Transaction Feedback Both parties of a transaction please post your positive/negative feedback here. This section is meant to give both parties the ability to explain the situation and rebut. New buyer should check on feedback regarding all new sales.
E-bay Seller Warning 04-05 civic fogs
Old Jan 22, 2006
jzuha01's Avatar
Championship White 04 Ex Coupe
jzuha01 is an unknown quantity at this point
Do not buy foglights from e-bay seller powerimport the wire harness that is provide does not work with our cars. The switch that came with the lights burned out as soon as I hooked it up and the only good thing was that the lights actually worked. But I had to do a major amount of work to get them to work and hardwire the piece of **** harness and then I had to buy a whole new switch also. So just be warned guys/gals!
Old Jan 22, 2006
Al Gore FTW's Avatar
jdmtytedoridori
aight
Old Jan 22, 2006
redex04's Avatar
redex04 is an unknown quantity at this point
thanks
Old Jan 22, 2006
05_ CivicJDM's Avatar
Thanks also, i'm about to purchase some pretty soon...
Old Jan 22, 2006
mateusz's Avatar
mateusz is an unknown quantity at this point
i had the same problem the swith sucks (cheap)
Old Jan 23, 2006
jzuha01's Avatar
No problem guys
Old Jan 29, 2006
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
More that look out for the seller, you shoudl look aout for the brand, what brand were thay?
Old Jan 30, 2006
spoonEM's Avatar
omgwtfbbq mod.
i got the same kit. Im ****in PISSED! I had to do a bunch of **** to get em to work to. Where did you wired yours up to?
Old Jan 31, 2006
jzuha01's Avatar
I had one of my friends help me install them in my car. He has alot of electrical background so I dont know exactly but I will check for you.
Old Feb 1, 2006
ragingSPAM's Avatar
I just burnt my tongue
hey robbie when u installed mine mine seems to work fine...i've had only 1 problem...the power connector doesnt connecto too well and sometimes the thing goes out...but if i jiggle it around and move it to a spot with better contact than it works fine...i think im gonna either hardwire it into the same power source or to the accessory wire in the ignition...the kit is crappy but it works for now heh
Old Feb 7, 2006
aussiebuddha's Avatar
aussiebuddha is an unknown quantity at this point
hi guys.
This is my first post here, so please excuse me for being a n00b.
Anyways.
I bought the powerimport lights a while ago and decided to install them now.
did all the wiring got thru the firewall plug the switch.
There's a 1 pin harness than needs to be connected to the power, do you know where the H... that thing goes?
Cheers and thanks for the help
PS: I've got a civic GLI 2005 (Australian version)
Old Feb 7, 2006
spoonEM's Avatar
omgwtfbbq mod.
Originally Posted by aussiebuddha
hi guys.
Anyways.
well.....like us, you bought some piece of **** fogs. If you plug it into where its supposed to go, the switch is going to stay on always....even when the key is off. Its because of a shitty harness. Youre best bet is to cut off the plug, and wire them to a switched 12v source like i did. just some advice....lol
Old Feb 7, 2006
and just to try... where was it supposed to go?
Cheers
Old Feb 7, 2006
found the 12v source on the fuse box.
still doesnt work.
the relay seems to be ok, could it be the switch?
I dont think the wiring they provide doesn't work, since powerimport has more than 10000 positive feedback.
could be a **** product and last 2 days, but it has to work *me thinks*
Old Feb 8, 2006
ragingSPAM's Avatar
check the fuse cuz my harness and connection were all ok just the fuse was cheap and went out i changed it and no problems now
Old Feb 8, 2006
russdogg's Avatar
Myspace Gangster
russdogg is a glorious beacon of lightrussdogg is a glorious beacon of lightrussdogg is a glorious beacon of lightrussdogg is a glorious beacon of lightrussdogg is a glorious beacon of light
dang, hope you can get it going...
Old Feb 10, 2006
djrabbi's Avatar
djrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to all
i bought something from him.... i dont remember thoughh, hes a okay seller
Exterior
Nov 28, 2025 05:23 PM
Xuhme
21
Aug 7, 2023 03:40 PM
TomSchaeffer
Nov 2, 2021 07:31 AM
smmahan
Apr 15, 2015 08:17 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
