Nitrous quarter mile timeslips
Old Jan 14, 2004
newshus's Avatar
newshus is an unknown quantity at this point
Here are my 5 to submit....
Old Jan 14, 2004
newshus's Avatar
two of them...
Old Jan 14, 2004
newshus's Avatar
need to make them larger...
Old Jan 14, 2004
newshus's Avatar
better...
Old Jan 14, 2004
newshus's Avatar
another two...
Old Jan 14, 2004
newshus's Avatar
last one...
Old Jan 14, 2004
02civic's Avatar
Need....More....Mods
02civic is an unknown quantity at this point
is it just me or are you saying you ran with nitrous?? what shot...
those appear to be stock times though
Old Jan 14, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
you look like you are waiting for the green.
sorry to bag on you but your reaction times suck,
also your 60 foot times are horrible...I am guessing that you are spraying in
1st gear which is bad and your tires are just spinning.
I am also guessing that each gear you shift into you are spinning the tires.
or, you nitrous jet is clogged a bitt and you are spraying an inadaquate mixture and spraying
more gas into the intake, or your nozzel is about a foot away from the throttle body
Old Jan 14, 2004
newshus's Avatar
Actually, I spray (50 shot) in first gear for one try, then second gear for another two, and the last two in third. I spin the tires in every slip that you see here. Can't get any traction....the reason for my horrible times. If I'm spinning the clock is moving and I'm not. The best speed trap time I have is 91.29 which should be a better time. These are all old from about a year ago.
Old Jan 14, 2004
kjgracing's Avatar
try launching at around 2,800 rpms.
Old Jan 14, 2004
newshus's Avatar
Sounds good...all of those launches are around 3500 to 4000.
Old Jan 14, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
try waitin till like 4000-4500 to spray that will let your tires stop ripping and get the spray to do someting. cuz no offence but i have the same 1/4 mile without spray. (my best)
Old Jan 14, 2004
Jaykuai's Avatar
ish...
^ he is in FL and you are in NJ..
maybe hes more "up" than you.
Old Jan 15, 2004
00celicagts6spd's Avatar
yeah youre launches are really holding you back. you can easily gain .5 once you get the hang of it.
Old Jan 15, 2004
newshus's Avatar
I haven't used the nitrous since. Burned up the tires and just got new ones. I didn't try lowering the pressure either. Heard that works pretty good. I'm newer to drag racing. My last car was an MR2 and I autocrossed with Martin Sports Compact Car here in Orlando. Now I've got to get more practice in drag. What?? "maybe hes more "up" than you"
Old Jan 15, 2004
I think he meant elevation wise.
for the 1/4 I put my street tires to 18 psi. and it really does help.
Old Jan 15, 2004
kjgracing's Avatar
I drop down to 23psi.
Also your sixty foot times will be better and your 1/4 mile time will get lower,
but your trap speed will be a little less.
Old Jan 15, 2004
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
Florida is about as low in elevation as possible without being below sea level. I'm guessing you haven't been there and that georaphy wasn't one of your strong subjects in school. Temperature and humidity would be a factor though.
As for those 60 foot times, they are atrocious. 2.3-2.4 is more like what what you should be getting on street tires. But practice makes perfect so keep at it 'cause I'm sure you had fun.
Old Jan 15, 2004
I think 2.2's are possible on street tires. just takes practice.
alexxx
Jan 7, 2004 09:15 AM
SLOcivic
Jan 31, 2002 04:30 PM
ripper
Jan 30, 2002 06:45 PM
BiGDoG
Jan 29, 2002 10:28 AM
normaspirated
Jan 2, 2002 03:19 PM
