SF Fuel SYS. W/O Turbo ?
Not really - the "fuel system" which he uses references boost, which means it increases fuel pressure upon boost. So essentially it won't do anything but make noise (if the pump runs) - your fuel pressure would remain the same.
I personally don't think it will hurt anything to install the fuel system early.....You might run a tad rich if it increases fuel pressure by 5 PSI without running your turbo. I live in Orlando (when I'm there, since I travel for work).....Plan on being back next week!!
i dont know what hooking it up entails but try it, running rich really wont do anything, its running lean that can cause probs, running rich means alot of fuel, sometimes at idle it could stall, just sitting there letting fuel build up and then pressing the accelerator all of a sudden
GritzNGravy
Aug 19, 2015 03:03 AM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
