Need serious help on a sub box!!!!!
Old Aug 23, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
i bought a 10" kappa perfect VQ infinity sub.
this is the top of the line sub from infinity. 20 lbs, 6.5" mounting depth
im lookin for .5 ft3 volume box.
ppl say .5 ft3 volume box is too small for this sub and will be hard to find one.
well i chose this box cuz it will sound best w/ the music i listen.
i looked looked looked looked online sites, local shops.....NO ONE has 1 for me to mount the sub into.
goodguy agreed to build me a custom box to fit. (will proply cost alot)
SO IM HERE TO ASK FOR HELP FROM S. CALI FORUM! help me build a .5 ft3 volume that can fit a 10" kappa perfect VQ infinity sub
Old Aug 23, 2004
fonto's Avatar
The LA Clipper
That box size is on the small side, and a negative of such a small box will be trying to build one out of wood...you may need to build a fiberglass box OR build a really small box and invert the sub.
Manufactures (sp) purposely reccomend these really small box sizes so that consumers will think that the sub will sound good in a small enclosure that will not take up too much space...in reality the sub would be better suited to a bigger box...Infinty ALWAYS gives recommended box sizes that are to small. I bet a 1 cubic foot box would sound great!!!
Old Aug 23, 2004
yea i looked up all the recommended boxes and sound frequencies and stuff.....
.5 will sound the best for my type of music
Old Aug 23, 2004
fonto's Avatar
The LA Clipper
What type of music is that? Did you try to Model it out in WinISD, or another box building program? Why don't you just use a different Q setting so that you can use a bigger box? ...your prolly wasting your time looking for a .5 cubic foot box.
Old Aug 23, 2004
dru106's Avatar
ThE CoRRupToR
Yea!! Listen to Mike!! He has a sick system!!!
Old Aug 24, 2004
MangoEX's Avatar
Just Be
MangoEX should not be trusted
what size do you reccomend fonto for 2 12" MTX thunder 8000s?
Old Aug 24, 2004
fonto's Avatar
The LA Clipper
I have no idea...I would use the biggest box that the manufacturer recommends, or model it out on WinIsd. ...I have never used MTX subs.
...the reason why I am giving Civicracer my 2 cents for the Perfect is because I have the old Perfect 10's, and I know that the sizes Infinity lists are usually too small, and peaky...plus, you will get a lil more power and bottom end with a slighlty bigger box.
Old Aug 24, 2004
MangoEX's Avatar
Just Be
Thanks, yo.
Old Aug 25, 2004
JDMVTECB20's Avatar
JDMVTECB20 is an unknown quantity at this point
.5^ft for the 10" does sound alittle small, especially if you build it, after displacement if it's .5cube you might be in trouble. If you're doing sealed .75cube after displacement would work fine.
ººIn a nut shell small box=small sound. You'll have decent SQ tho.
1^ft sealed chambers for the 8000s. They're meant for sealed enclosures.
Old Aug 26, 2004
MangoEX's Avatar
Just Be
so i go into a shop and ask for a 1 foot sealed enclosured? and is it better if its divided into two boxes internally??
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
Islesfan
Sep 29, 2015 03:42 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
