structural strengthening for turbo?
Old Sep 8, 2003
AznPhoenix's Avatar
AznPhoenix is an unknown quantity at this point
1- If you were to add a turbo and ur total hp turned out to be bout 280-300, or maybe even alittle more, would u need to reinforce the chasis to make up for the massive hp added?
2- What engine parts do you need to upgrade as well when getting a turbo kit. Ex. Pistons?
Old Sep 8, 2003
EnProceso's Avatar
1. you need new axels for sure, coilovers would probably be a good idea and i'm sure there are a couple other things that you may ned but i doubt your chasis "would twist coming off the line from all the torque", lol
2.rods, pistons, valve guides/springs, sleeve your block and gasket, with all that and more fuel you could run high boost all day long.
Old Sep 8, 2003
Snoop88's Avatar
Snoop88 is an unknown quantity at this point
how much would all that run you, the rods, pistons, etc.
Old Sep 8, 2003
EnProceso's Avatar
a lot of $$$, lol i dunno, thought i read that someone got pistons for 550 somewhere,think they were JE
Old Sep 9, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
look at it this way, is upwards of $1000 to sleeve the block (good for 700+ whp), then about $600 for pistons, then another $600 for rods. Then you are looking at $300 for valve springs and retainers to handle that amount of power.
Old Sep 9, 2003
EnProceso's Avatar
.n/m
Old Sep 9, 2003
C2i0v0i1C's Avatar
SuperMODrizd
i got the JE for 550
Old Sep 9, 2003
andyman97's Avatar
Turbo Guru
You can get sleeves installed for around 800, check out golden eagle. Keep in mind that with sleeves you won't need a block guard. Pistons and rods should be around 600 a set, 1200 total. Suspension isn't necessarry but it will make for massive handling imporvements. Strut and sway bars are definitely a good idea because torques steer is pretty heavy with boost.
Old Sep 10, 2003
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
Who sleeves blocks?? I didnt know sleeves were out for our engine? Or am I missing the point 100%?
~nick~
Old Sep 10, 2003
andyman97's Avatar
Turbo Guru
Their site doesn't advertise....probably because noone has sent them a d17 yet, but I'm sure golden eagle can do it for around 800.
Old Sep 11, 2003
Got Boost???'s Avatar
gasket,
didn't you know all the 9 seconds run on the stock paper gasket ?
Old Sep 11, 2003
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
true.i asked two tuners here and they say they prefer using honda oem one.
Old Sep 11, 2003
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
why would you want to do that?
Old Sep 11, 2003
andyman97's Avatar
Turbo Guru
It's a strong gasket but it is still the weakest link. The beauty of it is when the headgasket goes, you know before you destroy something else.
For example on mine and catalyst's cars. We both overheated and blew headgaskets. If we'd had stronger headgaskets or ones that wouldn't blow, we could've both done some serious damage. Oh, btw, catalyst has decided against using his copper gasket and is going with oem honda aftter all.
Also, a friend of mine here in colorado built a 12 second, at 6k ft, no less, hatch that is n/a. No nitrous or boost of any kind, it's all motor. He originally recommended that I use oem gaskets also.
Old Sep 11, 2003
How do you know when you blow a head gasket?
Old Sep 11, 2003
andyman97's Avatar
Turbo Guru
You loose coolant and the car overheats before you detonate to the point of throwing a rod or breaking a piston.
Old Sep 11, 2003
oh ok, i guess thats alot better than throwing a rod or breakin a piston.
Old Sep 11, 2003
andyman97's Avatar
Turbo Guru
Not only that but pulling the head is much easier than pulling the whole block if you do internal damage, not to mention much cheaper.
Old Sep 11, 2003
how much are stock head gaskets?
Old Sep 11, 2003
andyman97's Avatar
Turbo Guru
I paid 29 bucks for mine along with 40 bucks to have the head resurfaced, cleaned and inspected.
Old Sep 11, 2003
Wow, that is pretty cheap. Thanks for all the help !
Old Sep 11, 2003
CIVIC808's Avatar
was it that bad that you had to resurface the head?
i think i caused more damage cause i keep filling it up with coolant and water everyday.at that time i didnt know what was causing it and no one here had that happen to them.
Old Sep 11, 2003
andyman97's Avatar
Turbo Guru
Well, what happens is, when the engine gets hot and your temp gauge rises, the heat from the cylinders has to go somewhere. When your headgasket is blown, coolant leaks into the cylinders through the leak in the seal of the headgasket. If the car is heating up, even if only for 30 seconds, it can and usually does warp the head because it's trying to push the heat out through the exhaust but the coolant isn't cooling correctly and there isn't a seal in the spot where the gasket is ripped so it pushes the heat out through the leak in the seal when no more coolant is available to circulate.
Old Sep 14, 2003
in other words you WILL know when you blow a head gasket, its not one of those things you can drive around and then stumble upon when your checking your coolantor oil and say "Well hows about that the head gasket blew maybe i should order a new on"
Old Sep 14, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
wtf is coolantor oil ? bhahahhahahahahahah
im guessin u mean coolant or oil ? hahaha well coolant ull know cause the car will over heat...
and oil , well.. if u have a turbo u SHOULD have an oil pressure gauge IMO
Old Nov 22, 2003
ballajack11's Avatar
ballajack11 is an unknown quantity at this point
Sorry if this ain't related to the post, but say I don't wanna go turbo but still wanna re-enforce my engine parts, pistons..etc, will that gimme a performance gain? This might sound like a silly comparison, but a friend of mine drove a subaru RS 2.5, its a non turbo for those that dunno, yet he forged his engine parts and is making 400whp.
Could someone explain me how this could be possible? Thanx.
Old Nov 22, 2003
C2i0v0i1C's Avatar
SuperMODrizd
he had to do somethign else, higher compression maybe for NA, if it were turbo he could have got low compression pistons and upped the boost, other than that i think u have a "fibber" on ur hands
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
