Specific turbo questions...plz help!!!
Old Jan 30, 2004
sterned4's Avatar
sterned4 is an unknown quantity at this point
I want to get a Garrett T25BB turbo and run 8lbs. At 6lbs its supposed to gain 56% WHP over BHP..ie (127x1.56=196WHP). This is also with many upgrades for the turbo system and NOT internals. And I want to run 8lbs. Should i lower the compression ratio, and how would I do that? Also, should I get a new clutch to handle the new power?, AND should I get any new internals. I have done searches and I am not getting the info I need. THANKS!!!!
Old Jan 30, 2004
Deamon32's Avatar
Deamon32 is an unknown quantity at this point
i dont know if u should lower the compression ratio, but im pretty sure u lower it with new headers, the clutch will hold 200 ft/lb of torque, so you should look into getting a new one. and the internals should do fine with 8 lbs, but not for too long, so something might blow sooner or later
Old Jan 30, 2004
C2i0v0i1C's Avatar
SuperMODrizd
whoa, compression ratio is lowered or raise based on the piston being dome or dish and ur close on the numbers try 110 as the base bc thats about what it is at the wheels, or at least its right around that number, new internals are cool, and a clutch would be recommended
Old Jan 30, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
I don't know what would make you say that......
Also its called a Header.
Not trying to be a ****. Compression ration can depend on alot of things pistons, head gasket...........etc.
If you are putting together your "own" turbo kit I would think the hardest thing to get around would be the fuel system. People have done it though. Do searches and talk to them. Or maybe they'll post.
Old Jan 30, 2004
civicskater's Avatar
Chicks dig my scent
Get the SF fuel system unit...from what i've heard it kicks ***, and you dont have to tune and do a fuel return lke you do with the greddy emanage
Old Jan 30, 2004
sterned4's Avatar
no no guys. Its a kit. I think it comes with a fuel unit. I really just want to know how i can lower my compression easily and cheaply. Maybe ill get a SF fuel rail. And also running 8lbs daily would really hurt my engine? I want it to last 150,000 miles at least.
Old Jan 30, 2004
C2i0v0i1C's Avatar
SuperMODrizd
how cheap u talkin, a new head gasket from dealer is like 28-35 bucks or so, but then thats not easy bc it will raise the head a lil and throw ur timing off, its not like u can just unscrew/unbolt something and make the CR lower
Old Jan 30, 2004
C2i0v0i1C's Avatar
SuperMODrizd
is this for a 7thgen just out of curiosity
Old Jan 30, 2004
sterned4's Avatar
Yea its for a 7th gen. Thats what i was planning on doing is the head gasket. I can just change my timing later. Its probably what I will end up doing.
Old Jan 31, 2004
C2i0v0i1C's Avatar
SuperMODrizd
why would u change the timing later, the moment u put the head gasket on the timing will be thrown, i dont understand why u dont do it at the same time
Old Feb 1, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
...um...i don't mean to sound like an inconsiderate ***** here...but! um...the only way that you could throw off your timing doing a head gasket is if you don't put the cam gear and the crank gear lined up properly with the timing marks. just putting in a gasket won't throw your timing off.
if you can prove that doing what you said will throw your timing off i'll believe you...but until then i'm going by what i have seen happen in the shop.
Old Feb 1, 2004
No wait, I thought of something. If you put a thicker head gasket on, that will make the timing belt tighter.. throwing off the marks. My bad.. sorry man
Old Feb 1, 2004
tfnaaf's Avatar
BLDNPSI Mod
I could be wrong but as i recall if the head gasket is thicker or thinner then OEM it will change the cam timming SMALL amounts.
Old Feb 1, 2004
sterned4's Avatar
yea....I WILL do it at the same time. But does anyone know how much it will lower the compression from a 9.9:1???? Plus I think running 8lbs on a T25BB doesnt need that much lower of a compression. BTW...can I just use an adjustible cam gear to change my timing or do I have to get another TDC??? Ahhh!! just thinking about having to do all these things for my turbo is making me pull my hair out.
Old Feb 1, 2004
C2i0v0i1C's Avatar
SuperMODrizd
thats why bolt ons are better, and custom ones take more thought, NOT A DIS TO THE THOUGHT THAT WENT INTO SF,
ricer_em2
May 11, 2016 08:09 PM
HondaGuy7
Feb 22, 2016 01:00 PM
Bruce2
Sep 27, 2015 08:45 PM
IronFist
Sep 25, 2015 07:13 PM
rnaodm
Sep 21, 2015 12:42 PM
