, 2015 03:46 PM
MamaBear2015
Sep 15, 2015 09:35 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
bhayes82
31
Feb 11, 2002 01:00 PM
