shift techniques?
Old Nov 3, 2003
R3DL1N3's Avatar
shift techniques?
couple questions,
1. i read a post somewhere that says our cars cant double clutch? ive never tried it but i was just wondering why cant they?
2. whats short shifting?
3. is quickshifting ok for your car?
Old Nov 3, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Short shifting is not redlining out. Usually if you've got a tight corner or something, and you'll be revving too high to go around it (i.e, your wheels will spin and you'll lose it), then you upshift, even though you have more RPMs to go.
Quickshifting isn't good, it wears on your synchros... but if you don't do it constantly, it won't kill the car quickly.
Double clutching is slow. Synchros do the work faster. Double clutching with synchros kills the synchros, so don't do it.
Old Nov 3, 2003
R3DL1N3's Avatar
thanks for the quick help
Old Nov 3, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
uh wtf .... quickshifting wears out the syncros? ...
damnit ... I quickshift on a daily basis ... (provided that quick shifting just means ... shifting quickly)
Old Nov 3, 2003
Jap-Euro Fusion
quick shifting, usually means slam shifting. If you shift faster than the synchros can match the RPMs, you're gonna heat them up, and pre-maturely wear them.
Old Nov 3, 2003
Zzyzx's Avatar
Autocross Junky
yup, synchros can only work so fast......
Old Nov 3, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
How can double clutching wear the synchro's? When I double clutch it goes into gear much smoother then when I don't especially when I go into 1st gear, sometimes I can't even get it into 1st unless I double clutch, I think it only screws em up if you don't do it right. Whenever I go into 2nd gear and i'm going over like 30-40 I always double clutch.
Old Nov 3, 2003
Zzyzx's Avatar
Autocross Junky
When I down shift I just revmatch. Gotta pratice those racing techniques!
Old Nov 3, 2003
Renamazazo's Avatar
I used to just rev match, but with the short shifter it feels like i'm really forcing it into gear, that's why I double clutch, also, did you see my results from the AutoX this weekend Zzyzx?
Old Nov 4, 2003
LazyDog01's Avatar
Raceway Park Track Tech.
only quick shift....at track
Old Nov 4, 2003
Zzyzx's Avatar
Autocross Junky
ya I checked them out, Not bad for your first time. especially in the snow..... Thats crazy.
Old Nov 5, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
on the road drive nmormal.. no reason to be speed racer.. at the track.. drive it like ya stole it...
Old Nov 9, 2003
Shambler's Avatar
I'm an idiot.
Shambler is an unknown quantity at this point
Stupid kids granny shiftin, not double clutching like you should.
Old Nov 9, 2003
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
lol shambler
<--- drives hard all the time, cept when its 3 in morning coming home after a long night of racing.
Old Nov 16, 2003
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
i heard about double clutching but i have no clue on how to do it and i don't really want to try. somebody explain how you double clutch..
Old Nov 17, 2003
username03's Avatar
The Anti-Rice
username03 is an unknown quantity at this point
i believe it is something to the extent of that when you shift, you first flip into neutral to get the RPMS higher, then upshift to get more of a boost.
if im right or wrong, its bad for our cars.
Old Nov 17, 2003
00celicagts6spd's Avatar
2 FAST 2 Furious 2 Fast 4 Y'all man!
^^^ Taught me how to double clutch faster and drive in reverse going 90mph
Old Nov 17, 2003
Zzyzx's Avatar
Autocross Junky
2 Fast 2 Furious tought you how to Burn up a clutch.......
Double clutching is a term used for 2 different actions.
one is by drag racers and the other is from the street and road racers.
the one described by username03 is more or less the technique used and described by drag racers as double clutching. Personally I dont see the point in this. (it was probably started by Clutch Manufacturers so they could sell more clutches.....)
the other and OLDER description of Double clutching is used primairly with cars that do not have synchros. it basically takes the place of the Synchros and prevents grinding of the gears when you shift. It is both a waste of time and unnessisary for our cars.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Jrosa
Sep 14, 2015 08:24 PM
