Intake question
Old Jun 14, 2005
7ThGengripRacer's Avatar
7ThGengripRacer is an unknown quantity at this point
Intake question
I have an 05 civic coupe dx and I just installed my aem v2 intake
Everything worked out after we finished but the next night my car started acting up. It wont let me go over 5000 rpm and then it starts to die afterwards. The car runs but there seems to be no power. The check engine light came on and I got it scanned. It said that the barametric pressure was the problem (code p2227) but I dont have any idea what that is. Does any one have any idea what the problem is? Thanks
Old Jun 14, 2005
Kamahls_Civic's Avatar
Kamahls_Civic is an unknown quantity at this point
Did you install it yourself?
If you did make sure you fitted it properly and try to reset the code.
What do you mean it said the "barametric pressure"?
Old Jun 14, 2005
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
try taking a picture of it. then we can see what exactly u did.
Old Jun 14, 2005
claudeboi's Avatar
im a psychopath...what are you looking at?
claudeboi is an unknown quantity at this point
did you put back the o2 sensors in?
Old Jun 14, 2005
tuner04civic's Avatar
spell check pwns you
i would deff check the o2 sensor that sounds like it...also check the fittings make sure no leaks and that nothing at all you touched is loose
Old Jun 14, 2005
Rennen's Avatar
New Mod on the Block
if its somehting major, just throw on your stock intake and take it to honda to get it fixed.
Old Jun 15, 2005
dragoon's Avatar
that's not an O2 sensor. it's a MAF sensor, and shouldn't severly affect the car even if it's out. check to make sure all the pipes are on tight, and try resetting your fuel ECM (pull the fuse in the fuse box for some time)
Old Jun 17, 2005
SpecialEdCivic's Avatar
SpecialEdCivic is an unknown quantity at this point
You have got to be kidding. The MAF will severely mess with your car if it is out.
Old Jun 17, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
Hey buddy... There is air everywhere... when you're moving the air is also moving. Thus making the sensor work.
Although it may cause the car to act sluggish when not installed. check to see if this is unplugged first.
carid
Nov 7, 2015 01:46 AM
Farticle69
Aug 6, 2015 08:02 PM
spyder13
Jul 31, 2015 06:31 PM
NoobyKid
Jul 13, 2015 07:53 AM
Ccoop87
Jul 9, 2015 03:26 PM
