My new custom door panels. *More Pix*
Re: My new custom door panels. *More Pix*
mannnnnnnnnnnnnnnnn dont you know i went to get the tires mounted and balanced and they f$%ked one of my tires..... they were like "hey it happens with low profiles like urs.... i have 225 35 NITTOs and they dont want to pay it cause they said the tire had alot of wear on it... i asked them if they were blind cause they only had about 200 miles on them.. gonna report them punk asses... but anyways the 3 i have on right now look sweeeeeeeeeeeeeeeeeeeeeeeeeeeeet
A long winded 7th genr
good job.
so you didnt lay down some fiberglass on the door panels? is it as easy as pealing off the fabric and spray painting it with the paint? no sanding?
sorry for all the questions, but i'd like to do this too. where did you pick up the paint, can you get it at any autoparts store?
thanks!
thanks!
-Remove door panels
-Remove handles/armrest
-Remove Cloth
-Sand with 100 grit sandpaper, then sand with 220 to get the glue off
-Mask entire door w/paper and masking tape
-Blow off dust and crap with air
-Wipe down surface with wax and grease remover
(I used an HVLP gun and an air compressor to paint.)
-Paint entire surface with primer (follow manufacturers specs.)
-Let dry ( I waited 24 hours)
-Wetsand primer with 400 grit & soft rubber block
-Paint one coat of single stage paint
-Wait 15 minutes and paint another coat
-Let dry install everything back together and BAM!
Fly/drive your Massachutsetts *** to SoCal and THEN I'll do it!! Haha (Bring Dr.Pepper as bribe)
You Stay Classy, San Diego
I was thinkin about doin this with mine. Will they look like **** if i just do them in like 3-5 coats of krylon fusion silver??? Wut if i layed down a thin coat of fiberglass would that be better. I dont know much about fiberglass wut would i have to do??? Could i just lay down a coat of auto body filler and sand it down then paint it with krylon fusion silver?
man all u have to do is rip the fabric off.. clean it real good u know take off the glue and what not.... do some sanding, primer, paint with krylon as many coats as you want and clear since your using krylon he did not have to use a clear coat cause of the paint he had but look through the thread he pretty much explained all steps
na u shouldnt have to as long as you do good prep work on it,,, i used krylon fuzion and it works good as long as you do good prep work and a good sanding for the paint to stick on
If you use automotive paint, the situation changes. When you decide what you want to do, you can PM me with the info, and I'll tell you which to go with.
OK! Send them on over! Although truthfully I don't think that it would be a good investment, shipping to and from, plus paying me and buying paint....Hm you can do it! Have faith in yourself! YAY!
if someone has pics of door panels that have been painted using krylon fusion silver or like red or something i'd appreciate seeing them
Aladinbama
Aug 23, 2015 06:37 AM
glockma630
Aug 1, 2015 10:30 AM
ayoitzjulesdx98
Jul 26, 2015 02:25 PM
ballmich
Jul 9, 2015 11:59 AM
