Att. ALL BOOSTERS. QUESTION ON SETUP
Old Jan 31, 2004
Ouse's Avatar
Ouse is an unknown quantity at this point
Question Att. ALL BOOSTERS. QUESTION ON SETUP
I've seached and heard alot of talk of wich turbo size to go with but i wanted to hear opinions.
What size intercoolers are you runnin? im looking to work my way up to 3oo hp max. im questioning if i should go T3 or T3/T4?
Old Feb 1, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
So long as you get a good intercooler, such as a Spearco or GReddy that has good flow, you can get just about any size you'd like that fits behind your bumper. So figure out how you're going to run your piping, and then measure how much of the bumper hole you want your intercooler to fill, and figure out if you want to do any bumper cutting. Bigger is not always better, you'll reach a size where the increased lag and pressure drop across the intercooler is worse than the cooling effects of a larger intercooler core. This size is pretty huge though, so I'd say just get the biggest intercooler that will fit behind your bumper.
As for turbo choice, it depends on what you want the car for. The T03/04 will make slightly more power due to it being a larger turbo, but the T3 should spool slightly faster. Much also depends on which brand of turbo you are going to go with, because that can make all the difference in the world. If you have a brand of turbo you can get cheaper through shop connections or something like that, then you figure out which of that line you want, because almost every turbo producer has a turbo that will work well with our engines, but they all call them different names.
Basically, both your questions are partly based on personal preference, so it's what you want on your car that makes the choice. For my personal recommendation, I'd go with the Turbonetics T3 Super-60 turbo if you want fast spool, or the Turbonetics T03/04B (what I have) for more power with a little more lag. Spearco intercoolers are great, and you can get them in just about any size you'd like.
Old Feb 2, 2004
Ouse's Avatar
Thanx riceburnr. does im lookin to max out my hp at about 300 hp. would a t3 make it there without loosing efficiency. Im either going turbonetics or garette. has anyone sized our bumpers to see what is the biggest intercooler we can run?
Old Feb 2, 2004
RiceBuRNeR's Avatar
Turbo Member
I have a Garrett GT25BB and its rated for 325+ hp. It spools up very fast, and doesnt lag between shifts. If you only want 300 hp thats what Id go w/. BTW: Im selling my T25 manifold for $125 shipped.
Old Feb 2, 2004
Ouse's Avatar
why are you selling the manifold? and what size intercooler do you have?
Old Feb 2, 2004
RiceBuRNeR's Avatar
Turbo Member
Im selling the manifold b/c Im geting a equal length one made. Im using a custom intercooler made from a 18x6 inch spearco core.
Tedverseti
Apr 23, 2020 01:45 PM
cukaracha
Aug 27, 2015 02:02 AM
Strycker
Aug 2, 2015 08:40 PM
