9psi without alcy?
Old Mar 11, 2004
MadWheel's Avatar
Premium Boosted Member
9psi without alcy?
I have an EX with all the supporting mods and have 93 octane at every gas station where i live...
I've been told by 2 diff 7thgen boosted owners, they've run 9 (one ran 10) without detonation and one doesn't even have alcohol injection, the other didn't use it.
If I run 9psi, without the alcohol, on my EX and iridium plugs on 93 octane, anyone think this will be fine. One of the members is very knowledgeble and he sounded pretty confident.
Old Mar 11, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
What about timing retard?? What injectors are they using?? What about fuel???
Just wondering. Cause, I don't think it's absolutely impossible, but from what I understand detonation is possible at 10PSi and can be quite likely.
I'd just be worried bout fuel for the most part. Guess the only way to know for sure is to give it a whirl. Let us know, how it goes if ya do and good luck. Just keep close attention to how the car reacts/acts.
Old Mar 11, 2004
MadWheel's Avatar
well here's the thing... i have the sf kit... as the psi goes up, so does the fuel, so the mixture will always be right...
i just worry about my ignition i guess...
they were both using stock injectors. one with sf fuel system, one with greddy emanage, return conversion and fpr.
Old Mar 11, 2004
SpdRcrChk's Avatar
BOOST JUNKY
Both using stock injectors eh? Hrrmmm.....but the SF kit ads an extra injector in the charge pipe correct??
Old Mar 11, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
No extra injector on SF kit.
Old Mar 11, 2004
SpdRcrChk's Avatar
BOOST JUNKY
Welp....I wouldn't be happy (personally, like if I were you) until I put it on a Dyno and made sure everythin' looked ok if I did bump it.
Old Mar 11, 2004
Havok2k1's Avatar
Wicked Pissah Admin
You would need to retard the timing if you planned on running the SF FMU and 10lbs without the injection...
The fuel issue SpdRcrChk was talking about is the capacity of the fuel pump and fuel injectors. They both will reach a point where they cannot supply more fuel... You can run a 20:1 FMU all you want but it won't work unless the pump and injectors can supply the fuel...
Old Mar 11, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I'm one of the ones who said they did 9-10psi.
I did it with the return conversion and all that. But I did note that I raised the fuel pressure to do that and so I ran it rich. Before I even went to 10... I checked to make sure I was good for 6,7,8, and 9psi individually. I had no problems or signs of detonation or anything. No change to timing or injectors. But it was a one time deal that I did that. I'd say if you seriously wanted to run it, you should go to a dyno and be sure it's right. I'm just saying that I didn't have any problems when I did. I can't say what would have happened if I kept it up.
Old Mar 11, 2004
Boosted2k2's Avatar
I should probably also mention that I have an LX and the compression is lower. LX 9:1 vs EX 9.5:1
Old Mar 11, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
I run 10psi pretty frequently, but I have an additonal injector system, so my stock injectors do not max out. Even at this, on a cold day it's not safe because colder air=denser=needs more fuel, and this is about the limit of the stock fuel pump. So I rarely go above 8psi when it's cold out, but in summer and spring I run 10psi without any problems.
Old Mar 11, 2004
keepin_it_clean's Avatar
keepin_it_clean is an unknown quantity at this point
Man i want boost.
Old Mar 11, 2004
SpdRcrChk's Avatar
BOOST JUNKY
Yup. Thanks for clarifying that.
I was discussing that today w/my b/f and we're both wary of bumping to 10 psi on stock injectors. But....as it's been mentioned, a return fuel conversion w/FP and FPR and aftermarket injectors would definitely help.
The compression is relevant too, but I don't think 10PSi on 9.5:1 would be unfathomable. Just...like it's been mentioned a thousand times...tuning!
Old Mar 13, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
I dont want to argue. But how did "torque king" run 14psi and two occasions w/ no problems. He also ran 12psi several times also w/ no problems. He was running the stock SF kit w/alch. I ran 14psi on accident and checked for blown head gasket and dont see signs. Maybe lucky? Who knows. I will have my DH heads soon and will know for sure about the head gasket. Godd luck to all,..
Old Mar 15, 2004
rscivic's Avatar
rscivic is an unknown quantity at this point
I did a couple runs @ 10 but I stay safely at 8 all the time w/ no problems.
We have all heard the story though, that it may not seem like high boost is causing problems at first but it may come back to haunt you....
keep us posted though if you do keep it at 10 or 11for a while and if there are no problems b/c I will run out and turn the allen key to up mine!
Old Mar 16, 2004
Maverick's Avatar
Maverick is an unknown quantity at this point
I ran 10 lbs daily w/ no alcy and no additional injectors(using stock) and 93 octane. no probs whatsoever...it's been tuned a lil by a shop but other than that it's the same as when i installed it over the summer...just sold it tho...looking to put new injectors in, but could never find the right ones
Old Mar 17, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
Answer me this...When i had my boost turned up to 6-7, at wot i can feel the car studder, and i hear like this ticking sound through my boost gauge. IS THIS DETONATION? It only did this when i would try and run it hard like in a race or something. I have since turned the boost down and I don't have this problem anymore, but i want to go faster damnit
Old Mar 17, 2004
Maverick's Avatar
The "stuttering" you're probably feeling is just the boost controller doing it's job...that will happen anytime you go wot and let boost get to whatever level you're controller is set at and then some...as for the ticking through you're boost guage...get a new boost guage.or check the wiring.and oh, you can go fast man, trust me
Old Mar 17, 2004
fuchs's Avatar
I don't have my boost controller hooked up yet and it only will do it when i adust the boost to go around 7. As for my boost gauge...same thing only above 6 and it is brand new, I don't see how any wiring could be loose... the only wires there are for the light. The rest is just a straight line to the T fitting.
Old Mar 17, 2004
guns's Avatar
Skyline R33
You can tunr boost up by placing a T fitting on the hose going to your wastegate. Leave the end of the hose open and it will be like an open bleeder valve. Make sure it is a small T with small opening. This is what I do to get to 10psi. It works and no problems.
Dont put two T's in this is where I spiked to 14psi. I thought I blew my water jackets out, but now I am not sure. Will know soon when I pull my heads.
Old Mar 18, 2004
BoostedCivicZex's Avatar
Proud Srt4 owner
yes i am one of the members madwheel is talking about that has alcohol injection but i rarely use it. I have ran 9-10psi without it many times but I also have a s-afc to add in the extra fuel if needed.
EMK20a2
Sep 8, 2006 05:27 AM
ruffryde009
Engine Swaps
27
Jul 19, 2006 09:26 AM
jwcardy
Engine Swaps
65
Jan 12, 2006 05:30 PM
Ahtasham
Engine Swaps
Sep 6, 2004 04:43 PM
MadWheel
North East
May 24, 2004 09:20 AM
