Ok, i finally dynod the beast.
Old Jan 4, 2004
  #31
username03's Avatar
The Anti-Rice
username03 is an unknown quantity at this point
o man... i heart the SF
Old Jan 4, 2004
  #32
iamboo's Avatar
Retired - SoCal FI Mod
Originally posted by SFpower
horsepower numbers are derived from the equation (torque * RPM)/5250
When the clutch only holds 200 ft.lbs, the whp does not read correctly. With the clutch slipping from 3800 RPM til redline, the car still made 235 whp. With the new clutch installed, it should have no problem making 260 whp. At the highest, it will probably touch 300. And make about 250-265 ft/lbs.
un-freakin'-believeable...
i still can't believe how crazy this thing is...
Old Jan 4, 2004
  #33
MadWheel's Avatar
Premium Boosted Member
All with stock pistons and rods... What's the point of a swap again?
Old Jan 4, 2004
  #34
Jaykuai's Avatar
ish...
^ i will do it for the galore of just reving up to 8500 rpm
Old Jan 4, 2004
  #35
HondaLuver's Avatar
Its a celebration bitches!
meee tooo^^^^
but dam, that is pretty sick...
Old Jan 4, 2004
  #36
cdmx's Avatar
Dayum i need $$$$$$$$$
Old Jan 4, 2004
  #37
Havok2k1's Avatar
Wicked Pissah Admin
Nice job Cat, nice to see some decent numbers.....
Old Jan 4, 2004
  #38
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
yeah no doubt... 200hp to the wheels with K20 is pretty expensive... swap is no good imo... and you can rev to 8500 all day, K drops off in power above 7500.... doesnt make it faster just cause it revs hiugher, and a D17 could rev to 9k if built right...
Old Jan 4, 2004
  #39
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
The reason they rev to 8500 is because they make no torque. With that same equation above, you can see that. If they only revved to 7000 RPM the motor would only make 160 hp. And how much torque do they have?
Old Jan 4, 2004
  #40
C2i0v0i1C's Avatar
SuperMODrizd
and what would u do about the ECU?
Old Jan 4, 2004
  #41
Jodster's Avatar
Post Whore General
^^^^^^Send it to Hondata? Don't know.
Old Jan 4, 2004
  #42
civic01vtec's Avatar
only about 140 ft/lbs i belive
Old Jan 4, 2004
  #43
opto_isolator's Avatar
Actually, with the way things are going Hondata might actually make an upgrade for our car.....they may see that there is really a market for our engine.
Old Jan 4, 2004
  #44
god i hope so
Old Jan 4, 2004
  #45
C2i0v0i1C's Avatar
SuperMODrizd
Originally posted by civic01vtec
god i hope so
would be nice for 2 reasons, no fuel cut, no rev limiter, other than that, thats all im looking for, since when has hondata said they were even working on us, bc last email from them there was nothing in the near future
Old Jan 4, 2004
  #46
civicmorph's Avatar
civicmorph is an unknown quantity at this point
thnx civic01vtec for the info on whp and hp...I'm a percentage smarter now ... so one question...what whp does our stock engine actually put out?
Old Jan 4, 2004
  #47
a EX.....prolly around 110-115
Old Jan 4, 2004
  #48
ELaudio's Avatar
ELaudio is an unknown quantity at this point
Stock Civic EX puts out 127hp (at the crank, not the wheels). This translates to around 105 to 110 whp, depending on who you ask. In other words, your transmission, CV joints and accessories rob about 15-20 hp.
I think the Civic LX puts out 115hp at the crankshaft (correct me if I'm wrong).
With that said and based on what I've read here, boosting a D17 is a far more cost-effective way to get power. That is over swapping a K20. The K20 out of the Type-S RSX does produce 200hp, but only in a very narrow band. Plus the engine has very poor torque figures. Well, more than the stock Civic engine, but poor in comparison to a D17 running even modest boost.
I'm still debating whether or not to boost my car or sell it and get something faster... Probably make up my mind once it gets warmer up here.
Old Jan 4, 2004
  #49
Originally posted by MadWheel
What clutch you going with? That's my next mod so I'm curious to see what people bought. Im thinkin of the centerforce dual friction clutch with the ACT pro-lite flywheel setup. Any other decent setups that's cost effective?
i am looking at the ACT Extreme Performance Stage 1 kit with the Prolite XACT flywheel (8.2 lbs).
I dont' know what the difference b/n the stage 1 and stage 2 kit. They both can handle 270 ft/lbs.
Old Jan 4, 2004
  #50
Catalyst's Avatar
I am making a flywheel. It should be available after we get done with testing.
Old Jan 4, 2004
  #51
Jaykuai's Avatar
ish...
though
Old Jan 6, 2004
  #52
civicmorph's Avatar
nice nice thnx guys, wow I needa boost
Old Jan 6, 2004
  #53
MadWheel's Avatar
Yeah Mike S told me today that I need a clutch that holds at least 250 ft/lbs of torque or it's a waste... I may have to go with a stronger act setup. either way i'm def gettin the prolite
Old Jan 7, 2004
  #54
detoX's Avatar
detoX is an unknown quantity at this point
when will the flywheel be available? and how much would it cost?
Old Jan 7, 2004
  #55
Green Civic's Avatar
Cat, do you know the weight and pressure the clutch and flywheel will hold?
Old Jan 7, 2004
  #56
i say get the DHracing clutch..... nice quality, and cheap ($130 if you mention code #TS101)....
Old Jan 7, 2004
  #57
Civic Type S's Avatar
Civic Type S is an unknown quantity at this point
the clutch is that cheap huh, tell me more about it?
Old Jan 7, 2004
  #58
more info on clutch see thread in otherparts and products, or get me on AIm.... speed13racing.... use code #TS101 to order and get a deal from Josh...
Old Jan 8, 2004
  #59
showoner's Avatar
showoner is an unknown quantity at this point
Now thats a salesman !
Old Jan 9, 2004
  #60
wenlyone's Avatar
wenlyone is an unknown quantity at this point
post some dyno charts
