Buying a nitrous kit
Old Jan 9, 2004
dinimicus's Avatar
dinimicus is an unknown quantity at this point
Question Buying a nitrous kit
Hey i got a friend who is selling me a nitrous kit for $200. He used on his Hatchback and i was wondering if i buy it will i be able to use it on my 01 civic? Is there a problem that its for a hatch or what? Do you guy's think i should buy it?
Old Jan 9, 2004
ZapThyCat's Avatar
ZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to behold
If it's a DRY system, it is not going to work on our civics, although it might have in past generation civics... we have something like a... vacuum regulated fuel system or something? that makes it where more fuel (to compensate for the N2O) cannot get pumped into the engine. Previous civics could do this.
As long as the system is WET (which means fuel is added in with the N2O) then it should work fine with our cars.
Old Jan 9, 2004
75shot's Avatar
I <3 my Evo
75shot should not be trusted
what he said
find out who makes the kit, and probably the product number. then we will know for certain.
Old Jan 9, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
yeah make sure you get a t connector to tap into the fuel line and to
get a wide open throttle switch along with it.
Old Jan 9, 2004
dinimicus's Avatar
Hey thanks alot i'll check and see whats up. One more question i can make to where it only gives me like a 50 shot a not a 75 shot like he had it on his right? What would i need to that?
Old Jan 9, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
smaller fuel and nitrous jets
Old Jan 9, 2004
dinimicus's Avatar
So do you'all think i should get the kit or pass? I think it is a wet kit?
Old Jan 9, 2004
Catalyst's Avatar
That is a good price for a wet kit. Make sure if you buy it that he gives you everything. Even the Throttle switch (if he has one)
Old Jan 9, 2004
dinimicus's Avatar
Ok thanks alot. Hey how much would it be for installation or can i just do it my self?
Old Jan 9, 2004
Catalyst's Avatar
It depends. It can run anywhere from $50 to $200 to install it. It is pretty simple. As long as you are knowledgable with wiring stuff up, you should be able to install it. The install of the actual jet, solenoids, and lines are easy. The wiring is what gets people.
Tedverseti
Apr 23, 2020 01:45 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
chrisjackson321
Jul 12, 2015 03:00 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
