Turbo Calc
Old Aug 16, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
Smile Turbo Calc
Dunno if this is a repost or not or if anyone could use this but I just wanted to share...
Turbo Calc
Old Aug 16, 2003
iamboo's Avatar
Retired - SoCal FI Mod
argh... too lazy to fill in the numbers.. they're probably inacurate anyways..
Old Aug 16, 2003
RoBBUsaF's Avatar
ya... figured ppl might want it though...
Old Aug 17, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
FOR 8 PSI @ 7000RPM
Bore: 75mm (2.95")
Stroke: 94.4mm (3.72")
Cylinders: 4
RPM: 7000
Ambient Air Temp: 25C (Room Temperature)
Engine VE: 85%
Boost: 8 psi
Compressor Efficiency: 70% for mine T3/T04B (you have to check the compressor maps)
Intercooler Efficiency: 75% (less for tube and fin style IC's)
RESULTS:
CID: 101 in^3 (correct)
N/A CFM: 175 (correct... I got 175-200)
Air Temp Before IC: 71C (159F)
Air Temp Drop: 25 Celcius Degrees (35 Farenheit Degrees)
Air Temp After IC: 46C (114.8F)
Turbocharged CFM: 245 (correct)
Air LB/min: 17 (correct)
FI BHP: 189 BHP (close)
FI Tq: 142 ft-lb (way off)
Old Aug 17, 2003
iamboo's Avatar
the numbers you put out of the caluculation are only as good as the numbers you put into the calculation.... thats why i said earlier that it would probably be very inaccurate...
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
