what's that noise?
Old Oct 1, 2004
RevHigh's Avatar
RevHigh is an unknown quantity at this point
what's that noise?
here it goes...it only happens every now and then. and it seems like it only happens on trips over 15 minutes long. it's a loud screaching noise that seems to be coming from up front, yet stops when i tap the brakes. wtf is it? it's driving me insane, i was driving home tonight and stomping on my brakes what seemed like every few minutes just to shut it up. any ideas?
Old Oct 1, 2004
FALKEN's Avatar
Civicforums Junkie
how many miles do you have on the brake pads??
Old Oct 1, 2004
RevHigh's Avatar
41,000, but honda says mine look good for "several thousand more miles."
Old Oct 1, 2004
AZNRACR's Avatar
that sounds like the problem I have. But it doesn't do it all the time though. Then, it does stop sometimes when I tap the brakes too. I have close to 40K miles also. If you find out what it is, then let me know. I had to cancel my appt. with honda this week, because of moving.
Old Oct 2, 2004
AZNRACR's Avatar
check out this thread, I think we have the same issue.
http://www.7thgencivic.com/forums/sh...ght=brake+pads
Old Oct 2, 2004
JoeyOKC's Avatar
http://ackakaka.ytmnd.com
JoeyOKC is on a distinguished road
i had the same problem...got my brakes checked and ended up needing new pads.
Old Oct 2, 2004
Rufus's Avatar
Its your scrapers fools. They're just warning you to get new pads before you really are "metal on metal". If you're too cheap, you can bend the scrapers back for a few extra "squeak free" miles
Old Oct 3, 2004
AZNRACR's Avatar
See, I thought they only squeaked(sp) when you press on the brakes. That's why I didn't know.
Old Oct 3, 2004
RBABE's Avatar
The Righteous
RBABE is an unknown quantity at this point
Joey-you know damn well that those, "noises," are just you and I having fun in your vic! C'mon now! Quit playing!
It is more than likely a wear indicator like Dallis was spillin' earlier. Go change your pads.
Old Oct 3, 2004
RevHigh's Avatar
Jodie - i FINALLY got the stains out of the seats too ;-)
But yeah I always figured they were supposed to squeak when I applied the brakes, not the other way around. I'm a dumbass, i'll go change them this week...
Old Oct 4, 2004
RBABE's Avatar
The Righteous
Joey, you are by far my best friend and that by default makes you the exact opposite of a dumbass. Not just because I am hella off the hook and on continuous redial, but, because I don't associate with dummies. Yeah,' they will squeak even when breaks are not at all applied.
Old Oct 4, 2004
topnotch7gen's Avatar
JDM-Jonathan David Martin- I own everybody
topnotch7gen is on a distinguished road
yeah you definitely should change your paddywacks before you start scrapin metal on metal!
Old Oct 7, 2004
AZNRACR's Avatar
Where are the scrapers located? I took my wheels off and can't seem to see any metal parts close to the pad. Can someone take a pic or let me know where they are? thanks
Mike
Old Oct 7, 2004
Rufus's Avatar
They're usually a part of those metal plates that go on the outside of the pad (really thin metal) They're difficult to see.
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
