about Engine swap..
Old Jan 2, 2004
DOHCVTEC's Avatar
DOHCVTEC is an unknown quantity at this point
about Engine swap..
can 02 Si uses 200 HP RSX type s engine?
how about transmission?one is 5 speed..one is 6 speed
because "bascially" they are the same engines..
2.0 Liters
thanks
Old Jan 2, 2004
BoostedCivicZex's Avatar
Proud Srt4 owner
no they arent the same, the k20a3(si) has half *** vtec and the k20a2(rsx) has true vtec
Old Jan 3, 2004
DOHCVTEC's Avatar
ok..but would they fit?
Old Jan 3, 2004
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
yes, HASport has a mount kit that mounts the rsx-s motor into the 2002 si. checkout www.hasport.com
Old Jan 3, 2004
hondaciv01's Avatar
hondaciv01 is an unknown quantity at this point
yeah, the vtec in the si isn't the true vtec that we all know and love. its a ***** vtec. where the k20a2 is just a beastly vtec.
Old Jan 4, 2004
bongobennie's Avatar
bongobennie is an unknown quantity at this point
the two engines ARE identical as far as your concerned, yes the heads are different, but since the head only touches the block, it doesnt matter, trannies are the same too, but you will have to mod the shift linkage for the sixth gear, and you can use the 5 speed, but i doubt you want to
Old Jan 4, 2004
also, no mount kit needed for Si
Old Jan 4, 2004
HondaLuver's Avatar
Its a celebration bitches!
all k series engines are interchangeable with the heads blocks and trannies.
you can have a si block with a rsx S head and a rsx R tranny
its all about the series
same thing with the b series engines... everything mixes
Old Jan 4, 2004
civicvtec1ps's Avatar
Search and Learn
Sure can.
myeverlovinsir has swapped the Type-S head and ECU and made a complete walkthrough of it on EPhatch.com. He also made video of it, he first ran the head swap with a Hondata flashed Si ECU which allowed the car to run in Vtec from 2200rpm all the way to 7700rpm(sounded mean). He then changed ECU's to the proper K20A2 ECU and the car runs like a Type-S now.
Yay, i own civic si with half *** vtec.
Here is video
http://www.imagestation.com/video/pl...?id=4196599311
Old Jan 4, 2004
Proud Srt4 owner
^^^^ hahahah, yeah its half *** cause the packers won today damnit lol
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
