What gauges are recomended for sf kit ?
Old Aug 11, 2003
UnOrthodox9546's Avatar
UnOrthodox9546 is an unknown quantity at this point
Hi, i just paid for my sf kit and the alchohol injection tonight and i want to have everything here by the time the kit arives, so i was wondering what gauges should i get ? Also are there any electronics like a boost controller or anything you guys would recomend?
Old Aug 11, 2003
andyman97's Avatar
Turbo Guru
Gauges:
I have Exhaust Gas Temperature (Pyrometer), Oil Pressure, Air/Fuel, Fuel Pressure
I also picked up a turbo timer and an electronic boost controller. None of this is necessarry but it could make the difference between blowing the motor.
Old Aug 11, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
you DEFINETELY need a boost gauge... NOTHING more important than that... even with a boost controller you need one IMO... i also have air/fuel, turbo timer, and i might get a few more, but when i set it up i know i will do right, so thats enough for now... spend the other money on the clutch you will need.. just put in my ACT 6 puck today with the 11lb flywheel...... yup yup.. oh yeah.. and i got racing tranny fluid.. a MUST... feels SOOOO much better
Old Aug 11, 2003
OK, THANKS FOR THE HELP !
Old Aug 11, 2003
ALSO, IS THERE ANYTHING ELSE I NEED TO BUY TO INSTALL THE KIT LIKE DIFFERENT FILTERS MAYBE OR ANYTHING? i WANT EVERYTHING READY FOR IT!
Old Aug 11, 2003
opto_isolator's Avatar
HOW ABOUT A CAPS LOCK KEY FOR THE KEYBOARD?
Old Aug 11, 2003
andyman97's Avatar
Turbo Guru
Old Aug 12, 2003
you will need a oil pan gasket... dont think they include that... caont thiknk of anything else... oh yeah.. oil...LMAO... and filter (change at time of install to 5w-30 instead of 20... thicker oil, youre voiding warranty anyways...).. dont know what else off the top of my head.. time, patience... hmmmm
Old Aug 12, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
y would u need an oil pan gasket? if the orginal one isnt bad .. whywould u need to waste money.. im not tryin to flame .. im being serious.
Old Aug 12, 2003
Maverick's Avatar
Maverick is an unknown quantity at this point
you don't need a gasket...because you don't have one...honda uses a liquid gasket...when i put mine back on, i just slathered some good old hondabond back on the pan after peeling the old off. have fun
Old Aug 12, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
exactly...
Old Aug 12, 2003
EnProceso's Avatar
dont wanna start a new thread but wheres a good place to get a boost gauge? i was thinking of putting a boost gauge on the dash, and a a/f, oil temp, tranny temp on a A-pillar gauge cluster. anyone know a spot where i can find all these?
Old Aug 12, 2003
andyman97's Avatar
Turbo Guru
I got alot of my gauges from summit.
The a/f gauges are very inaccurate, however if you go to gadgetseller, you can find ones that are modified to be much more accurate than one you can buy anywhere else. They can also modify gauges you already have for you. They're a great shop.
Old Aug 12, 2003
RoBBUsaF's Avatar
gauges
this is where i put mine:
Old Aug 12, 2003
EnProceso's Avatar
Re: gauges
word! thats the set i'm going for, where did you get the a-pillar gauge cluster and gauges?
what do they monitor?
Old Aug 12, 2003
RoBBUsaF's Avatar
got it at ptuning or tornactive... boost guage, a/f, and oil temp... all of that costs around 200
Old Aug 12, 2003
EnProceso's Avatar
whats th difference between "full sweep electrial" and "mechanical"? elerticals are like $200+ while mechanics are around $60+. they're more accurate?
Old Aug 12, 2003
RoBBUsaF's Avatar
yea. use mechanical.
Old Aug 12, 2003
andyman97's Avatar
Turbo Guru
Your gauges are electronic in your car. The difference is...an electronic oil gauge uses wiring to detect oil pressure whereas mechanical actually routes oil directly to the gauge. I say go electrical.
Old Aug 12, 2003
RoBBUsaF's Avatar
well then go mechanical as far as the boost gauge is concerned... that's what i thought he was saying.
Old Aug 12, 2003
EnProceso's Avatar
so for boost use mehanical, and for the rest like a/f, oil temp, etc... use electrial?
Old Aug 13, 2003
Maverick's Avatar
summitracing.com and ebay are the cheapest places to get guages...summit sells them for only 5% over cost. my third choice is optauto.com
Old Aug 13, 2003
RobearRacing's Avatar
RobearRacing is an unknown quantity at this point
We have the FULL LINE of Autometer in stock.
Call us if you do not see it on the website. We most likely have it
Old Aug 13, 2003
andyman97's Avatar
Turbo Guru
Now he posts this
Damn Rob, wish I had known, ah well.
Old Aug 14, 2003
DIMO's Avatar
DIMO is an unknown quantity at this point
Boost, EGT, and fuel pressure gauges are the most important gauges I'd say. And you would probably want to get something like the VAFC-II for tuning.
Old Aug 14, 2003
I got my gauges off ebay brand new for around $50-$60 each.
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
