andyman (SF) vs. zinkyroo (maxrev)
#121
Rep Power: 0 i wonder after the both manufacturer read this post, will they fine tune their setup for these 2 ppl than a normal package just so they can say I beat so-and-so's setup.
#122
Rep Power: 0 Originally posted by andyman97
Ok, well, be sure to let me know when you get it on, k.
#123
Yes, try reading the whole thread. The maxrev kit sucks so I sent it back which they don't ant to accept because they know it won't ever sell. So I ordered an SF kit with some other goodies.
#124
Turbo Guru
Rep Power: 326 Turbo has arrived. It is in the process of being installed. Will be done tomorrow. I will post pics of the setup and possibly a pic of my timeslip after going to the track tomorrow
#125
Rep Power: 0 Originally posted by Diemos
Honestly, I dont know what this arguement is about? Which guy spent his 3000 dollars the best? It seems a bit childish if you ask me. Although, I am interested in seeing the results between the kits. But truth be told, I would like to see someone elses experiance with the SF kit, and because of Catalysts 13 second run, I will be purchasing this kit in the future.
#126
#127
Turbo Guru
Rep Power: 326 A turbo isn't like an engine, it doesn't need to be broken in. The only thing it needs to do is get seated correctly before it's ran hard and that only takes about 30 miles. There's a whole nother thread on this.
#128
Rep Power: 289 Anyways, i just drove andyman's car after my 14 hour drive up here and my 6.5 hour install, and it feels sweet. Here, let me post some pictures.....
#133
Turbo Guru
Rep Power: 326 Yeah, for everyone who doesn't think I'll be able to break into 13's, your all probably right, yeah, right on the money lease:
Anyways, iamboo, you may not have to hack up your viper with the air to air ic either. I don't know if it's the same on your's but I have about a 3" clearance b/w the bumper and a/c condensor. The air to air from SF is only about 3" thick so if you do have that much clearance, it'll be a perfect fit
I have to give mad props to Catalyst and SFPower. These guys are awesome and they definitely know their stuff. I would definitely recommend this kit over anything else on the market, trust me, you won't get the quality nor the support that these guys will give you, they are both truly amazing. Thanks a million guys
#135
Turbo Guru
Rep Power: 326 Originally posted by Big Baller L
so is the race gonna be held or what? I wanna know the results. Didnt the other guy get a sf kit also? whats going on?
#140
cool beans
Rep Power: 0 Is this even going to be a fair race to begin with???I thought it was base kit vs base kit...Not upgraded kit vs base kit. I'll still race, but its not going to be fair at all. I know andy will run ice in his intercooler, which I have no problem with, but I have an air-air intercooler so right there he has a big advantage...and then alcohol injection????Do I have alcohol injection??? No. Ill still race, but i already know that I will probably lose...
#144
Rep Power: 389 Originally posted by zinkyroo
#145
Rep Power: 0 Originally posted by KD5FTN
Childish? How so? If I lay $3,000 on a kit, I definatly want to make sure I get the best I can. It only makes sense to do a product comparision....
#146
Rep Power: 0 Originally posted by FlyRiceRacer02
It was only a matter of time before you tried back out. Dont worry, we all know that you were thinking that SF is better deep down inside.
#147
it's like running a N/A k20 against a N/A d17, its just not fair.
#148
Rep Power: 389 Originally posted by Diemos
If we are going to compare kits we should compare base kit vs base kit otherwise the entire competition was pointless and proved that a Upgraded kit can beat a Base kit. If SF is truely that superior he wouldnt be needing to use all the upgraded parts.
The SF is superior because it has the ability of being upgraded.
This entire competition is pointless anyways because the SF kit owns all. We are now up to 2 people so far who haven't been able to fit the maxrev kit into their engine bays. I doubt zinkyroo will be able to even install his kit.
#149
Screw that. A race is a race and whoever wins has the better setup and better driver. If he is willing to spend more to get the best performance out of his kit, then more power to him.
#150
Turbo Guru
Rep Power: 326 Originally posted by FlyRiceRacer02
Anywho, I wasn't planning on running with ice, I was going to use roome temp ice and boost at whatever psi he wants to boost at. And no, I won't use alcohol injection. I don't even need it until I'm at around 9 lbs. If he wants to run at 7 lbs, that's fine with me, I am not going to use ice in the intercooler. This is not a slow kit, you saw catalyst ran a 13.6 on 9 lbs with a fmic.
