my 7thgen vs. tC
Old Apr 16, 2006
  #61
carmina_joi's Avatar
carmina_joi is an unknown quantity at this point
Originally Posted by BoostedVik
i like it, the last statement
YEAH, CUZ I'VE BEATEN CARS THAT I MOST DEF. SHOULDNT HAVE BEATEN. BUT I BEAT THEM. SO I'D BE LIE'ING IF I SAID I DIDNT. ANYTHING'S POSSIBLE.
-CARMINA_JOI.
Old Apr 18, 2006
  #62
JesterMasque's Avatar
...ever grinning...
JesterMasque is an unknown quantity at this point
Well let's look at this for a second...
People are swapping the K20 and K24 motors into EVERYTHING including Lotus and a couple other exotic I-4 cars, not to mention every Honda that has even been in production. Bottom line, the K-series motor is the swap of choice right now and for good reason. I haven't heard of anyone swapping out for an 2AZ-FE, have you? Even Nissan for the R35 Skyline is releasing it powered by an turbocharged I-4 that was designed based on the K-series motor.
As it was mentioned a couple times in here, the only motor that could possibly rival the K20/24 is the new Si, but I think it will be at least a year, maybe more until that catches mainstream. Go with the Type-S, the extra 5g's is worth it because you're getting a running start into I-4 performance with an already legendary motor. People even perfer it to the B-series for the most part...
Old Apr 18, 2006
  #63
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
u said something about swaping a 2jz-fe. those are popular swaps into a 240sxs.... the new si i would imagne would be the copy of the k-series engines
Old Apr 19, 2006
  #64
...ever grinning...
That's true, but as far as I know, it's not the most chosen because there are better options out there with the SR20 and the Skyline RB's. People mostly put them in their 240's if they're already built and TT'd, from what I've seen, because it's not a huge leap forward in performance from the stock... And the K-series has been around only as long as the 2JZ but it's already in the hall of fame.
Old Apr 19, 2006
  #65
BoostedVik's Avatar
top ten best engines.....(most swaped engines too)
not in any order
b16a/b18c
k20
sr20det
rb26dett
d16
4g63
ej20
13b-rew
3s-gte
2jz-gte
Old Apr 19, 2006
  #66
S2000man01's Avatar
O RLY
and that's based off of....
Old Apr 20, 2006
  #67
...ever grinning...
I saw that list in one of my Super Street magazines, I have to see if it's the same list though. If it's different I'll post what they said.
Old Apr 20, 2006
  #68
BoostedVik's Avatar
its the same list, i participated in the pole!!!
Old Apr 21, 2006
  #69
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
I had a chance to follow a tC last night and it was auto....
It was slow...I was amazed how I was able to close distance slowly....
I have no doubt that you were able to beat a tC from start....
My first hand experience tells me this....dont listen to others...
Old Apr 22, 2006
  #70
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
dude that thing as more torque than we have hp to the wheels
its a 2.4 liter with 160torque and hp
theres no way he woulda been able to take him from stop, auto or stick. d17 is the worst fukin engine ever made....
Old Apr 22, 2006
  #71
BoostedVik's Avatar
but there is a weight difference, scion tc = 2,970lbs (source, automotive.com) and civic =1,114kg thats about 2500lbs(source, autmotive.com) there is a difference of 470lbs...
Old Apr 22, 2006
  #72
spoonJDMlX's Avatar
weight isnt that much of a factor when theres more than 45+hp/torque in difference
Old Apr 22, 2006
  #73
...ever grinning...
Are you serious? 500lbs is a hell of a lot especially when take in other factors. A standard Civic will absolutely beat an automatic tC because:
a) The tC has a set shift point which as generally before the max shift point of the car
b) The Civic would be able take full advantage of the powerband and shift faster (depending on the driver)
c) The tC motor has an extreme problem of power loss around 5,000 RPM according to almost every major magazine that has test driven and from my own experiences. The tC is really laggy at higher RPMs.
Old Apr 23, 2006
  #74
BoostedVik's Avatar
where did u get 45+hp/torque difference, dont throw number without sources...
Old Apr 23, 2006
  #75
CustomXSpunjah's Avatar
CustomXSpunjah is an unknown quantity at this point
i test drove one before and i thought it was the car but i guess not. The engine really falls off the powerband at higher rpms...its weird.
Old Apr 23, 2006
  #76
drive_fast_dail's Avatar
drive_fast_dail has a little shameless behaviour in the past
Yeah, you really got to take into account that the tC has a camry engine in it when trying to compare it. Sure this engine is meant for a big car so its got some torque, but the tC isnt exactly light. Toyota really didnt design the camry for people who want to go fast, so you really just cant compare hp and torque to a civic.
Old Apr 23, 2006
  #77
spoonJDMlX's Avatar
http://www.internetautoguide.com/car.../tc/index.html
there now shut up and
civic stock 115hp and 0 torque
tc stock....160hp 163torque
now lets do some math
160
-115
= 45!!
gues what i was right, now who looks stupid here, me or you?
Old Apr 24, 2006
  #78
^well thats assuming against a non EX civic. And you were refering to Devani's claim when you said that, and hes got an EX. Plus you gotta remeber the whole thing that started this was guessing at a auto tC vs a manual civic. Then the auto is from the camry, and you are going to loose a lot of power because of that and in addition the engine probably wont want to rev that high. So like say an EX runs 108 hp with a 15% loss, the tC would be running 128 hp with a 20% loss. Then your talking only 20 hp and 400-500 lbs difference. I think if the weight isnt enough the shift time you can get in a manual civic is just worlds better than a toyota auto will do. I mean sure the manual tC is going to beat a civic, because it can deliver the power.
Old Apr 24, 2006
  #79
Devani's Avatar
Not only me but whoever started this thread experienced this too....
Old Apr 24, 2006
  #80
BoostedVik's Avatar
160
-115
= 45!!
u are retarded.... scion makes 160 to the wheels???... that **** makes 160 to the crank and with a economy auto trany makes less to the wheels... more like 125whp....if u didnt know, there are 3 different civic layouts.. dx -107hp, lx-117hp and ex-127hp...WHICH one where u talking about??? i dont have to argue with u.... i know my em2 will beat a manual tc... i beat a few... dont care about the number or shitty driver.... i guess i raced shitty drivers...but dont care.... oh yeah that was before i was boosted... now Fvck them....ur stock , u probably raced them and lost... u probably lost to a manivan
Thank u
Last edited by BoostedVik; Apr 24, 2006 at 11:22 AM. Reason: Automerged Doublepost
Old Apr 24, 2006
  #81
...ever grinning...
Yea, I think that with d_f_d's, Boosted's, and my comments we can discern that a manual transmission Civic (apperantly an EX) can beat an automatic tC. Anymore deliberations?
So if AnaRki's Civic is an EX w/ manual trans, good kill! *thumbs up*
Old Apr 24, 2006
  #82
spoonJDMlX's Avatar
nah the only thing ive raced was some old pos bmw. i dont race ina stock civic, or even if it was fixed. go ask anyone with a modded civic you'll get the same answer......slow (i/h/e)
and if you do the math, lx gets like 90whp......big fukin WOW!!!!!!! d17 crap
Old Apr 25, 2006
  #83
BoostedVik's Avatar
ok... but i got a turbo em2 and not THAT slow
Old Apr 25, 2006
  #84
spoonJDMlX's Avatar
well there you go, your boosting, put it to like 2psi and see how slow it is then
Old Apr 25, 2006
  #85
...ever grinning...
XD
Man, so yea... RSX here I come baby! No more slow D17 for me... I love the body and interior, but hate the mechanics of the 7thgen...
Old Apr 25, 2006
  #86
BoostedVik's Avatar
still faster that urs
Old Apr 25, 2006
  #87
spoonJDMlX's Avatar
should i givea ***? you own a pos honda, why would i care?
is your IQ is as low as your torque?
come talk to me when i have my rsx
Old Apr 25, 2006
  #88
SilverVTEC's Avatar
SilverVTEC is an unknown quantity at this point
well come talk to me when i have my corvette, or better yet my lambo! Dude, who cares what you are GOING to have...all of us on here will most likely get another car sometime, but incase you for got....you are on a site that is for SEVENTH GENERATION CIVICS!!! which is what we have...and is what you have also. so it makes no sense for you to say its a pos honda, seeing as you have one, and the rsx is owned by the same company.
Old Apr 25, 2006
  #89
S2000man01's Avatar
O RLY
wow. grow the hell up, and then you can come back onto this forum.
Cam Diaz
Sep 29, 2015 07:17 PM
jordan1794
Jun 11, 2015 09:14 PM
Wild Cranker
May 19, 2015 06:10 PM
EuroCivic
Apr 2, 2002 11:13 PM
