Ait Sensor Question...
Old Feb 12, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
hey i gotta question for all the boosted ppl. if i take sensor that plugs into the intake by the throttle body and removieit from the intake pipe and just let it get its readings from the engine bay instead.. do u think it will affect anything?
my only reason for doing this is that i cant get a good seal around the damn thing . it keeps leaking boost.
what have u done to this sensor? got pics? show me!
Old Feb 12, 2004
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
I just ziptied mine off when I had my turbo, which is now sold.
Old Feb 12, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
You will have problems if you just put that sensor in the engine bay. May not be big problems, but during cold and hot weather, you will not run right, as that sensor controls a fuel map modifier table based on intake air temperature... also a very important thing to a boosted motor.
Here's how I did it... kinda ghetto looking but works perfectly. Metal nipple welded to charge pipe, then what you see here.
Old Feb 12, 2004
C2i0v0i1C's Avatar
SuperMODrizd
is that also a pict of ur return??
Old Feb 12, 2004
First to spool
No, I do not have a return line. That is the supply for my additional injector.
Old Feb 12, 2004
JohnyBlaze's Avatar
JohnyBlaze is an unknown quantity at this point
Where is that sensor supposed to go? In the intake manifold, or the stock intake air box?
If it is in the intake manifold, and you remove it, what are you sealing the hole with so that you don't leak boost?
Old Feb 12, 2004
First to spool
Pretty sure it was in the airbox, but it's been so long since I've had the stock airbox in the car that I can't remember for sure. But there's nothing plugged on the intake manifold or throttle body, so it would have had to be in the stock airbox.
Old Feb 12, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
thanks bro.. im gonna do that... i gotta find a piece of pipe now to weld on like that! thanks !
Old Feb 12, 2004
JohnyBlaze's Avatar
Ah, okay. I have this sensor relocated to the air filter intake pipe, i.e., the pipe attached to the compressor inlet.
Any downside to having the sensor BEFORE the turbo? We put it there so that we wouldn't have to worry about leaking boost.
Old Feb 12, 2004
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
what i did on mine was use the tape that plumbers use on the thread of pipes to make it a tighter fit... a 50 cent fix.
Old Feb 12, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
if any of you have an aem intake you can use the rubber gromet and connector from it. That's what I'm going to do.
Old Feb 12, 2004
civicskater's Avatar
Chicks dig my scent
^^^Yes sir. just use that gromet, find a drill bit that size, put you a hole, and wa la...perfect fit
Old Feb 13, 2004
First to spool
Yep, big downside. Incorrect readings. Air is heated as the turbo compresses it, then is cooled when it flows through the intercooler and if any nitrous is sprayed. Needs to be close to the throttle body to be accurate.
Tedverseti
Apr 23, 2020 01:45 PM
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
mistermenphis22
Jul 13, 2015 04:43 PM
