help - pics SSM civic
Old Jul 3, 2007
12345678910's Avatar
12345678910 is an unknown quantity at this point
i need a hand from you guys! i bought a tripod, hoping to make the pics clearer, but its not just helping. all the pics turn out fuzzy and grainy then i edit them (on my mac using iPhoto) and it helps a bit, but its still not great. then i look at pics you guys took and they look amazing...
my camera isnt a piece either. i have a Canon SD630. 6mp, and im trying toooonnnnsss of settings
what can i do?
heres what i mean
but then i took these pics a while ago with just auto bleh settings and they turned out amazing....
please help, this is SO frustrating, haha
Old Jul 3, 2007
1sykcivic's Avatar
RHCP0801 is my hero
1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute
Re: help - pics SSM civic
use the timer, and increase shutter time
also best time to take pics is dusk/dawn
Old Jul 4, 2007
soldierboi's Avatar
soldierboi will become famous soon enoughsoldierboi will become famous soon enough
go back to auto settings then lol
Old Jul 4, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
dude those arent fuzzy at all!! all u have to do is click that little bar to vies the original size... they look nice man...
Old Jul 4, 2007
LT2004ever's Avatar
but set up your tripod at a level place where u wont have to use zoom. Turn your iso up a tad, then pic no flash. After all that make sure the resolution is at "quality" and adjust the lighting option based on the conditions. also u might wanna then turn your exposure time up by like 2 seconds or so. Then click the button, and post what that takes. I can try to help you from there. Also if u dont have some of those options, just tell meh
Old Jul 4, 2007
Ti71's Avatar
Ti71 is an unknown quantity at this point
Use your camera's spot metering to set the correct exposure
Old Jul 4, 2007
mogwai's Avatar
mogwai will become famous soon enough
Check you ISO settings. Typically you use a higher ISO when in dark settings and lower ISO when it's more lit. The cost of using a higher ISO is that the pictures turn out more grainy. From what I read about your camera, it becomes pretty noisy at it's higher setting of ISO 400 and 800. Just do some more experimenting... if it is set to 800 for example, lower it and use a slower shutter speed or open up the aperature more and experiment from there. I don't know if your camera has a full manual option but it should have a aperature priority or shutter priority setting.
Also as another member pointed out... make sure the quality setting is set to Fine. Don't overlook the obvious, maybe in manual you have to readjust the picture quality. That 1st picture does look pretty bad. The others look pretty good though... Good luck.
Old Jul 4, 2007
looks good? idk, also the first pic is behind plastic, ofcourse it wont look as clear. the light reflects off it and you cant get a good shot. just like for headlights, i always have to take pic with cover off or its all weird with the cover reflecting most of the light.
Old Jul 4, 2007
54321r's Avatar
54321r will become famous soon enough54321r will become famous soon enough
what he said, or it might not be your timing or settings like that. if your camera has an auto focus then use it or that may mean what u meant by auto mode...sometimes the brightness n contrast mess with the pic so look what they are at
Old Jul 4, 2007
my ISO has been set at 800, and the shutter is open for a second (long shutter option), and i take ALL pics at the superfine quality setting.
thanks for the pointers though guys, i REALLY appreciate it. gives me a place to start.
Old Jul 5, 2007
kcsays's Avatar
kcsays is an unknown quantity at this point
you do not want iso to set too high, u want it low like lowest ur camera will go. and when u take pictures that is in under shadow / dark places u need tripod to get the nice shot, cuz u will be using long shutter speed.
if u wanna know more about the settings, PM me of reply on here. help u out.
Old Jul 5, 2007
LT2004ever's Avatar
alrighty man, found some easy reading for ya
ISO
http://www.digicamhelp.com/camera-fe...ttings/iso.php
SHUTTER SPEED
http://www.digicamhelp.com/camera-fe...tter-speed.php
EXPOSURE
http://www.digicamhelp.com/camera-fe...ettings/ec.php
APERTURE
Adjusting your digital camera's ISO settings will determine how sensitive the camera will be to light. This is very much like using different film speeds in a film camera. The higher the ISO setting, the more sensitive the camera will be to light.
With the camera set at ISO 100, this photo captures the bright white of the sun sinking below the
horizon, but the rest of the sky is gray.
This shot was taken moments later. This time, however, the camera was set to ISO 400.
Rendering the camera more light sensitive resulted
in more vivid and dramatic color.
Aperture values impact depth of field (the camera's ability to deliver sharp focus on objects both close to and further away from the camera). A high aperture value (small lens openings) delivers more depth of field, while a low aperture value (big lens opening) will deliver less depth of field. If you want to isolate your subject from the background (let's say you're shooting a person standing in front of a collection of shrubs), you'll want a low aperture value that will deliver shallow depth of field (the person will be in sharp focus, but the shrubs will be blurred).
If you're shooting a landscape, on the other hand, you'll want a high aperture value (small lens opening). This will deliver more depth of field, keeping objects both in the background and in the foreground in focus.
Since shutter values control how long the lens remains open, they also control how long the camera's image sensor has to capture an image. If you use a slow shutter speed and your subject moves, the resulting picture will likely be blurred.
Situation-related modes are designed to take into account the conditions under which you're shooting. If you're photographing an automobile race or a sporting event, for example, you could set the camera on "sports" mode. The camera would then automatically set its aperture, shutter, and other settings for those conditions-giving a bias to stopping the action to reduce blur. In "night" mode, the camera will choose settings (such as a slower shutter speed) that will compensate for low-light conditions. In this mode, however, moving objects will almost certainly be blurred.
wait isnt there a sticky somewhere on this site about this stuff?? lemme check for ya
Edit: bruhahahah!!
https://www.civicforums.com/forums/3...aphy-tips.html
https://www.civicforums.com/forums/2...hy-thread.html
Old Jul 5, 2007
kcsays's Avatar
^^ i dont think he cares about the landscape photography....? =P
Old Jul 5, 2007
LT2004ever's Avatar
^^ yea but its still a picture is a picture... the way u alter the settings will determine the shot, whether theres a car in it or not The pics are pretty much for reference, just like all the links have pics to clarify what he doesn't understand through reading
Old Jul 6, 2007
LT2004, i love you. haha rep X 1000000000000000000
thanks again SO MUCH for the help (all of you)
Old Jul 6, 2007
kcsays's Avatar
no problem~
Old Jul 6, 2007
guitarchan16's Avatar
guitarchan16 is an unknown quantity at this point
Hey man, i have the SD630 too and it's one of the few camera's that i don't mind leaving it on auto because it usually does a really good job. Especially in the day light. At night or in darker areas, i'll usually put it to manual and change up the ISO settings and a few things, but one of the biggest things that i noticed that helped is to put on the timer...that way when you push the button you can let go and nothing is moving the camera when it goes off.
PS. I love that camera...it's awesome!
Old Jul 6, 2007
yeah dude, one of the things that i sure liked about it was the 3" LCD on the back. ive had Canon's for years so i stuck with it, but that 3" screen is wicked
thats a good idea to use the timer! i like! even the 2 second timer, because im way too impatient to wait 10 seconds for one picture
Old Jul 6, 2007
LogicWavelength's Avatar
7th Gen Photographer
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
Well - the problem in the first pic was your car was in shadow... Your camera isn't really designed for longer exposures without increasing grain - it ca do it - but it gets grainy. The higher the ISO - the more grain you get. And on smaller point-and-shoots the ISO is really there so you can "get the shot" but it won't be a piece of art.
Shoot in a little brighter sunset-light. If the car is in shadow, relocate. All your following shots seem to be a similar time of day, but the car is exposed to the light. Check out the guide in my Sig for additional info.
Old Jul 6, 2007
LT2004ever's Avatar
^^ THATS THE THREAD I WAS TRYING TO FIND EARLIER!! thanx logic
Old Jul 6, 2007
chicohonda02's Avatar
Since 2002 Baby!
ur photos look weird. PM CaucasinAsian he's a photo wize
chgofirefighter
Apr 18, 2015 08:08 PM
tattedlariat
Apr 17, 2015 03:26 AM
ImmortalEX
Nov 8, 2001 09:52 PM
Importracer
Nov 5, 2001 05:13 AM
