Launching tips
Old Oct 2, 2004
grindsman's Avatar
grindsman is an unknown quantity at this point
Launching tips
I normally launch between 2500-3000 but i normally get alot of wheelhop. Its probably mostly because of my 17s i guess but is there anyway to minimize this? I also hear of people preloading the shocks or feathering the clutch. What is the best way to do this?
Old Oct 2, 2004
1320Racing's Avatar
1320Racing is an unknown quantity at this point
New engine mounts
Old Oct 2, 2004
TurboDreamZ's Avatar
Super Member
TurboDreamZ is an unknown quantity at this point
engine mounts could be the problemm.. ^^ agreed..
Old Oct 3, 2004
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
What's preloading the shocks....?
Old Oct 4, 2004
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
I did a couple practice launches today. I launched one time at 2k, got a little wheel hops, and then pulled. Second time I launched at 2,300...Hopped alittle and then pulled, hopped once going into second.
After, I just put it in first, let out clutch normally, pulled to about 6,300, shifted REAL nice into second, no hop..
I'm trying to get better at my 1st to 2nd shift, cause that hop is gonna get REAL bad when more power applied.
Old Oct 4, 2004
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
yeah i no what your saying. i had stock like 13 or 15's on my car and now i have 17's so i'm hoping it wont wheelhop as much, i used to screech the tires shifting out of first.
Old Oct 4, 2004
jonnyg's Avatar
E36 M3 Driver.
jonnyg is an unknown quantity at this point
try slipping the clutch more to prevent wheelspin and maybe experiment with a little more rpm.
Old Oct 5, 2004
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
Ill launch mine at about 4500 and no wheel hop due to the Koni front end set-up have 17" wheels with yokohama paradas about half wonr down...they act a little like slicks its nice the launch stays pretty smooth and i beat a lot of cars off the line i have no business beating
Old Oct 6, 2004
sofabolous's Avatar
sofabolous is an unknown quantity at this point
i dont like launching with my 17's.. hopping doesnt sound good at all.. hydro'd in the rain by mistake one time.. it was bouncin like a 64
Old Oct 6, 2004
Echelon04's Avatar
The one and only....
Echelon04 is an unknown quantity at this point
I have 17's and hardly any wheel hop...I "bark" the tires when I hit second though..
Old Oct 7, 2004
nismostreets21's Avatar
nismostreets21 can only hope to improve
damn you guys launch low i launch about 5500 no wheel hop and you may say that is to high but beaten a lot of cars ppl said i would get smoked by.
Old Oct 8, 2004
scansel912's Avatar
Don't race in ur 17's at all, you'll be quicker at the track with your stock steelies more then likely. Try launching higher but don't drop the clutch. Try feathering it instead.
Old Oct 8, 2004
00celicagts6spd's Avatar
the higher you learn to launch the quicker you will be off the line.
for me i launch at 8600 rpms and hook around 6000 - 6500 rpms.
I'd say rev as high as you can, dump the clutch, slightly let off on the gas and as the car hooks, floor it. you'll have good momentum goin and done properly you should hook right away. Timing is the key to this technique though. if your timing is off you'll screw it all up.
Old Oct 10, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
4000rpm
Front Upper Strut Bar
X-brace
Thicker Tire Wall
Air To 20psi
__________________
No Wheel Hop
SammySC
121
Apr 7, 2017 07:43 PM
emiixo
Exterior
Sep 22, 2015 03:53 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
Bikergofast
Sep 12, 2015 10:54 AM
99BoostedSi
Sep 7, 2015 04:49 PM
