EP3 seat swap ain't no thang....
Yes, it's an Acura EL
I had some clearcoat left over from painting the bumper on my dad's/brother's Integra....I used that. I think the brand was Plastikote, I don't have the can anymore so I can't really say. I got it from a local bodyshop supply store. But remember kiddies, clearcoat won't gloss up unless you're wetsanding with fine grit between coats then layin into it with rubbing compound afterward.
Telly, you've gotta help your brotha from the L dot O....
I've got a new wheel coming in (obviously with no air bag). What do I have to do to make sure no SRS light comes on?
1) Disconnect battery, wait 30 minutes for residual charge to dissipate
2) Remove steering wheel, disconnect airbag/cruise/horn plugs
3) Stick a 2-ohm, 1/4watt resistor in the airbag plug. If you have a dual-stage airbag then you will have to use 2 resistors
4) Attach new wheel. Reconnect horn plug, relocate cruise control
5) Reconnect battery
6) Pray (Pecx, lol)
7) Turn on car.
Taken from pecx's DIY on this site somewhere.
ThE CoRRupToR
AHAHAHHA!!!!!!! Awesome!!! Hey Telly, did your door panels come in black stock?? I wanna paint mines black since i have ep3 seats too. What about the rear seats?? Dam your **** looks sick and i luv that thong
alaga
25
Aug 13, 2015 04:42 PM
cizsak
Jul 21, 2015 03:39 PM
[/QUOTE]
