Ok, i finally dynod the beast.
Old Jan 25, 2004
  #121
icebergslim's Avatar
BOOSTED HYBRID
icebergslim is an unknown quantity at this point
Originally posted by Catalyst
in about 2 weeks ill show you what we can do with a K20. The pipes need powdercoated and the downpipe needs made. Then the K20 civic beast will be complete.
Can't wait to see it.
Old Jan 25, 2004
  #122
civic01vtec's Avatar
Originally posted by opto_isolator
wenlyone, just stop looking like an idiot and stfu already.....quit fvcking up this thread.
naw opto he is allowed to.....anybody can talk **** on the internet now
Old Jan 26, 2004
  #123
C2i0v0i1C's Avatar
SuperMODrizd
this looks better than anything wenlyone can do
Old Jan 26, 2004
  #124
C2i0v0i1C's Avatar
SuperMODrizd
look for it on the cover of DRAG
Old Jan 26, 2004
  #125
C2i0v0i1C's Avatar
SuperMODrizd
wnelyone, is your 7thgen turboed, if not, u dont have the authority to talk to me if ur going to look like a fool, so until it is dont talk about me and dont talk to me, and certainly dont talk about **** u have know idea about
and if u dont have a 7thgen then stfu permanently
Old Jan 26, 2004
  #126
Old Jan 26, 2004
  #127
Jodster's Avatar
Post Whore General
Yeah I've seen Tims hatch. That thing is bad ***. Nothing wrong with 10s in the quarter.
Old Jan 27, 2004
  #128
Catalystsgrl's Avatar
Catalystsgrl is an unknown quantity at this point
Too bad dave hickman wont allow cameras near his crx.
Old Jan 27, 2004
  #129
C2i0v0i1C's Avatar
SuperMODrizd
now that makes me a believer for sure
Old Jan 28, 2004
  #130
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
Originally posted by wenlyone
700 hp on 42psi and 80 shots is not a good number... a/i with 80 shot? obviously, you have no clue. sadly, your car is a joke, and by talking and bring your shop into the picture, you just made a joke out of your tuners. ask them to explain to you why you sound so stupid.
here is a b18 on 30 psi. at the end of its career, it ran 780whp without wastegate.
you shouldn't talk **** when you have no ****ing clue.
Whoa whoever tuned that engine is horrible...Look at its A/F ratio! Know wonder it died
Old Jan 28, 2004
  #131
C2i0v0i1C's Avatar
SuperMODrizd
yea did the car die completely between 5.5 and 6.5
Old Jan 29, 2004
  #132
kTxCiN's Avatar
Stage7
kTxCiN is an unknown quantity at this point
that is so pretty
Old Jan 29, 2004
  #133
lid6662's Avatar
lid6662 is an unknown quantity at this point
Wow thats amazzzzzing
Old Jan 30, 2004
  #134
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
dyno's for my car at 5.5 psi and 11 psi are coming up in a few minutes.....
Old Jan 30, 2004
  #135
kikoman0's Avatar
kikoman0 is an unknown quantity at this point
HELL YEAH
Old Jan 30, 2004
  #136
VTECTypeR's Avatar
Waiting impatiently
Old Jan 30, 2004
  #137
Catalyst's Avatar
Here is the 5.5 psi graph
And here is the 5.5 vs. 11 psi.
*note: The clutch completely let go at 4300 RPM. hence it could not pick up the power.
Old Jan 30, 2004
  #138
kikoman0's Avatar
DAAAAAAAMN....THAT IS OFF THE HOOK
Old Jan 30, 2004
  #139
kikoman0's Avatar
damn that turbo made power prety quick at 3k rpm on 11pounds
Old Jan 30, 2004
  #140
heathenz's Avatar
heathenz is an unknown quantity at this point
hey cat was that with pnp done, didnt feel like running back through the thread.
Old Jan 31, 2004
  #141
Catalyst's Avatar
yea, thats the PnP from DHracing.
Old Jan 31, 2004
  #142
civicfreak84's Avatar
civicfreak84 is an unknown quantity at this point
I am not an expert on turbos but I am aware of some of the basics. Maybe someone can shiens ome light on what I don't know. BUt aren't our engines aluminum? If so, this turbo charging setup would put our engines under a lot of stress. Right? I mean I am looking into turbo charging my car but I do care about where my reliability for my 2002 honda civic ex couope will go. To add another thing, our engines are high compression. Usually turbocharged cars are low compression. With this kit here, we are already looking at changing the clutch and flywheel. would anything else have to be changed? I am just curious, so CAT if you can tell me what you think about my concerns or anyone else for that matter I would really appreciate it. I am just concerned with doing a good job that will last a long time without problems.
Old Jan 31, 2004
  #143
Catalyst's Avatar
the block and head is aluminum. If dissipates heat much better than cast iron. The cylinder wall is steel with an aluminum outer shell. This motor was built just like every other honda engine. Just because it is aluminum doesnt meant that you cant turbocharge it.
And to address the high compression issue, we finished the prototyping of the celica GTS kit, which has 11:1 compression, where our civics have 9.7:1. And the celica runs 9 psi on pump gas and no alcohol injection.
Old Jan 31, 2004
  #144
kileryoyo's Avatar
kileryoyo is an unknown quantity at this point
good news for us then
Old Jan 31, 2004
  #145
C2i0v0i1C's Avatar
SuperMODrizd
u turbod an 11:1
Old Feb 1, 2004
  #146
darklegacy540's Avatar
darklegacy540 is on a distinguished road
ImportRacer2123...you have the best sig i have ever seen in my life...*droooool*...
Old Feb 1, 2004
  #147
Andrick's Avatar
Andrick is an unknown quantity at this point
u turbod an 11:1
No they didn't turbo charge a 11:1 Compression Ratio motor. That would be too easy. They turbo charged an 11.5:1 CR motor.
Toyota Celica GT-S
2ZZ-GE 1.8L DOHC
Aluminum block and head
Variable Valve Timing and Lift with intelligence (VVTL-i)
11.5:1 Compression Ratio
82mm Bore/85mm Stroke
Toyota Celica GT/Pontiac Vibe/Toyota Matrix XR and Base/Toyota Corolla
1ZZ-GE 1.8L DOHC
Aluminum Block and head
Variable Valve Timing with intelligence (VVT-i)
10:1 Compression Ratio
79mm Bore/91.5mm Stroke
These guys make it look so easy don't they.
Richard
Old Feb 1, 2004
  #148
Catalyst's Avatar
Thank you richard. We make it that easy because we are just that damn good.
Old Feb 7, 2004
  #149
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
Originally posted by civic01vtec
thats a fuked up pic
Old Feb 7, 2004
  #150
guamcivic2k1's Avatar
YoUnG N SuXsExFul
damn good numbers for the civics..i wanna see the civic k20 beast..hehe
