Just installed Injen short ram...
Old Jun 2, 2005
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
Exclamation Just installed Injen short ram...
questions. Where does the o2 sensor plug into? it shows something different on the directions. And also how do i shut off my engine light? TY.
Old Jun 2, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
The Intake air temp sensor (which you called an o2 sensor) plugs into the hole near where the intake connects to the throttle body. If you don't have this hole, you're going to have to make it. But don't do it while the intake is on the car...
There should be some kinda rubber grommet in the hole already. If there isn't, its not a real injen.
Old Jun 2, 2005
civicrice's Avatar
yea i had the rubber but i lost it. so i dont know what to do now. If i do find it, i just slide it in there? and does anyone know how to shut off that damn engine light?
Old Jun 2, 2005
Blahman240's Avatar
you need the sensor in the intake to shut the light off... You'll need that rubber peice. Contact injen and tell them you never got one. They should supply you with one.
Old Jun 2, 2005
civicrice's Avatar
sounds good. how can i contact injen? and also how to get this light off after i get the part? the engine light
Old Jun 2, 2005
or buy some silicon hose from the auto store and connect it from engine to intake. To reset the engine light (once the sensor is connected), just unplug the negative battery connector OR pull out the FI ECU fuse under hood for a few seconds.
Old Jun 2, 2005
flqu05's Avatar
flqu05 is an unknown quantity at this point
pop the one out of your stock filter box.
Old Jun 2, 2005
jjdawg22's Avatar
jjdawg22 is an unknown quantity at this point
hahaha... I need to get my mind out of the gutter.
Old Jun 2, 2005
civicrice's Avatar
fixed. i used the stock one. Thanks guys
Old Jun 3, 2005
goodtimes's Avatar
OMG ROFL
Old Jun 3, 2005
haha.. dont worry.. i was thinking the same thing when i first saw it..
Old Jun 3, 2005
Blahman240's Avatar
pervs! lol
toastyghosty
32
Dec 26, 2001 02:03 AM
XenonCivic
Nov 30, 2001 04:21 PM
ModNewbieHELPME
Nov 20, 2001 12:25 AM
1028CiViC
Bolt-on Engine Performance
Nov 18, 2001 05:02 PM
CIVICINJEN
Nov 6, 2001 01:30 PM
