i did it... vtec in a 01 civic !!!
Old Apr 22, 2006
str8street247's Avatar
str8street247 is an unknown quantity at this point
a while ago i had a post asking about vtec in my civic and here is where i stand
i made a custom cold air, i put an ebay header and test pipe on i kept the stock mid section not by choice and welded a ractive fart can on the back ( i had it laying around from one of my older cars) to top it off i got the final piece of the project the apexi vafc 2 hooked up with vtec set at 4600 rpm and although i thought the car would be sluggish until vtec hit but its not it runs great i love it and not only does it make the noise we all want but it actually pulls... the best way i can describe it without a sound clip is the older vtec with a stock exhaust....
i have the 01 civic ex and i dont know where to go from here... i want to work the motor a little bit but i am not sure if i am going turbo or nitrous we will see any1 with a built motor if you dont mind listing your set up with part numbers and total hp id appreciate it thanks
Old Apr 23, 2006
Zeppelin8778's Avatar
Zeppelin8778 is an unknown quantity at this point
what in the hell is the point of this post... ur car always had vtec, u didnt change anything except setting the vtec engage point later in the RPM powerband (stock is 4300)... most people move it down so it engages earlier so you have more powerband with the bigger cam lobes.
Old Apr 23, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
Even then you don't want to mess around with the VTEC engagement point until you start running aftermarket cams. Stock VTEC engagement point is optimized for stock cams.
Old Apr 23, 2006
exactly. i really dont understand the purpose of this thread whatsoever.
Old Apr 23, 2006
cwick187's Avatar
cwick187 is an unknown quantity at this point
Yeah, It's better to have the Hi and Lo point engage at the same time with the VAFC 2..I dyno'd my car awhile back and it makes the most gains and is smooth all the way up...It just feels like you are pulling because the "harshness" on the engagment point that your setting higher...When your in the menu for the Vtec Hi/Lo option, press the control button left while the RPM is highlighted so you see ****...
Old Apr 23, 2006
diskreet's Avatar
Worst post ever?
quite possibly
Old Apr 23, 2006
No, I think that this is the worst post ever:
http://www.7thgencivic.com/forums/sh...d.php?t=253663
Old Apr 23, 2006
diskreet's Avatar
You are right, that is the worst post ever.
Old Apr 23, 2006
civic01vtec's Avatar
ROFL.....this is great
Old Apr 23, 2006
Hayz's Avatar
I don't understand this post at all how does "custom cold air, i put an ebay header and test pipe on i kept the stock mid section not by choice and welded a ractive fart can on the back" give you v-tec, sounds like a crappy exhaust system to me...
Old Apr 23, 2006
dj02's Avatar
-closed-
Old Apr 23, 2006
aznrocka's Avatar
aznrocka is an unknown quantity at this point
hahaha...i think01hondercivic is right...that's gotta be the worse post ever
usajags84
15
Aug 19, 2015 03:12 AM
LionSpratt
Apr 26, 2015 01:02 PM
Tybonater
Apr 24, 2015 07:03 PM
CapYoda
Nov 11, 2001 05:17 PM
locozoko
Nov 4, 2001 05:45 PM
