sf turbo question
Old Oct 1, 2003
BREEZE's Avatar
Yeah, i drive an EP
BREEZE is an unknown quantity at this point
Question sf turbo question
so do u have to get bigger injectors before u install this turbo kit?
basiclly what else do u need to buy that isnt included in what u get from stafford
Old Oct 1, 2003
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
everything is included in the kit, it uses stock injectors
Old Oct 1, 2003
BREEZE's Avatar
Yeah, i drive an EP
so straight out of the box what is the max psi u can run with out hurting your car?
Old Oct 2, 2003
BREEZE's Avatar
Yeah, i drive an EP
cant anyone answer this
Old Oct 2, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
6lbs psi is safe
http://members.aol.com/kylepa2b/car/
Old Oct 2, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
if you get the alcohol injection ($100 upgrade) you can run as high as 11 psi.
Old Oct 2, 2003
BREEZE's Avatar
Yeah, i drive an EP
so how does the alcohol injection make u be able to run higher psi.. i thought it had to do with the pistons and stuff.????
Old Oct 2, 2003
tdiddy's Avatar
tdiddy is an unknown quantity at this point
Read the first topic in the forced induction forums
Old Oct 2, 2003
C2i0v0i1C's Avatar
SuperMODrizd
i think it makes temperatures inside cooler
Old Oct 2, 2003
Catalyst's Avatar
and it raises the octane rating of your gas. The higher the octane, the more boost you can run.
Think of alcohol as a really cold 156 octane gas.........
Old Oct 2, 2003
BREEZE's Avatar
Yeah, i drive an EP
hey mike what are all the add ons that u can get for your kit?
Old Oct 2, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
dude You gotta search and read like everyone else.. the answers have been covered... otherwise PM catalyst.
Old Oct 3, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
yeah bro/./.. search.. all you will need for install is time, tools, breather filter, and youre done... MONEY... get the kit, SOOOOO worth it...
Old Apr 9, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I'm wondering-- does this mean I can continue to fill up with 87 octane with water/alcohol injection? i was gonna run 93 octane until i was certain the alcohol injection was working OK, then go back to 87 (if it really is the same as using 120+ octane gas). i recall reading somewhere that running too high of an octane is bad? any clarification is appreciated, thanks
Old Apr 9, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
I would never run 87 I don't care what else I'm dumping in. The SF alcohol injection kit does not ensure that the alcohol is evenly distributed into each of the cylinders. Basically I'm saying that relying on the alcohol injection is not safe.
Old Apr 9, 2004
Havok2k1's Avatar
Wicked Pissah Admin
I would avoid running 87 unless you feel like paying for a new headgasket (detonation)... Even factory FI cars always recommend the top octane available to you....
And higher octane will hurt nothing whatsoever...
Old Apr 9, 2004
ramster's Avatar
ramster is an unknown quantity at this point
MORE OCTANE MORE PSI!!!?!?!?!? so if you raise your octane like 98 you can run what, 10 psi safe!!!!?!? i dont get tha sory somebody can explain!!??
Old Apr 9, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Higher octane burns less rapidly. Its used on hgh compression or F.I. applications. The lower the octane the faster it burns...but the likelihood of detonation increases (under heavier loads of high comp. or boost, etc).
In other words though....a really high octane wouldn't be beneficial to an n/a car for which a regular octane rating is recommended. You might actually lose power.
Old Apr 9, 2004
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
Octane is like this: The higher it is, the colder it burns. the colder your engine is running, the harder you can push it (more boost) Alcohol injection sprays a 50/50 mix of water and alcohol into your engine, the alcohol is bunred off and the water is ejected through the exhaust as steam taking the heat from your engine with it (making it run cooler so you can boost higher)
~nick~
Old Apr 12, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
I spray 100% methanol. My car runs lean w/ alch&water. It made alot of diff when I switch to methanol. I might do a dyno run on pure methanol and compare. From my butt dyno it feels like at least 15-20hp difference.
Old Apr 12, 2004
Thats probably not the best idea.. seeings how the water is used to cool the engine. The methanol might make more power but it wont get rid of heat like the water will. Hopefully you wont roach your motor.
~nick~
Old Apr 12, 2004
Mex's Avatar
Mex
is running pure methanol the same as running 100% alcohol?
Old Apr 12, 2004
C2i0v0i1C's Avatar
SuperMODrizd
i dont even know where to begin with that statement............
Old Apr 12, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Old Apr 12, 2004
guns's Avatar
Skyline R33
well running lean caused me not to build power after 5,000rpm. So once the methanol richens the mixture and cools the intake charge it should run alot better. Like I said I will dyno. I posted a before and I might do an after today or tommorrow.
Old Apr 12, 2004
guns's Avatar
Skyline R33
I read this post and it pissed me off. So I went to the local mustang shop and strapped her down to the dyno. What do you know I gained huge hp from 100% Methanol and a little tunning at 10psi. Still very rich and could get maybe another 10hp with more tunning. The mustang shop knows nothing about VAFC-2 and niether do I. We just played with the fuel a little. Check out the results. I think my butt dyno is off about 20hp. The date is today at around 4pm. So dont try and say it is not my car.
Old Apr 12, 2004
Thats cool and all.. but that does not have the cooling ability of the water mix because the water takes the heat out of the engine through the exhaust. So dont be suprised if you try to crank up the boost and it doesnt work out that great.
~nick~
Old Apr 12, 2004
guns's Avatar
Skyline R33
Before methanol. Injecting alch and water.
At 10psi:
Old Apr 12, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
btw.. where are u getting the methanol?
Old Apr 12, 2004
guns's Avatar
Skyline R33
~nick~
Have you ever felt pure methanol. It feels cold and burns slow at 158 octane. I run lean w/out it. Water does not add the fuel we need after 5,000 rpm under 10psi of boost. I need more tunning and you will see 235hp at 10psi.
