DIY blackout headlights....
Old Sep 29, 2003
jttegx's Avatar
OMNES AD UNUM
hey everyone,
i seen the blackout headlights for the rsx (DYI) and was wondering if they had the same for the 7th gen civics?
http://forums.clubrsx.com/showthread...threadid=79247
has anyone done this process before or know who has? cause i was thinking about buying some pair of OEM headlamps off eBay and do this procedure. any comments/questions/ideas?
-thanks,
Tommy
Old Sep 29, 2003
GreenNVicious's Avatar
Newbie
yeah we did it at tech day, its hella easy. Andrew and Walter (dizwikedcivic and xxdelerious247xx) are the pro's at it. It's basically like clearing headlights.
Old Sep 29, 2003
Civicster's Avatar
Old Sep 29, 2003
KeNsHiN's Avatar
LEVA
Originally posted by Civicster
wtf?
but yeah it's the samething just your laying out the chrome and painting
Old Sep 29, 2003
aZnVoYCe's Avatar
Yeah, be sure when you paint it. Wait for it until paint completely dry b4 you put it back in. Otherwise... Hahah.
Old Sep 29, 2003
Civicster's Avatar
just post whoring. the pw king is back
Old Sep 29, 2003
Weaponx12o's Avatar
heres mine.. i left the amber piece in.
Old Sep 29, 2003
DizWikedCivic's Avatar
did my also
Old Sep 29, 2003
jttegx's Avatar
OMNES AD UNUM
so u guys juss painted over the chrome? with what paint?
wouldn't it effect ur headlamps eventually if its heated and the paint smears? if its sum good free ****, i wanna get my lamps done =D. what kinda paint u guys used?
Old Sep 29, 2003
Civicster's Avatar
when u blakk out ur headlight guru?
Old Sep 29, 2003
Weaponx12o's Avatar
no the paint is not affected by the heat from the headlight. the "chrome" plastic part is seperate from the actual headlamp assembly. make sure you tape up the reflectors, so the light will still be visible.
i used duplicolor glossy black. it doesnt have to be a high heat paint. just make sure when you do it, you give it plenty of time to dry, or else the fumes from the paint will mess up the outer housing (cover).
Old Sep 29, 2003
Weaponx12o's Avatar
hey andrew, did you paint under the amber piece?
Old Sep 29, 2003
no
Old Sep 30, 2003
jttegx's Avatar
OMNES AD UNUM
awww how come this isnt in the DIY section? only clearing out but no blackout
Old Sep 30, 2003
speedracersong's Avatar
try to keep the pwing to a min.
or im going to have a regulate if not another mod
Old Sep 30, 2003
Civicster's Avatar
can i be mod. i promise to not abuse my power like flyricer.
Old Sep 30, 2003
Weaponx12o's Avatar
doesnt need to be.. its the same procedure, only difference is you're painting after you take off the amber piece
Old Sep 30, 2003
Civicly02's Avatar
here is mine if anyone cares. We did it on tech day here in southern kali
Ziggy1999
Oct 15, 2015 07:56 PM
General DIY
Sep 25, 2015 08:02 PM
meicalnissyen
Sep 25, 2015 12:12 AM
speedlever
Sep 24, 2015 07:18 PM
