LED's In vents
Old Aug 23, 2004
redspeed03's Avatar
redspeed03 is an unknown quantity at this point
Thumbs up LED's In vents
What is the best way to hook up Led's in the vents, I know how to pop everything off, the problem just is how to mount them. If anyone knows what im talking about let me know what the best way is.
Thanks,
Old Aug 24, 2004
I'll give you some pointers at the meet. I've never done it, but you probably want to aim them up so they don't shine in your eyes. And put them kinda low. That way it glows without you seeing the led.
Old Aug 24, 2004
slappyhoohah's Avatar
the leds i had in mine were red and you could hardly see anything but then i got some neons and it worked awesome, just something to think about
Old Aug 24, 2004
HomerSimpson's Avatar
SlappyHooHah is right, I tried some LED's myself and you could barely see anything. I still havent gotten around to buying neon tubes but they seem like the logical way to go. Try and find the small 3" tubes, I think they would work best.
Old Aug 24, 2004
Diver's Avatar
Diver is on a distinguished road
ok if you go with neon, better for tubes or flex wires?
Old Aug 24, 2004
I want to say tube would be brighter, but I think the flex wires would be easier to work with as far as vents go
Old Aug 24, 2004
Nitto's Avatar
gone
Nitto will become famous soon enough
neons... ;/
Old Aug 25, 2004
Diver's Avatar
why the ;/ ?
Old Aug 25, 2004
amhtown01's Avatar
it means he's not a neon fan.
Old Aug 25, 2004
redspeed03's Avatar
what is the best way to wire these led's, the power from the switch does it have to run to the battery or can it go through any power source?
Old Aug 25, 2004
I would say tap into the 12V power outlet
Old Aug 28, 2004
Cipher's Avatar
Cipher is an unknown quantity at this point
you should wire it to a fuse that doesn't draw out too much power, we did it on a pre-existing fuse for interior neons. my friend did it and he made a custom switch for his LEDs. as for placing them. we used silicone. all you need is just a drop of it. the best part is that if you don't like it, it just peels right off without making any marks in your vents. but make sure to use very small amounts; otherwise it can get kinda messy.
Old Aug 28, 2004
Wolfgang5884's Avatar
hmmmm, can someone post pics. sounds like a good idea. I just want to see what it would look like.
Old Aug 28, 2004
Diver's Avatar
Cipher,
You and your firned have DIY for this?
solarpunk70
Apr 12, 2016 11:43 AM
senicalj4579
Oct 2, 2015 10:03 AM
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
Klame9420
Sep 18, 2015 12:37 PM
