best turbo kit availavble
Old Dec 17, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
which is the best turbo setup and why?
I would like to see the similarites and differences
between Stafford Fabrications, Turbo Discounters extreme kit
and the 3rd company that just came out with the funky
manifold.
who outperforms the other?
Those of you with turbo's, have you upgraded your intake
manifold with the KMS manifold and have you installed a
block guard to lower the pistons compression?
I search but find no answers...hopefully some of you
experts can help me out.
Old Dec 17, 2003
HondaLuver's Avatar
Its a celebration bitches!
the best turbo out there is a T88
Old Dec 17, 2003
Green Civic's Avatar
Isnt that a huge turbo?
Old Dec 17, 2003
kjgracing's Avatar
what are the similarities and differences...are you seririous?
Old Dec 17, 2003
iamboo's Avatar
Retired - SoCal FI Mod
this is getting OT already...
http://www.7thgencivic.com/forums/sh...hreadid=101556
i don't think anyone has any REAL numbers for that new hp kit, i'm guessing that it's no where near the hp numbers that they provide on their ebay auctions cause that's just freakin' rediculous... 185whp at only 5 psi on a stock engine and no fuel supplement... very skeptical if you ask me... the only way we can finally prove once and for all which kit is the best is if we had a dyno shootout between all the kits all at the same place and the same time which won't happen considering some of these manufacturers aren't all based in the same state.... that would be kinda cool if all the companies did come out to the same dyno to do a dyno shootout...
Old Dec 17, 2003
C2i0v0i1C's Avatar
SuperMODrizd
Re: best turbo kit availavble
manifold.
well SF has the equal length manifold A+
TD...i have no idea about....riceburnr
the HP turbo...well it has good numbers at 5 psi, the next dyno attempt will be at 10 so lets see what that does
ALSO, a BLOCKGUARD DOES NOT LOWER COMPRESSION
pistons arent compression either, the sizing of them and the dish size is a component of getting to the compression ratio
blockguard and pistons dont interact, the block guard reinforces the cylinder wall
Old Dec 17, 2003
C2i0v0i1C's Avatar
SuperMODrizd
oooooooo sounds fun
also the dynos are up for DIRK21 with the HP kit
Old Dec 17, 2003
civic01vtec's Avatar
this thread is just gonna be a flaming contest since one person has the TD kit and Dirk21 has the other kit while everyone else has SF.
Old Dec 17, 2003
HondaLuver's Avatar
let the flameing begin
Old Dec 17, 2003
sweet, hondaluver is a tool !!!
haha, j/p
Old Dec 17, 2003
iamboo's Avatar
there are a lot of biased people here for that reason... me being one of them but there is no real way of proving these number unless you're there to see the dyno or get it on video... sf has dyno'd the EX with the same turbo kit at the same boost setting as the LX and the end result was that they both put out very similar numbers.... if your kit really pulled 185whp at 5psi... congrats and i'm sorry if i sounded like i'm hating but my reason for being skeptical is that sf made only 166 at 5.5psi.... i forgot to keep in mind that he was using the stock LX exhaust when running this dyno.... i'm sure with the bigger exhaust, he could put out just as much hp as the hp kit...
Old Dec 17, 2003
iamboo's Avatar
this isn't the so cal forum...
try to keep it serious here... consider this a warning bro... i wanna stay on topic with this thread....
Old Dec 17, 2003
alright, i am bias to the SF kit, for obvious reasons, but
SF kit has.......
equal length mani as upgrade
track proven, dyno proven and customer proven results
customer care is excellent but many ppl are waiting on their parts for a long time
kits take awhile to be made since they are custom
small company which cares about the ppl and posts here regularly
the kit that dirk21 has
proven dyno results at 5psi
warranty
u have to relocate the battery
they are working with hondata to make a chip
no fuel system.......injects alot of alcohol
anybody else, chime in
Old Dec 17, 2003
HondaLuver's Avatar
sorry for kidding around... but i personally want a k20a with a cybernation stage 3 turbo kit...
Old Dec 17, 2003
Name:	changing subject.gif
Old Dec 17, 2003
haha........j/p again Hondaluver
but does anybody know anything about the TD kit, cuz i don't
Old Dec 17, 2003
kjgracing's Avatar
it would nice to see dyno sheets next to each other and the 1/4 mile times
that both the turbos produce.
SF is the most popular and I definately would get the water alcahol injection,
but is there a gauge to let you know that your are running low?
I wouldn't want to run out and have the boost a at 8psi and run into detonation.
Old Dec 17, 2003
dont' quote me on this, cuz i have not installed it yet, but.......
there is no gauge to tell u it is low. U set it at what psi it injects at......so, lets say u are running at 8 psi and u set it to inject at 6psi then it will. You can use ur windshield washer bottle for the alcohol, so u can just regularly check that.
Old Dec 17, 2003
kjgracing's Avatar
How much W/A does it use..would it need to be filled every tank full of gas
or every 100 miles?
Old Dec 17, 2003
it depends on what psi u set it at to spray and how much u are at that psi.........if u have it set to inject at 6 psi and u are just cruising around town and then u wont' use it that much.
Old Dec 17, 2003
C2i0v0i1C's Avatar
SuperMODrizd
im sorry but ur thought cannot be completed as stated
boosted and i have kits made from scratch
Old Dec 17, 2003
ok.......i'm wrong there
but, he wanted to compare the 3 manufactured kits
Unless u want to make one and sell it to him
Old Dec 17, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
too bad theres 4
Old Dec 17, 2003
yeah yeah, the max rev kit, but again, he didnt' ask opinions on that kit
Old Dec 17, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
manifold.
yea cause hes a moron who didnt search and doesnt know that there is a Forth.
Old Dec 17, 2003
true, but dont' flame me for that......i was just giving opinions on what he asked.
Old Dec 17, 2003
kjgracing's Avatar
Re: Re: best turbo kit availavble
how do you search for homemade crap?
I only knew of the 3 turbo kits available.
Old Dec 17, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
no maxrev makes a kit..
Old Dec 17, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
i think the reason the HP kit is making 185hp at 5psi, is that it is using alcohol injection from the start that could be the factor making it a bit better a 5 psi, unlike SF's kit where when you reach a certain psi (5-6 psi i think) thenk it uses the alcohol inyection, the HP kit has tu refill with methanol twice per tank of gas, while the SF kit does not
Old Dec 17, 2003
^^^ ur kinda right there sir.....but u set at what psi the alcohol injects.....and remember, not everybody has W/A injection
and yes, the hp kit has no fuel system.......it relies on alcohol injection to compensate for the lack of fuel.
HondaGuy7
Feb 22, 2016 01:00 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
beanhead
Sep 24, 2015 12:04 PM
