just got back from the track... *updated
Old Oct 29, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
alright, well ... I'll give everyone a little background first. This was my first time at any track, I left my car full interior .. nothing was taken out ... tire pressure was kept the same as I would run it on the street (roughly 44? psi) ... basically nothing was touched.
elevation was 1100 feet, temperature was ~78 degrees, there was a little bit of wind, the track was at California Speedway in Fontana
Ok, I ran 4 times.
my first run was HORRIBLE ... my shifter popped out of first gear after my launch:
1st run
R/T: .983
60': 3.131
1/8: 10.629
1/4: 15.633
mph: 99.6
2nd run
R/T: .531
60': 2.422
1/8: 9.380
1/4: 14.315
mph: 99.51
3rd run
R/T: .581
60': 2.541
1/8: 9.763
1/4: 14.814
mph: 97.52
final run
R/T: .666
60': 2.400
1/8: 9.393
1/4: 14.362
mph: 99.60
I'm not at all disappointed. I just need to work on my launches. Mods:
K20A
Injen CAI
17x7.5" SSR Comp - 215/40/17 GY Eagle F1 GS-D3 tires
Nextgear Intake Mani Gasket
no p/s
~150 pounds weight reduction
stock everything else.
on my final run, I thought about my dyno numbers ... and how rich I was running after 7500 rpms ... so I decided to shift at 8000 rpms instead of 8500 ... but I think I could've gotten a 14.2 if I had shifted at 8500 ... considering that my 1/4 time compared to my 1/8 increased, comparing my 2nd and 4th run.
Old Oct 29, 2005
mugenman's Avatar
"mmmBAHHHH" - vtec y0
way 2 go. im still workin on breakin outta the 18;s lol
Old Oct 29, 2005
spoonEM's Avatar
omgwtfbbq mod.
damnit derek....you shoulda told me you were going to the track....i would have gone too.
Old Oct 30, 2005
Michalo187's Avatar
Abortion Survivor
Thats freaking good dude 14.3 thats really good. If you can improve your 60 you will be in the 13s next time. Good luck
Old Oct 30, 2005
HondaLuver's Avatar
Its a celebration bitches!
thats good, im telling you, you need better launches.... i'll be there for sure on the 12th...
Old Oct 30, 2005
chrisleecool's Avatar
same here
Old Oct 30, 2005
HondaLuver's Avatar
i posted this in Socal
Old Oct 30, 2005
not bad at all. but that seems a bit high isn't tire pressure supposed to be 30 or something?
Old Oct 30, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hm I read somewhere that as you change the size of your rims (or was it profile?) that tire pressure needs to change accordingly...
I could've sworn the receipt for the tires said ~44 psi ... but I could be wrong. I'm pretty sure the tire pressure is pretty high right now ...
Old Oct 30, 2005
Michalo187's Avatar
Abortion Survivor
yeah that does seem pretty dam high
Old Oct 30, 2005
spoonEM's Avatar
omgwtfbbq mod.
next time ill go and see if my car can even do 18s.
Old Oct 30, 2005
you don't go by the pressure on the tire. you go by whats written on the car. if its a civic ex, then 30psi for 15" rims. yes you do change with the rim size I believe, but I don't know how to figure that out.
Old Oct 30, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
rob: I'm sure you'll do better than 15's ... just take your spare out and take out your power steering pulley for the runs ... it's not like you're gonna be using it when you go straight anyway.
gear: yeah ... I remember something like that ... different pressure for different sized rims ... anyone know what the recommended is for the 215/40/17 ???
Old Oct 30, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
updated 1st post with all info
Old Oct 30, 2005
S2000man01's Avatar
O RLY
i dont think he'll hit 13's with his current setup.
Old Oct 31, 2005
spoonEM's Avatar
omgwtfbbq mod.
i would like to break 15s....im gonna take out my system, spare tire, front seat, rear seats, and whatever else i can to shave some weight.
if i take out the ps pulley, is the tensioner gonna be enough to tighten it? or am i gonna need to get a spare serpentine belt?
Old Oct 31, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^ don't take out the pulley ... just take out the belt. I think it's just like 4 bolts and then you can loosen then tension on the pulley and it'll slip right out.
Old Oct 31, 2005
spoonEM's Avatar
omgwtfbbq mod.
ohhh..got it. Ill have to do that
Old Nov 6, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
Your tire pressure was super high. Your front tires should be around 18-20 psi (even on stock tires).
Old Nov 7, 2005
bgoetz's Avatar
bgoetz is an unknown quantity at this point
I think that the complete missconception is that time taken off of the 60ft works on a 1:1 ratio, it does NOT (i.e. .433 seconds taken off of the 60ft does NOT = .433 seconds faster in the 1/4). I am not to sure on the exact #, but it is atleast 1:1.5. So .433 seconds off of the 60ft would = somewhere around a .65 reduction in the 1/4mile. So if we take his 2.422 60' and reduce it to around a 2.1(more than obtainable with his current setup) he will run around a 13.9xx. So with his setup and a decent launch (not even a great one) 13s should be no problem.
Old Nov 7, 2005
SLO REX's Avatar
250+ awhp Stage 2
WHAT?!?!?! Tire pressure should be aound 27-35 psi. Depending on how rough or smooth you want them to ride. 18-20 psi will cause major sidewall damage, don't listen to this guy.
Old Nov 7, 2005
bgoetz's Avatar
I almost forgot that 14.3xx was at a higher altitude. So 13s should be not problem at whatever altitude you ran at. Corrected you could hit 13.7xx with a decent lauch.
Old Nov 7, 2005
Everybody I have talked to at the track lowers their front tire pressure down to 18-20 psi for drag racing.
Daily driving pressure is 32 psi BTW.
Old Nov 7, 2005
SLO REX's Avatar
250+ awhp Stage 2
Oh ok, I thought you meant DD at 18-20 psi. My bad...
GolNat
Suspension DIY
May 12, 2022 06:49 AM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Lopes101
Jun 7, 2015 08:04 PM
HiImBrandon
Jun 1, 2015 07:34 AM
dragonsblood
Apr 27, 2015 12:28 PM
