01 Sedan...need some advice...116k miles and boost?!
Old Nov 12, 2007
  #31
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
Re: 01 Sedan...need some advice...116k miles and boost?!
Originally Posted by bigainabuilt
Ok where to start?? Exhaust will be good for about as much hp as a sticker would maybe 1 hp more, If it sounds good and fits right for that price i would run it. I would recommend either swap (200 hp) or just save up the cash and buy a car that you could afford to sit (because it will). As far as what new to put in your ride thats up to your tastes. Got ICE??
i got a sound system that is precise as a rifle
300watt rms sub by eclipse older model
blaunkpunkt speakers
kenwood amp
sony deck
dont need anything else
as far as the exhaust, il be better off with an intake probbably...my old one actually gave me more power after 4500, sounded good, and better MPG
Old Nov 12, 2007
  #32
blouisgod's Avatar
Life Begins > 6800rpms
By new blacked out headlights to refresh the car - they look a little sun faded.
Old Nov 12, 2007
  #33
TemjinX2's Avatar
Originally Posted by ultimatetuner10
seems kinda funny you would say that...how is deleting a cat not good for at least a few ponies...explain
unless you have a 1970's pushrod engine in there, the cat doesn't eat that much power. Most modern engines are designed with the cat in mind.
Some members even said they lost power then they deleted there cat because of the lost of back pressure.
We're just trying to save you some money. Most of the members have had I/H/E. Then went back to stock when they realized it didnt do anything and they lost there low end power. The d17 is tuned pretty well straight from the factory.
Getting power out of sohc low displacement 4 cyclinder is difficult.
Force induction or a swaps is the best way to get a lot of power out of the money you invested.
Old Nov 12, 2007
  #34
Christian Calim's Avatar
Christian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to behold
Originally Posted by manahoonie
well, there's always changing out things...if you want (headlights, tail lights, grille...)
there's always the folding side mirrors for our sedans
have you checked about a Neuspeed Lower X-Brace??? really gives you stability in the steering!
and there's always painting the door handles to match...
just some thoughts. gotta love the sedan!
are you in the city, or located outside of Philly? I sometimes visit my family in Devon, PA
yeah, gotta love sedans! or you can just go all out show (body kit,turbo, and more).
Old Nov 12, 2007
  #35
Technical Assistant
il probbably just get my muffler put back on, the stock one, and leave the **** for now
Old Nov 13, 2007
  #36
Technical Assistant
real quick will an injen intake from an automatic fit a manual...?? its a coldair
Old Nov 13, 2007
  #37
Technical Assistant
looks like the bracket wont even line up
Old Nov 13, 2007
  #38
Technical Assistant
or this one...looks like the injen and fujita system but without the letters
80 bux brand new...any experience with this?? the mount seems to be in the same place as the other intakes as well....worth it??
Old Nov 13, 2007
  #39
Technical Assistant
come on people intake help
Old Nov 13, 2007
  #40
speedfoos's Avatar
I ended up cutting the brackets off my generic Ebay intake and making my own with a piece of 90 degree bent aluminum (about 2" long by 1/2" wide) and a worm clamp. That way you can move it up and down the pipe to where you want it. The only difference in the AT and MT intakes is the location of the little mounting bracket.
Old Nov 13, 2007
  #41
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
^ speedfoos is right on. ebay intakes arent good for anything but the piping. i used my own hardware putting mine on when i had one and made little brackets for it.
Old Nov 13, 2007
  #42
Technical Assistant
thanks dudes...yea the brackets on my old ebay one didnt line up at all, but maybe this one will be different being obx, at least some form of a brand name. does the design look the same as the injen and fujita? it does to me
Old Nov 13, 2007
  #43
no, injen, obx, fujita cold airs will not fit on automatics, due to the tranny being in the way.
Old Nov 13, 2007
  #44
CenZ's Avatar
PWIT
actually they all make a automatic version...
Old Nov 15, 2007
  #45
Technical Assistant
will one from an auto fit a manual...i know the bracket is in a diff spot, but if i get an auto intake for my manual will it still bolt on?
Old Nov 30, 2007
  #46
Technical Assistant
with a t3 turbo how much boost can i run safely. motor has 117k miles and given that compression is still ok. some said 7 and call it a day some said 10 and get arp studs, thicker headgasket, and a good tune with chrome
Old Nov 30, 2007
  #47
ziggi21's Avatar
ziggi21 is an unknown quantity at this point
if u have spare change to throw around save up for a new d17 block bottom end and u can work on it... while u have ur dd thats what im doin considerin im dd as well
Old Dec 16, 2007
  #48
Technical Assistant
Did some thinking and I am feelin as follows for now
Put the exhaust on that I have
Blackout headlights
Ditch the lip and front bumper for a hybrid one
Hybrid lip spoiler
04/05 rear bumper
04/05 taillights
16in rotas (undecided on which ones I want)
that or I may just drive it the way it is since I want to get a new car when I turn 21, not sure yet. Suggestions?
Old Dec 16, 2007
  #49
Technical Assistant
I also have this axleback sitting in my garage..love the sound of it, but the look kills it for me...maybe I should paint it black and put it on instead of the exhaust??
http://youtube.com/watch?v=omok92Ly-MY
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
Danofthebass
Jun 8, 2015 08:42 PM
Mike Garvey
Jun 7, 2015 07:25 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
