Turbo Installed Now Rebuild
Thanks there matt. no phone call needed... yet at least. i know how you did it now, but is it sturdy enough? don't you think it will rattle since its not mounted on a flat place? i was comparing the v2 vs the v3 intercooler, although the v3 is slightly shorter and i know it is able to flow more, the v2 seems as though it would cool the charged air much better. i have both intercoolers so i am not sure yet which i want to use. on to the whole exhaust mani, turbo, and downpipe... have you put this in yet? i have discovered 2 of the 3 oxygen sensors will have to be moved. one is shoved up against the front motor mount, and the other is right against were the metal guard that covers up part of the oil pan. let me know if you run into this same problem. i have some pics i just need to learn how to put them up on here
well i have an EX.. i only have 1 oxygen sensor in my car by the motor that goes into my down pipe, then i also have my AEM wideband in there, then i have 1 other oxygen sensor by my "cat".. and yes i have had everything in and im about 2 put the pics up now.. and the FMIC is fine there it wont move.. my friend is gunna weld my bolts and **** on once i have everything runin this week "hopefully" so...
vids will come as soon as i get my damn wire harness lol..... and all i need 2 do it put my harness in when they send it back.. and i need 2 clean my car its dirty all ova... and i have like rust spots on my hood 4 sum reason. andd the hot side of the turbo is already rusty also owell.. and i have some rust on my BOV flang cuz i got some gas that leaked out and got on it
hope non got in the bov owell its been dry so w/e
hope non got in the bov owell its been dry so w/e well.. this is gonna be alittle out of the topic, is the turbo gonna be as shakey as kswap?? (well i gues thats not as off) or the car just feels like as is?? ive been dying to know this lol
it should be pretty much the same as stock if you're using the same motor mounts. Everyone says the kswap is shakey because of the hasport motor mounts
The turbo is looking nice and came together quick for you. I'm hoping to have everything together by the end of next week and installed by the end of thanksgiving break *crosses fingers*
yeah i should have been done on wed last week when i got the mani but the damn harness owell.. and no it will not be shaky.. its gunna ride like stock or w/e and run like a stock turbo car cuz i have a great tune bein done by chris
werd, i still don't know what engine management I want, I need to decide by tuesday but **** I don't know. I'm leaning more toward pcs because of price, but I don't want to have to upgrade to the aem when I get the cams and internals changed (whenever that happens) and the aem has way more options for tuning. decisions decisions. I guess I'll see how your tune goes with the pcs and then decide, what psi are you thinking about runnnig? I want to run 8 or 9 on the stock internals
well chris said he would not do over 8psi on stock motor cuz thats 2 much WHP for the motor. he said on the old kits like v1 and v2 it would but fine but the v3 is so much better and puts down more HP with less boost soo.. and u can tune ur car with PCS XFC if u get cams and internals down the road still also.. talk 2 chris about it he knows everything.. im gunna run the 5psi base tune for like a month, once all goes well ill tune it for 7 or so
I plan on doing stage 2 turbo cam and I want to increase my rev limit into the mid-high 7k range and I will have to mess with idle so I will need the aem for that, but that will be a bit down the road especially since I plan on getting a bike next summer (was supposed to be last summer, but well, **** happens) I guess I'll just go with the pcs anyway, seems like it'll be good enough for now and by the time I get ready to do internals I'll have a much better job bringing in more cash and will just get the ems.
Matt, If i were you i would clock the center section of the turbo more so its parallel with the ground, i also notice your missing a downpipe bolt, but it looks like it would be difficult to fit one in there. Im suprised this kit doenst come with a flex pipe, hopefully you dont crack a weld somewhere due to the engine torquing alot more now that its boosted.
thx everyone...
@ ex2k3: you can do all of that with the PCS XFC chris said.. it is setup just like a standalone. thats just what i was told and it kicks ***.. and they have great customer service..
@ Sujak: no im usein the 5psi base map that paul has on his web site for now. im gunna do some data logs and send them 2 chris online and he is gunna see how everything looks and tell me what i should do. and yes pcs and go online and see what u are doin while u are tunein.
@ BigE19: no its not.. its Honda Bond, you have 2 buy it cuz we dont have oil pan gaskets, u have 2 used honda bond 2 seal it back up. and chris said 2 put some around the fitting just incase so i did..
@ joshb_: yeah i know my car has had 1 missin since i got it so idk.. i ill get 1 later on if i need 2..
@ Logan3024" the turbo is fine, its sittin how it is made 2 sit. and yeah im missin 1 bolt cuz i could not get it in there cuz i had 2 put the turbo in the car and hold it under the car, while someone put my mani on the block then we bolted the turbo up, then the down pipe. and i dont think ill crack a weld, or i hope not, cuz im not gunna be runin 2 much only what stock can handle untill i get my $ up and get internals.
thx man...... but as of right now the only thing im worried about it the IC pipein and stuff, i dont wanna blow a cupler.. but my friend welds so sometime im gunna get the pipes fit just right and have him weld a few of the pipes together so i can just have like the cuplers on the FMIC parts, 1 on the pipe that goes to the TB, and like 1 cupler on2 the turbo..
thx everyone..
at "cuplers" Last edited by Logan3024; Nov 13, 2006 at 11:22 PM.
quick question...shouldn't there be a pipe off the wastegate that merges into the downpipe? I don't know that much about turbos and the such, but I'm pretty sure the wastegate blows hot exhaust out of that port.
