SOCAL's Official Whoring Thread!
Re: CA Unofficial Whoring Thread!
anyone know anything about wiring??
if i have both red (bigger prong) and black wires on a speaker, and i have a colorful wire and a tan/green wire via the harness which ones do i hook what up to?
red means + and black means -. just look up the diy on the head unit and it'l show you which wires to hook up.
should I wire the red speaker line (bigger prone) to my colorful/blue/yellow wire and the black to the single colored tan or green ( im colorblind) wire?
my driver side has a black/blue and a white/blue wire, should i do black on black and white on red?
thanks
thanks
dorcas this is for you
http://cgi.ebay.com/ebaymotors/Cars-...1%7C240%3A1318
edit this is a better start for you
and its still a 7thgen
dorcas get this car. its almost the same price as the odessey regis is trying to get you to buy.
http://orangecounty.craigslist.org/ctd/994165396.html
except with this car, you can smoke both kenn and regis..
this one's nice if you want something more stock
http://orangecounty.craigslist.org/cto/980240590.html
here's the wiring schematics taken from the diy sub forum.
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|black/red |+ |ignition harness |
| SECOND ACCESSORY|white/red |+ |ignition harness |
| POWER LOCK|white/blue |- |gray plug above drivers kick|
| POWER UNLOCK|white/green |- |gray plug above drivers kick|
| LOCK MOTOR|yellow/black | |back of the fusebox *3 |
| UNLOCK MOTOR|yellow/green | |back of the fusebox *3 |
| DISARM DEFEAT|yellow | |back of the fusebox *3 |
| PARKING LIGHTS +|red/black | |back of the fusebox |
| PARKING LIGHTS -|blue | |factory alarm plug *1 |
| HEADLIGHTS|blue/red |- |headlight switch |
| DOOR TRIGGER|*2 |- |factory alarm plug *1 |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|red |- |factory alarm plug *1 |
| TACHOMETER|blue | |test connector *4 |
| SPEED SENSE|white/green | |PCM *5 |
| BRAKE WIRE|white/black |+ |brake pedal switch |
| HORN TRIGGER|orange |- |steering column |
| WIPERS|blue (L), blu/yel(H)|- |steering column |
| LF WINDOW UP/DN|red/blk - red/yel |A |drivers window switch |
| RF WINDOW UP/DN|blu/red - blu/wht |A |drivers kick panel |
| LR WINDOW UP/DN|brn/wht - brown |A |drivers kick panel |
| RR WINDOW UP/DN|blu/org - brn/yel |A |drivers kick panel |
| RADIO 12V|white/red |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| POWER ANTENNA| | | |
| LF SPEAKER|grn/blk - lt green | |radio |
| RF SPEAKER|grn/yel - gry/red | |radio |
| LR SPEAKER|blu/wht - blu/blk | |radio |
| RR SPEAKER|pink - blu/yel | |radio |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555I or 555U. *1 The factory alarm plug is a green plug above the drivers kick panel. *2 The drivers door trigger is green, front passenger door trigger is lt. green/red, and the rear door trigger is green/white. *3 In the top left plug. *4 It is a 2 pin plug to the passenger side of the battery. *5 The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column.
Notes:
https://www.civicforums.com/forums/2...it-wiring.html
i dont mind just using the spliced wires electrically taped to the prongs for the time being. in the future when i get some cash i'll get it completely redone professionally.
in other related - does anyones car ever shock them when they get out of the car and close the door?
electrical tape is meant for tempory use.
this is what i meant by posi locks.
http://www.posi-lock.com/posilock.html
i love these things. its secure and reusable and you don't have to crimp
nah the yellow ones are more versatile. you can buy them at walmart or home depot.
but i would just use the connectors i gave you since there free. the posi locks are for the future when you want to do some wiring without heat shrinking
