Doing an engine swap, and having a small question.
Old Dec 27, 2003
sexcivic2k1's Avatar
Question Doing an engine swap, and having a small question.
Ok, so I am taking out my stock D17a2 out of my 2001 civic ex, I can't seem to figure out how you take out the steering mechanism. if you are not sure of what I am speaking of, its the thing that makes the wheels turn. I'm kinda stumped, so I turn to you guys! Thanks
Old Dec 28, 2003
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
why are you tryin to take out your steering mechanism? You use that with the swap.
Old Dec 28, 2003
i found the name for it, CV Axle. I need to remove it to get the engine out. I think i found out how to do it, I will work on it when i get to my friends garage. thanks Justin (anotherslo1.)
Old Dec 28, 2003
Jaykuai's Avatar
ish...
you are swapping another D17 or K20/4?
Old Dec 28, 2003
k24 =X
Old Dec 28, 2003
Jaykuai's Avatar
ish...
let me know everything!!!!
Old Dec 28, 2003
ImPulse's Avatar
u are going to use turbo on it? or what?
Old Dec 28, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
TO GET THE AXLeS out the tranny unbolt the rotor from the struts and use a flat head screw driver and just pull them out. they're not held in by anything.. they just slide in...
PS U DONT USE THEM TO STEER... u USE THEM TO go.
Old Dec 29, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
hahahahahahahahahaha
sorry. I know something you guys dont.
Old Dec 29, 2003
shhhhhhhhhh cat
Old Dec 29, 2003
the 27mm bolt? i cant seem to get that **** off, it turns with the wheel, and i cant get it loose. i tried taking the whole control arm out and pushing it out like that, that didn't work. anymore ideas ?
Old Dec 29, 2003
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
loosen the bolt when the wheels are on the ground...you can get more leverage. the axle spins with the tranny thats why its moving while you are trying to spin it off.
OR
impact gun
Old Dec 29, 2003
thanks dober, im going to try that.
Old Jan 7, 2004
aight got it out. new engine is in
Old Jan 7, 2004
Your Parts Guy
WTF no pics?
Old Jan 7, 2004
not done.
Old Jan 7, 2004
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
i smelll boost coming on...............................
Old Jan 7, 2004
C2i0v0i1C's Avatar
SuperMODrizd
are u done yet, he already had a boosted d17, and i know its another d17 bc u told me u had one in the back of a truck ready to go in, unless u got something else since i last talked to u
Old Jan 7, 2004
Jodster's Avatar
Post Whore General
Busted?? LOL
Old Jan 8, 2004
blue03civic's Avatar
Pro Skater
haha so wat engine is it???
Old Jan 8, 2004
djmota's Avatar
whats up with the old one? blown or are you just adding a built D
Old Jan 8, 2004
andyman97's Avatar
Turbo Guru
An easy way to get that nut off is to stick a screwdriver into the caliper from the outside. When you put force on it, it keeps the rotor from spinning.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Tedverseti
Apr 23, 2020 01:45 PM
cloudguy
Apr 28, 2015 05:02 AM
bsmiley
Apr 27, 2015 01:27 PM
shawe90
Apr 14, 2015 07:10 PM
