Basic Turbo Parts
Old Jan 8, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
Basic Turbo Parts
what are the basic main ingredients needed to custom build a turbo set-up... I know i need ta search but i'm just looking for the most basic responses... like i know i need:
Turbo
Custom Manifold
Intercooler
I/C piping
bigger injectors
hardpipe w/BOV
Fuel Management
Wastegate... other side of turbo right?
Oil Lines
Boost Gauge and Controller
what else is the basic expensive stuff??? or have i covered the stuff i need for a basic reliable turbo kit?
Old Jan 8, 2004
Jodster's Avatar
Post Whore General
You need some kind of fuel management.
Old Jan 8, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
wastegate, oil lines...hmmm i cant think of anything else right now. Custom set-ups are the best tho!
Old Jan 8, 2004
civic01vtec's Avatar
boost controller, gauges.....PM C2i0v0i1c or Opto_Isolator........they will know.
Old Jan 8, 2004
BoostedCivicZex's Avatar
Proud Srt4 owner
map sensor
Old Jan 9, 2004
REDchirp's Avatar
ok... i updated the list
Old Jan 9, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
I would get an a/f ratio guage.
Do not forget the fittings needed to run the oil lines, or the fittings for the drain line (unless your welding a stub in the pan)
Old Jan 9, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
even with a narrowband map sensor???
Old Jan 9, 2004
Catalyst's Avatar
It will still let you know if you are rich or lean. You do not need a wideband to tell you that. The wideband is only good for precise tuning.
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
juror
May 26, 2015 06:35 PM
ktdezall
May 16, 2015 07:53 PM
cloudguy
Apr 28, 2015 05:02 AM
bsmiley
Apr 27, 2015 01:27 PM
