head unit wiring?
Old Dec 26, 2008
pward426's Avatar
pward426 is an unknown quantity at this point
head unit wiring?
i am installing my new head unit, but the only problem is that i don't know exactly what wires and colors go where. (the wires given are not the same color). i am assuming that the ones in the car now that are taped together in pairs are the speakers but i am unsure of which ones they go to (LF, LR,RF,RR)
does anyone know which ones go where or have a schematic or something.
i have an 05 civic lx se.
thanks.
Old Dec 26, 2008
silvercivic203's Avatar
New Member
silvercivic203 is an unknown quantity at this point
Re: head unit wiring?
i would say for ya is to get you a Hanes manual. It has everything about that car you would ever need including schematics about the whole car. Try your luck with that.
Old Dec 26, 2008
twitchit's Avatar
twitchit is an unknown quantity at this point
GET A WIRING HARNESS!...don't even bother trying to do it without a wiring harness...seriously
Old Dec 26, 2008
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
X2 so you wont have to cut anymore of the factory harness
Old Dec 26, 2008
manahoonie's Avatar
X3 Life will be so much easier then!
Old Dec 26, 2008
pward426's Avatar
haha that would have helped me. i ended up finding something online that said what all of the wires were. so the head unit works, but now the but my ipod adapter that hooks into the back doesnt really respond. it will show that its playing but there is no sound. is it because its going into the xm adapter which then goes to the head unit?
Old Dec 26, 2008
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|black/red |+ |ignition harness |
| SECOND ACCESSORY|white/red |+ |ignition harness |
| POWER LOCK|white/blue |- |gray plug above drivers kick|
| POWER UNLOCK|white/green |- |gray plug above drivers kick|
| LOCK MOTOR|yellow/black | |back of the fusebox *3 |
| UNLOCK MOTOR|yellow/green | |back of the fusebox *3 |
| DISARM DEFEAT|yellow | |back of the fusebox *3 |
| PARKING LIGHTS +|red/black | |back of the fusebox |
| PARKING LIGHTS -|blue | |factory alarm plug *1 |
| HEADLIGHTS|blue/red |- |headlight switch |
| DOOR TRIGGER|*2 |- |factory alarm plug *1 |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|red |- |factory alarm plug *1 |
| TACHOMETER|blue | |test connector *4 |
| SPEED SENSE|white/green | |PCM *5 |
| BRAKE WIRE|white/black |+ |brake pedal switch |
| HORN TRIGGER|orange |- |steering column |
| WIPERS|blue (L), blu/yel(H)|- |steering column |
| LF WINDOW UP/DN|red/blk - red/yel |A |drivers window switch |
| RF WINDOW UP/DN|blu/red - blu/wht |A |drivers kick panel |
| LR WINDOW UP/DN|brn/wht - brown |A |drivers kick panel |
| RR WINDOW UP/DN|blu/org - brn/yel |A |drivers kick panel |
| RADIO 12V|white/red |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| POWER ANTENNA| | | |
| LF SPEAKER|grn/blk - lt green | |radio |
| RF SPEAKER|grn/yel - gry/red | |radio |
| LR SPEAKER|blu/wht - blu/blk | |radio |
| RR SPEAKER|pink - blu/yel | |radio |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555I or 555U. *1 The factory alarm plug is a green plug above the drivers kick panel. *2 The drivers door trigger is green, front passenger door trigger is lt. green/red, and the rear door trigger is green/white. *3 In the top left plug. *4 It is a 2 pin plug to the passenger side of the battery. *5 The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column.
Old Dec 26, 2008
You have to be more specific about what your doing if you want a better answer. Just saying your ipod doesn't work doesn't help us help you.
Old Dec 26, 2008
wallydude03's Avatar
wallydude03 will become famous soon enough
What kind of headunit do you have?
Old Dec 27, 2008
pward426's Avatar
yeah ok. i have a JVC KW-AVX710 head unit and i also have the jvc xm direct adapter/reciever. i believe that is supposed to plug into the back of the head unit where an external device would go (cd changer etc.) and on that cord were two things. first, a two wires together which were yellow and black (not thick similar to speaker wire) and there isnt really a spot for me to put it in the back of the head unit. the second, an extra line with a female end like the plug on the head unit and i put the ipod adapter that had the male end of the plug into that. i ran the cable connecting to the ipod through my center console and when i tried to listen to it, there was no sound. i could see that the song was being read in the head unit, as there was a title and song info, but there was not any sound coming out.
is that clear enough?
thanks
here are the links to all of the stuff mentioned above:
head unit
http://www.crutchfield.com/p_105AVX7...kwavx710&tp=75
XM direct2
http://www.crutchfield.com/p_700XMJV...Kit.html?tp=87
Ipod adapter
http://www.crutchfield.com/p_257KSPD...00.html?tp=120
4 banger
Jun 5, 2015 01:44 AM
mugenca
Apr 16, 2015 12:15 AM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
