Doing a K20A Type-R swap
Old Oct 22, 2003
Bigmac's Avatar
Bigmac is an unknown quantity at this point
I just found myself someone selling a K20A (the type R one) for 5500$ CANADIAN (not US$) or a K20A2 (type S) for 4000$ CAN
the problem is: I DON'T HAVE THAT MUCH MONEY!!! i have arround 2000$ but i want one of these engines...
i wanna ask you swappers : what did you do to get enought money to do the swap???
i though about selling my ol' 2001 D17A2 (vtec) but how much it goes for? it has 43000 Km (which is arround 28-29k miles)
anyways, i need you guys' advises so i can get enough money to finance my swap, i have arround 2gs...
THX!
Old Oct 22, 2003
nme3's Avatar
JDM wannabe
my advice... GET A JOB!!!!
naw im just playin, but if your going to be struggling just to afford the engine itself, maybe you should rethink your budgeting plans. dont forget all the other extra fees as well such as instalation, labour, etc.
Old Oct 22, 2003
Bigmac's Avatar
problem is, i'll have a extra 3000$ in about a month and a half...but i think the guy won't keep it aside for me...
oh well, i guess i'll just pass on that one...
but can i go get a loan at the bank? will they loan to me since im a student with a part time job? and as for my D17...how much it goes for?
Old Oct 22, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
There will be other engines. Its not worth it to run yourself broke over it. Just wait until you have more than enough to cover the whole swap and then some (**** always comes up and you need extra stuff).
BTW D-series engines are worthless. Don't plan on getting any major funding from the sale of it.
Old Oct 22, 2003
civicvtec1ps's Avatar
Search and Learn
yea your stock motor is useless. cant even sell them for $500.
just get motor when you know you have enough money
Parts needed for K series motor swap installation for 2001+ civic coupe and sedan
- K20A2 or K20A3 (from Civic Si) Engine With:
- AC compressor
- alternator
- P/S pump or idler pulley (from Civic Si)
- wiring harness
- exhaust manifold and catalytic converter
- ECU
- Transmission and starter
- intermediate shaft
- Axles from either 02 Civic Si or 94 up Integra GSR (we used 02 RSX with RSX knuckles and hubs)
- RSX or 02 Civic Si subframe
- Hasport ESK1 bolt in mount kit (as of this time the kit will not work with the K24)
- Hasport ESKWH conversion wiring harness
- RSX shifter assembly and cables
- 02 Civic Si radiator and fans (although the RSX will fit with some trimming around the radiator cap opening in the grill)
- 02 Civic Si upper and lower radiator hoses (RSX are longer and may kink)
- RSX throttle cable
- RSX fuel line, brake booster line and purge line
- RSX AC line from compressor to condensor
- RSX clutch lines from the master cylinder to the slave cylinder
- Custom AC line from compressor to evaporator (Hasport should have one available by April)
- 90 Accord negative battery cable
- If you want powersteering:
- RSX high pressure powersteering hose and return line
- 92 Civic P/S resevoir w/ bracket and a section of hydraulic hose to go from the pump to the resevoir
Old Oct 22, 2003
Huh_Oh Sh*t!'s Avatar
Huh_Oh Sh*t! is an unknown quantity at this point
three words that wont put u in debt.... save save save....
Old Oct 22, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yep ... it's gonna be HELLA expensive ...
much more than $5000 ...
unless u get lucky enough to find a front clip
Old Oct 22, 2003
Bigmac's Avatar
what's a front clip?
yea, i guess i'll have no choice but wait until i get more than enough...
Old Oct 22, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
front clip is basically the whole front end of the car itself ... haha
Old Oct 23, 2003
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
yeah therell be other engines the price is only goin to get cheaper
Old Oct 23, 2003
Bigmac's Avatar
man, that's not a bad idea...
i'll have a RSX front 7thgen civic...i'll look into it
Old Oct 23, 2003
HondaLuver's Avatar
Its a celebration bitches!
u could sell your car, then you would have enought money for the swap
Old Oct 26, 2003
Alex1's Avatar
sell half ur liver and ur left kidney!
Old Nov 14, 2003
joedc5's Avatar
joedc5 is an unknown quantity at this point
My swap ran into a total of ulmost $18,000. i bought the entire front clip and the motor is a pain in the ***. There is a lot more to do than just dropping this motor in. Take it from me I did the swap and it ain't easy. But it's worth it because this motor is primed for a turbo!
Old Nov 14, 2003
Jodster's Avatar
Post Whore General
^^^^^^Bullsheit. Now way it cost $18K to do the swap. Hell with that much you could have swapped in a fu(kin NSX motor and made your civic RWD. And if you paid that much for your swap you are a stupid *** motherfu(ker. You could have bought a used RSX type S for $1K more.
Old Nov 14, 2003
NytRyder2k2's Avatar
Bay Area
18,000? Man you could have sold your civic and just got an STI. Why would you pay 18 grand! MAN!!!
Bigmac, you can always donate some sperm
Old Nov 15, 2003
joedc5's Avatar
well the total was suppose to be around 3,000. I paid 12,00 for the whole front clip plus shipping from japan another 1,500. Luckly I sold the whole front of the car. Lights, dash, shifter, hood, bumper, fenders etc.. So I paid about 5,000 total for the motor and had everything i needed. But I ran into nothing but problems. 1. Had to get a new ecu with an immobilizer key because US testers can't read JDM ECUS so I had to buy a rsx ecu with key and cylinder and transponder so everything matched from a junk yard $600 plus the type S computer needed to be sent to hondata to upgrade to the JDM itr program and the ECU had also had hardware mods. The Vtech pressure switch had to be removed from the ECU because JDM engines don't have it. If I leave the hardware there for the Vtech pressure then I get a check engine light which leads to having the ECU in limp mode and car runs like crap. $1000 for ECU upgrade and hardware mods. Then I had to send the wiring harness from an RSX type S and 01 Civic to be rewired so the RSX harness works with civic multiplex system. Also the vtech pressure switch connector was removed from the harness. $299
The JDM Harness will not reach because it's right hand drive. Hasport mounts were also needed. $600. Okay so everything was cool there
but the real problems hit with suspension issuses. The motor is simply too heavy for this car. The whole right side was basically on the ground. I had to update to Koni Shocks $750 for all four then I needed coil overs to compensate for the motor being heavy on the right side.
Skunk2 Coil overs $450. An eibach Camber kit is needed. $247
As you can see I did not know this was going to be this much because the swap was not as straight forward as I thought it was. But once I scraped the old motor there is no turning back. So you can't just stop and sell the thing. Besides I had a custom paint job, Kenwood Nav, Screen, Ps2, Alpine full sound system, rims, tires, Body kit, wing, lights blue and white leather custom interior.....etc.......... The list goes on. I started building this car and got attached to it so I am willing to do anything for it to keep it moving strong. But hey it's fun and I just wanted to do something different instead of being the average joe with just a body kit, wing, rims and that piece of crap 1.7 SOHC tinker toy that honda calls a motor! I wanted all show and let's go. Every car in my area looks nice but if you open the hood it's nothing special. But I give props to people who even think of doing this swap... Aways keep moding!! Joe
Old Nov 15, 2003
Jodster's Avatar
Post Whore General
FYI Koni struts are not designed for Skunk2 coilovers. So don't be suprised a little ways down the road when the perches on the Konis bust.
Old Nov 15, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
do like me wait a few years and the k20 prices will go down supply and demand by 2008 there will be plenty more k20's around so many people will want the k24 and not buy the k20 when i make my move and buy a k20 for cheap
and btw VTECH is PHONE hondas have VTEC
Old Nov 15, 2003
pitciv's Avatar
pitciv is an unknown quantity at this point
oh man i know how that goes...something similar happened with my system...but that doesn't really compare to your problem
but who cares what they say? your cars better than most RSX's out there!
Old Nov 15, 2003
eddie5spdx's Avatar
eddie5spdx is an unknown quantity at this point
this kinda scares me on getting an engine swap
Old Nov 16, 2003
joedc5's Avatar
Hey thanks for the compliment. And your right I can my ride is really fast and I can't wait to have my turbo done. I will keep everyone posted. Look for more pics soon
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
juicetayne
Sep 30, 2015 11:02 AM
C-Hamm
Sep 28, 2015 10:31 PM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
