how fast would this run
Old Oct 28, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
my civic is bone stock except for some ice.
i was thinking about getting some show and a lil go
17" rims with some sticky tires- yokohama es100 that are aa rated traction
a fifty shot of nitrous oxide.
so what would be the et on the track? i just want some go for once in a while
Old Oct 28, 2004
thrash_273's Avatar
deploy,engage,destroy.. to fail is not an option
thrash_273 is an unknown quantity at this point
i say 15.8 or if good launch.... 15. that's what i think... dn't load too much gas... maybe 1/4 tank.
Old Oct 28, 2004
Atticus's Avatar
Atticus is an unknown quantity at this point
probably looking at mid to low 15's high 14's depending on engine type, tranny / driving skill, ect.
Old Oct 28, 2004
BlackFire's Avatar
BlackFire is an unknown quantity at this point
With a 50 shot of Nitrous, a D17A2 will not hit the 14's if the air intake & exhaust is not modified too, and a couple of other things.
Even with other engine mods, 50shot of NOS will not get him to the 14s. It will need a lot of modifications. It could happen, but not with "a few bolt ons"
Old Oct 28, 2004
Atticus's Avatar
we can hope now, cant we.
Old Oct 28, 2004
cambo's Avatar
I wish I was asian
IBTM to track/strip/street forum.
Old Oct 28, 2004
jttegx's Avatar
OMNES AD UNUM
i'd say 16's assuming you have ex model
Old Oct 28, 2004
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
I say you run and tell us.
Old Oct 28, 2004
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Agreed. Also the bigger tires are going to slow you down as well. Can you even run nitrous through a completely stock engine w/o that engine falling to pieces? Even if you had intake and headers you still have to beaf stuff up just to protect the engine. Correct me if I am wrong.
Old Oct 28, 2004
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
OK, I will. Your wrong, NO2 can be used on a bone stock engine. Just wouldnt go over 50.
Old Oct 28, 2004
joe6680's Avatar
A property of nitrous oxide is that at about 565 degrees F., it breaks down into nitrogen and oxygen. When it is introduced into the intake tract of an internal combustion engine, it is sucked into the combustion chamber and, on the compression stroke, when the charge air temperature reachs 565 deg., a very oxygen-rich mixture results. If we add extra fuel during nitrous oxide injection, the effect is like a super charger or increasing the compression ratio of the engine. Automotive nitrous systems work like the automotive eqivalent of a jet's "afterburner" and is used for short duration extra bursts of power.
Nitrous oxide has this effect because it has a higher percentage of oxygen content than does the air in the atmosphere. Nitrous has 36% oxygen by weight and the atmosphere has 23%. Additionally, nitrous oxide is 50% more dense than air at the same pressure. Thus, a cubic foot of nitrous oxide contains 2.3 times as much oxygen as a cubic foot of air. Just do a bit of math in your head and you can see if we substitute some nitrous oxide for some of the air going into an engine than add the appropriate amount of additional fuel, the engine is going to put out more power.
You have to add more fuel to the mixture to get it to produce results. How are you going to do this with a completely stock engine?
Old Oct 28, 2004
djmota's Avatar
I guess we are all assuming that he will be using a wet kit. you'll see hi-mid 15's
Old Oct 28, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
n2o ;P ...
sjonesd3
Jun 11, 2015 06:32 PM
vtechcivic
Apr 21, 2015 06:58 PM
HaRdKoRePinoYrAcer
Jan 28, 2002 08:02 PM
supercivic01
South
Nov 30, 2001 11:27 AM
JumpingBean
Nov 12, 2001 05:42 PM
