sf turbo question
Old Apr 12, 2004
  #31
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Originally posted by OsOBooSTeD
btw.. where are u getting the methanol?
At the drag strip. It is $5 a gallon here.
Old Apr 12, 2004
  #32
OsOBooSTeD's Avatar
OsOBaNNeD
damn you!
Old Apr 12, 2004
  #33
guns's Avatar
Skyline R33
damn you!
Old Apr 13, 2004
  #34
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
so what about 50/50 water and methanol? would that be the best of both worlds?
also, where can methanol be picked up locally?
Old Apr 13, 2004
  #35
guns's Avatar
Skyline R33
You can find Methanol Fuel at most dragstrips and race tracks. Should run $3-$5 a gallon.
Like I said and have dyno proof. Run 100% pure methanol. It burns colder and has higher octane.
Pm Catalyst he is running pure methanol now.
"Torque King" was running 14psi on stock internals w/ 100% methanol and never had any problems.
When running alch and water I blew my head gasket. When I switched to methanol I gained alot of HP which is always good.
So try what you want, its your car.
Old Apr 13, 2004
  #36
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
If you have time some day, Maybe after running your car hard, take a temp. reading off your exhaust manifold for me.. I'd like to see what kinda temps your putting out.
~nick~
Old Apr 13, 2004
  #37
guns's Avatar
Skyline R33
~nick~
I need an EGT gauge. Thats my next project. Well one of my many next projects.
I think you are asking about the exhaust gas temp right? Lean causes the High temps. I am still too rich. But your right about checking the EGT.
Old Apr 13, 2004
  #38
Yeah.. I'm curious what it would come out at.. Maybe run your car hard on meth. and check it, then run it hard on 50/50 alc/h20 and check and get the differences. I'm sure if the meth. is cooler lots of people would like to know.. me included.
~nick~
Old Apr 13, 2004
  #39
guns's Avatar
Skyline R33
I dont like the alch. But I will try a 50/50 mix and a pure mix once I get the EGT hooked up. I will go on ebay and see if I find a cheap one. If I forget remind me again in a couple of weeks for updates.
Old Apr 13, 2004
  #40
You got it. Also, if you dont want to buy one, call around.. some shops rent them out or will let you use them. Try the place where you got yoru dyno, I'm sure they have one there.
~nick~
Old Apr 13, 2004
  #41
guns's Avatar
Skyline R33
~nick~
I will pick one up on ebay. I need one anyway. More acurate than my narrow band a/f.
Old Apr 14, 2004
  #42
Mex's Avatar
Mex
hey, is this the same as methanol?
http://www.misterart.com/store/view....1542&store=001
if so, I could run it at 100%? (though i'm also waiting to see the results on adding water to the mix)
Old Apr 14, 2004
  #43
guns's Avatar
Skyline R33
Dude what are you thinking? Methanol is methanol, not anything else. I wouldn't experiment with your car like that. If I do run water it will be at 8psi. Above that I will only run pure meth. Like I said I blew my headgasket running it with water. it ran lean. lean is bad.
Old Apr 14, 2004
  #44
Mex's Avatar
Mex
thanks for clearing that up-- I read this post and figured I needed a second opinion.
either way, I think I'll just order online from here, 5 gallons for $50, or maybe I'll do the monthly deal for like 3 months and stock up for $42/month. There's no place locally where I can find a better deal-- or just anty deal period.
also, some FAQ from Aquamist:
What is the maximum alcohol/ water ratio I should use?
No more than 50%, otherwise you will increase the cylinder temperature rather than reducing it. Beyond that ratio, onset of detonation is more likely. Methanol freezes at -96 deg. C, 50% mixture will stop the mixture from freezing at around -40 deg.C.
I plan to go no higher than 8-9psi in my auto, so I will probably do the half n half meth & water.
Old Apr 14, 2004
  #45
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
just dump antifreeze in your gas tank!
-HondaFTW-
Aug 30, 2015 10:38 AM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bhollie
Aug 12, 2015 09:58 PM
justcruzin125
Aug 11, 2015 09:09 PM
