andyman (SF) vs. zinkyroo (maxrev)
Old Aug 25, 2003
  #211
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Voltage Clamp
Name:	voltage clamp.jpg
Old Aug 25, 2003
  #212
Boosted2k2's Avatar
VTEC
Old Aug 25, 2003
  #213
Boosted2k2's Avatar
Controlling Main Injectors
Old Aug 25, 2003
  #214
Boosted2k2's Avatar
I'm not posting all the maps... but you get the general idea. It's 500rpm increment from factory, but you can change the increments as long as you stay 16x16
Old Aug 25, 2003
  #215
wenlyone's Avatar
wenlyone is an unknown quantity at this point
Originally posted by Catalyst
Andyman is actually a really competent person. And he has no problem asking questions when he doesnt know what something is. I am sure that now that he knows what all goes where on the turbo kit, he could take it off and put it back on all within a couple hours.
The place he gets his (awesome) attitude from is the group of street racers he hangs out with. By going to colorado and meeting him and his friends, we got to go to the street races out there and just hang out (since the colorado street races are more like a car show, since nobody races).
But now andy does have the car to back up his talk. If andy doesnt use ice in the intercooler, and doesnt use the alcohol injection, his car will actually be slower than our base kit. Believe me, i have had all the kits on my car. Without ice in the intercooler, and without the alcohol injection, Andy's car is still fast.
It all depends on how you define fast.
Old Aug 25, 2003
  #216
wenlyone's Avatar
Originally posted by andyman97
Ok, doesn't make sense to me but what I want to know is how, with such big injectors, you'll be able to idle smoothly when you aren't able to dial down fuel pressure. I mean, do you understand how this is going to work? Do yourself a favor and research it if you don't understand it.
fuel pressure + injector open duration = fuel delivered.
as long as e-manage can dial down the paulse of the injectors enough to compensate for the higher pressure, the little extra pressure doesn't matter.
the whole point of having a injector control unit is so no mechanical units have to be used. i.e. fmu, fpr..
mechanical controls will fail easier than electrical controls, that is the main reason why it is best to go that route if you want your car to be daily driven.
Old Aug 25, 2003
  #217
andyman97's Avatar
Turbo Guru
The whole fuel system doesn't make sense to me.....maybe n318z was using the safc instead of the safc II like I have. I know with the safc injector pulse can only be changed every 500rpm but on the safc II it is every 200 rpm. As far as at idle, I had to pull out 50% of my fuel from such high fuel pressure.....so the safc II would work fine with bigger injectors.
As far as defining fast....at 6k ft, low 14's, high 13's for a daily driver is fast in my book.
Old Aug 25, 2003
  #218
Boosted2k2's Avatar
agreed
Old Aug 25, 2003
  #219
wenlyone's Avatar
As for tuning points, 200/500/1000 doesn't make that much of a difference if all you want is for your car to run right. Even though for the 1000 rpm models, you can only set a value at every 1000 rpm, the normalized in between values should be enough; unless your compression varies too much from cylinder to clinder. If that is the case, you should rebuild anyhow. 1000 rpm models are nice, because it is really easy for a beginner to hit the right spot, and it will also cut the dyno time more than half.
I think at 6k ft, with basic boost, you won't make 13. If you get below 15, you are a very good driver.
Old Aug 26, 2003
  #220
andyman97's Avatar
Turbo Guru
Well, I've beaten a wrx badly that ran a 14.5. I pulled about a buslength on him by 80mph.
Old Aug 26, 2003
  #221
blue03civic's Avatar
Pro Skater
nice
Old Aug 26, 2003
  #222
wenlyone's Avatar
you beat a wrx without your turbo? hum...
Old Aug 26, 2003
  #223
andyman97's Avatar
Turbo Guru
No, it was the same night I finished the install. I was boosting 8 psi.
Old Aug 26, 2003
  #224
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
That is not true. My computer fails more than all of my cars combined (3 vettes, 1 truck, 1 RX8, 1 4-runner, 1 civic)
As long as it is used in the manner it was made for, the mechanical unit should last forever.
Old Aug 26, 2003
  #225
XxJDMCivicxX's Avatar
You have an rx8? Turbo that biatch!!! Just work on the 7th gen so we can know what to do and what not do , since you have so many vettes wanna lend me one till i get a sf kit .
Old Aug 27, 2003
  #226
wenlyone's Avatar
all of your car's ecu failed more than once? since there is no moving parts in an ecu, the chances of failing is as slim as to none unless it was bad to begin with. just as any computers you buy, none moving parts usually never goes bad. check any shops, it is almost impossible to find any cars sent there with ecu problems (but yet audi has a shitty electrical system. not ecu, just high current wire routing without proper flux handlilng). but if you scan down all the lifts, they all have mechincal problems. mechanical have moving parts which equals to wear and tear, no questions about it. epecially with extra stress made by constant suddent changes. fpr loves to fail due to the constant sudden change in pressure with that little outlet valve. that is the one single reason why people go larger injectors with controls route. most people who has been boosting for more than 5 years on a single car can share that experiecne with you. leaks and blow outs are very common. and the worst thing is, it is fuel related. that is why in the old times before programmable ecu's are designed for many cars, there were many more fires on the drag strips.
mechanical won't last forever, not even close.
Old Aug 27, 2003
  #227
Catalyst's Avatar
I am talking about computers in general. This computer that i am typing on has failed me more than any of my cars. I know about computers, i started out as a programming major. But i enjoy chemistry much more so now i am a chemical Engineering major.
We have been turbocharging cars for more than 7 years now, and many of our original cars are running today. The most common thing that has failed in the past 7 years is the fuel pump, and EVERY car has a fuel pump. And that is pretty much the only moving part that is on our fuel system. We dont have a common FPR, it is a little different than the ones you guys are used to. So the only wear and tear that our kit has, is the fuel pump, which will probably still outlast the stock fuel pump. And it is all under warrantee.
And as for wear and tear in general, your entire engine is composed of moving parts. Rubbing, sliding, and brushing one another. And it still runs after 270,000 miles, at least, that is how many i had on my crx, and 55,000 of them were turbo miles on 15 psi daily (all stock internals).
Old Aug 27, 2003
  #228
wenlyone's Avatar
what kind of fpr does your kit include. it doesn't work off a pressure operated valve? can you give me more details? so far, only your kit look the most promising, please provide more details about this. please let me know when you hit 12's. we really need something that will put the new civic into 12's.
Old Aug 27, 2003
  #229
Catalyst's Avatar
well, i cant really give out the details, because it is this fuel system that makes our's superior.
Dont worry about the 12's, i should have my car back together by this weekend (Dave is finishing my head by Thurs. Night), so i should have a run by the following weekend.
And like my 13.6 run, it will probably be posted on this site before i ever leave the track
Still kinda wondering how that happened.
Old Aug 27, 2003
  #230
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
i call cat hittin a 12.6 still .. thats my call with the new parts... come on cat, prove me right bro... I KNOW YOU CAN DO IT!.... oh btw.. im calling that based on 12-13psi... and better hook ups.. also the ported head wont hurt any... LOL.. probly gonna give you like 30more whp DAVE IS THE MAN!!!!!
Old Aug 27, 2003
  #231
sc1golfr's Avatar
sc1golfr is an unknown quantity at this point
better yet, prove futurersxswap wrong and go for like a 12.3!!!
Old Aug 27, 2003
  #232
sc1golfr's Avatar
but anyways, is this race between andyman and zinkyroo ever gonna happen? im anxious to see the results
Old Aug 27, 2003
  #233
SFpower's Avatar
Former Sponsor
SFpower is an unknown quantity at this point
we are going to try to run low 13's on Mike's car on 6 psi. Then see what it does at 10 and 11
Old Aug 27, 2003
  #234
MadWheel's Avatar
Premium Boosted Member
that would be a good comparison.
Old Aug 28, 2003
  #235
andyman97's Avatar
Turbo Guru
I plan to be at IDRC on september 7th. I just dono if zinky's car is going to be done by then or not
Old Aug 29, 2003
  #236
azure's Avatar
Originally posted by sc1golfr
. . . im anxious to see the results
Same here.
Old Aug 30, 2003
  #237
Project2k2's Avatar
To all you people in this damn thread that need to get over themselves.
Old Aug 31, 2003
  #238
detoX's Avatar
detoX is an unknown quantity at this point
i hate that pic ^.
isnt zinkyroo's car not finished yet???! whats the deal? did it even fit? hows the car andyman? you have the air/water intercooler w/ alcohol injection ryt? have you tried it on long drives? anyproblems?
Old Sep 1, 2003
  #239
andyman97's Avatar
Turbo Guru
No, zinky is still getting d*cked around by maxrev....if you check "mikeatmaxrev" for his member status, you'll see he's no longer a gold vendor and he hasn't been back to the site since the end of july.
Project2k2, you're a dumbf*ck so stfu, k.
Old Sep 1, 2003
  #240
detoX's Avatar
that sucks, but its his fault..you all warned him but neooooooo...
