engine noises?
Old Jan 1, 2008
  #31
Jza's Avatar
Jza
Jza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the rough
Re: engine noises?
Originally Posted by D16Z6_owner
its the exhaust manifold contracting faster than the clyinder head while cooling down
Solution: Replace exhaust manifold with turbo manifold, hook up the turbo and the intercooler, that simple, ask Speedfoos.
I'd still check the VTEC orb, though.
Old Jan 1, 2008
  #32
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Re: engine noises?
lol right im sure clint would agree on the ease of a turbo install!
Old Jan 1, 2008
  #33
briand17a2's Avatar
briand17a2 has a spectacular aura aboutbriand17a2 has a spectacular aura about
Re: engine noises?
camshaft gremlin thats ****.
Off topic, anyone know where to get a D17A2 exhaust (weld) flange? If not,
1) Would anyone else want them if I started making them,
2) Should primaries be stock bore, if not, how much bigger?
3) What alloy would be middle ground on the price / durability ratio? Im thinking 304.
Im getting pretty good at welding stainless now, so sooner or later I hope to make me own turbo mani.
Part 2:
Im learning to work with microcontrollers & **** like that...if anyone knows anything about D17 ECU reverse-engineering or whatnot, I'd like in on it, might be able to help. Id love to shitcan this eManage right now. I hates it.
Old Jan 8, 2008
  #34
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
Re: engine noises?
You guys are *******s, let me tell you exactly what to do: open you oil cam and take a gallon of Kool Aid and pour it in makes sure it mixes well with the oil. Also get a gallon of water in the throttle body and crank that engine like souljah boy crank that crank that. These guys are retarded they should know you dont have VTECH
Old Jan 8, 2008
  #35
Jza's Avatar
Jza
Re: engine noises?
^ that wasn't funny...
Old Jan 9, 2008
  #36
ryox82's Avatar
Re: engine noises?
Yeah not at all....you don't know who might actually be following that advice and now it would be your fault that their engine is thrashed. Keep that in mind...some people think there are gerbals running around in there keeping the damn car going and get confused when the power rating is in horses instead of rodents.
bokogabe
May 21, 2015 09:27 PM
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
silvervtec01
Dec 9, 2001 08:50 PM
TAZZ
Dec 5, 2001 09:35 PM
