custom pipes for the turbo
Old Jan 7, 2004
Jonauto's Avatar
Jonauto is an unknown quantity at this point
i plan to get a sf turbo in a few months but right now im doing the exhaust. I am getting a TCS muffler with custom pipes and no cat (i live in a state where noone gives a f*ck about emissions). What size pipes should i get to be best for the turbo and should i go for the LX or EX header size?
Old Jan 7, 2004
C2i0v0i1C's Avatar
SuperMODrizd
wait just wait, i have a 2.5 inch, if ur trying to match that up to a stock header, its going to sound like someone stuck a behive in the exhuast, plus ull then have to change the flange to fit a downpipe
Old Jan 7, 2004
Jonauto's Avatar
so what do u think i should do?
Old Jan 7, 2004
C2i0v0i1C's Avatar
SuperMODrizd
well if ur trying to make a ex header fit and have no CEL ull have to do some repositioning of the 02's, uh most places wont remove the stock lx cat in the first place, bc they can get fined, by the epa people, as for what u should do, how long til u get turbo, few being 2 or 5+, if its 2 just wait
Old Jan 7, 2004
Jonauto's Avatar
doesnt the sf turbo kit for the lx go where the cat is?
Old Jan 7, 2004
C2i0v0i1C's Avatar
SuperMODrizd
this is correct, but if u get a exhaust now ur going to have to re do it a little bit in order to fit right
you want a exhaust right now
if u put a turbo application type exhaust on ur small pipe NA car, it will sound like the buzzzzzzzzzzzing bees
Old Jan 7, 2004
C2i0v0i1C's Avatar
SuperMODrizd
im not one to do thing twice anymore, ive gone through that stage, so i suck it up and do it all together so i dont have to mess with multiple trips to places to get it right
Old Jan 8, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
our downpipe fits to the stock exhaust, and bolts to the stock flange.
Old Jan 8, 2004
C2i0v0i1C's Avatar
SuperMODrizd
to me that doesnt make sense as to WHY, i mean lets try to squeeze alot of air through that tiny hole
Old Jan 8, 2004
ohmysac's Avatar
ohmysac is an unknown quantity at this point
i'd go ahead and get the exhaust done...do u have a lx or ex? if you have an lx any shop would be able to make you a nice 2.5 inch exhaust setup without touching the cat...then just order the sf kit for the lx...catalyst has been using his kit with no cat for awhile and no cel's (from what i know, cat?..)
Old Jan 8, 2004
andyman97's Avatar
Turbo Guru
I run a test pipe as well and I've never had a cel (except for when it's too rich) due to the exhaust.
As soon as I leaned it out a little with the wideband, cel went away.
Old Jan 8, 2004
Jonauto's Avatar
is there anyway to get a bigger flange on the turbo so u dont have to squeeze all the air throught the tiny hole??
Old Jan 8, 2004
andyman97's Avatar
Turbo Guru
What tiny hole? You have to remember, you are replacing the entire exhaust system, totally. You're running a different manifold, a turbo and a new downpipe. If you upgrade exhaust, you can use a flange that fits your stock downpipe with whatever opening you want.
Old Jan 9, 2004
Catalyst's Avatar
The end of the downpipe is not the stock size. It will seal into the stock exhaust, but is not the little 1 7/8" pipe. It just hooks to the stock exhaust LOCATION. So all cat backs and what not will still work, and you dont have to have any custom work done.
HondaGuy7
Feb 22, 2016 01:00 PM
Cam Diaz
Sep 29, 2015 07:17 PM
carid
Sep 28, 2015 10:13 AM
General DIY
Sep 25, 2015 08:02 PM
Jrosa
Sep 14, 2015 08:24 PM
