Ok, i finally dynod the beast.
Old Jan 2, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
This is both good and bad.
Bad: I know that the stock clutch can only handle 200 ft/lbs of torque,
Good: I made 200 ft/lbs at 4,300 rpm
My clutch let go right at 200 ft/lbs. I will post the dyno run later. I made a second pass on the dyno with just feathering the throttle and it made 200 ft/lbs from 4300 rpm all the way til after 6500 rpm. The clutch was slipping the whole damn time. I also have a video, but it is rather large, and i dont have DSL. But my man Richard is going to email me my graps later on tonight so i can post them.
Old Jan 2, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
woo nice.. now what is this at? what psi ? what turbo what what what.. lol.
edit u have stock clutch too right?
Old Jan 2, 2004
Catalyst's Avatar
11 psi on the stage II kit, with the stock intake manifold.
Old Jan 2, 2004
Catalyst's Avatar
completely stock clutch.
we are already working on getting a flywheel, pressure plate, clutch combo
Old Jan 2, 2004
Catalyst's Avatar
we expect around 250-260 ft/lbs with a clutch that holds. That translates into somewhere around 270-300 whp.
Of course we will not know until i run it with a better clutch.
Old Jan 2, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
yea ur losing alot with that clutch..
Old Jan 2, 2004
sexcivic2k1's Avatar
mm boost
Old Jan 2, 2004
JayFReaZy's Avatar
cool, cant wait to see the dyno's
Old Jan 2, 2004
honda04civic's Avatar
honda04civic is an unknown quantity at this point
wow thats bad ***, but yipes about the clutch, keep up the good work bro your making me happy :-)
Old Jan 2, 2004
opto_isolator's Avatar
stage II includes the pnp job from josh - right?
Old Jan 2, 2004
BoostedCivicZex's Avatar
Proud Srt4 owner
damn, thats a lot of power lol
Old Jan 2, 2004
civicskater's Avatar
Chicks dig my scent
holy ish man. What a beast, with that new pressure plate combo and flywheel you're car will feel brand new x10...its awesome, just got the ACT clutch in and on a n/a car im loving it!
Old Jan 2, 2004
civic01vtec's Avatar
now ur scaring me cat....looks like i am gonna have to pull the tranny now to put a clutch in.
Old Jan 3, 2004
detoX's Avatar
detoX is an unknown quantity at this point
cant wait to see the dyno and video cat!
Old Jan 3, 2004
ImportRacer2123's Avatar
K20 Member
I can't wait to ride in that beast you call a civic
Old Jan 3, 2004
MadWheel's Avatar
Premium Boosted Member
What clutch you going with? That's my next mod so I'm curious to see what people bought. Im thinkin of the centerforce dual friction clutch with the ACT pro-lite flywheel setup. Any other decent setups that's cost effective?
Old Jan 3, 2004
Catalyst's Avatar
Well, we will be making a flywheel for our cars. They are special, and there is nothing out on the market like them for these cars. They will be aluminum, with inserts that you can replace when they get worn.
We may have the clutch changed by this next weekend, so i may be able to dyno it again then.
Old Jan 3, 2004
Elite's Avatar
Elite is an unknown quantity at this point
Well yeah when you add something like that especially a turbo, you need too add stuff that could hanlde it, its like lowering your car without shocks, just coilovers, u need the other half of it. 91 or higher octane for turbo, plugs etc. all that.
Old Jan 3, 2004
^^^ no ****.......but i was hoping that i could get away with the stock clutch until next winter.
Old Jan 3, 2004
MadWheel's Avatar
You can man. I'm still on my stock. His upgrades are pretty large, that and the fact that it's been subject to repeated abuse.
Cat, how much you want for a custom flywheel?
Old Jan 3, 2004
ditto, i am in the market for a new clutch/flywheel, let me know what your combo will cost.
Old Jan 3, 2004
Elite's Avatar
I was hoping to drop my car without shocks but it didn't work
Old Jan 3, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
sorry, I'm stupid ... but your clutch slips when you accelerate?
Old Jan 3, 2004
C2i0v0i1C's Avatar
SuperMODrizd
shouldnt u KNOW ur whp, considering u put it on a dyno, or are u just waiting to post the whole thing at once
Old Jan 3, 2004
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
clutch slipped and gave out before he got good reading... i believe it can hit 300hp at wheels... that torque is SWEET for a civic... damnit man i need that head like NOW...
Old Jan 3, 2004
SFpower's Avatar
Former Sponsor
SFpower is an unknown quantity at this point
horsepower numbers are derived from the equation (torque * RPM)/5250
When the clutch only holds 200 ft.lbs, the whp does not read correctly. With the clutch slipping from 3800 RPM til redline, the car still made 235 whp. With the new clutch installed, it should have no problem making 260 whp. At the highest, it will probably touch 300. And make about 250-265 ft/lbs.
Old Jan 3, 2004
Jaykuai's Avatar
ish...
now i wonder if i really want a k24 swap
Old Jan 3, 2004
civicmorph's Avatar
civicmorph is an unknown quantity at this point
ok can someone explain what the difference between whp and hp is? or are they the same? sorry I'm a noob when it comes to whp and hp initials
Old Jan 3, 2004
whp means that it is measured at the wheels. That is the true hp that goes to the ground.
car manufactures ususally measure hp at the flywheel w/o the a/c and other accessories robing power from the motor. They do this to make it appear that the engine is more powerful than it actually is.
EDIT: whp is measured on a chassis dyno while hp measured at the flywheel is measured on a engine dyno.
Old Jan 4, 2004
kileryoyo's Avatar
kileryoyo is an unknown quantity at this point
^^^^^ couldnt of said it better myself
