Fuking Crap, I need a new Oil Pan
Old Oct 3, 2004
streetglower's Avatar
So I was outside changing my oil today and I got my old bolt off and drained the oil, then when I went to put the new bolt and washer on, come to my suprise that the damn threads inside the oil pan were fuked up. The bolt would just keep turning. So now my happy *** needs a new oil pan. I would change it myself, but I dont have much clearance under my car, and I would have no time to do it. I pushed it up to the local auto shop and hopefully they will take care of it.
My only concern is the cost and if the exhaust has to be tooken out to get the pan out. It looked like it did, or just unbolted in a certain section. Oh well, another thing needing to be replaced.
Old Oct 3, 2004
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
Dude !!! just get the drainplug that has self tapping threads !!!!!!!!!!!!!!!!
Old Oct 3, 2004
joski's Avatar
MmmMMm.. I smell boost!
joski will become famous soon enough
I'm with him.. Try that before you jump to conclusions and buy a new pan, bro!
Old Oct 3, 2004
redvtec04's Avatar
VTEC MASTER
http://doityourself.com/store/6274450.htm
Old Oct 3, 2004
kikoy's Avatar
kikoy has a little shameless behaviour in the past
dude...there is a heli-coil kit that you can buy from any parts stores and just buy the next lower/smaller or higher/bigger drain plug......no need for a new pan...i know i did it to my car once
Old Oct 3, 2004
zen_master's Avatar
whoa!!
haha
nice info!
Old Oct 3, 2004
bobbio's Avatar
bobbio is an unknown quantity at this point
The exact same thing happened to me when I changed the oil on my car about three months ago. I went to Honda to get a new washer and bolt and they gave me one that was longer than what came on the car. So maybe it's a common problem.
Old Oct 3, 2004
so basically all I need to do is go to an auto parts store and get a bolt a size higher? And re thread it?
Old Oct 8, 2004
so now that I have a bigger bolt, 19mm I think, what would I do if this ever happens again? Go to another bigger size, or what?
Old Oct 12, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
I use the QuickDrain. It's so easy to change my oil now. Just hand screw on the end of the drain and watch the oil **** out from the tube. No more screwing around with the drain bolt.
http://www.carcraft.com/techarticles/55998/
Try it, I bought it at PepBoys for $9.99
Old Oct 15, 2004
Ok, I am thinking about trying something here, what do you suggest everyone? I threaded the new oil drain bolt in and changed my oil, but today when we were doing PM's at school I had my car on the lift, and when I looked at my oil pan and drain bolt, there was a bit of oil on the underside of the pan running to the bolt. I wipped it off, but when I looked at it again tonight, there was more there? What can I do to seal this up without having to buy another oil pan? I have a feeling the new bigger bolt that went in, the pan is stripped again?
I am thinking about the quick drain, but I have that bigger bolt it, so do I just need to get a bigger size quick drain bolt?
Old Oct 15, 2004
jameStype's Avatar
jameStype is an unknown quantity at this point
Question
was this your cars first oil change? (brand new ride)? my dealer told me that i would need my first oil change done at the dealership before i could do it on my own. i'm curious if its due to this threading issue??
you guys know anything about this? i have a 2004 ex coupe that still has some miles left before its first oil change.
Old Oct 15, 2004
No this was not my first oil change, it was like my 25-30 oil change. I have 75k on the car.
Old Oct 15, 2004
Oishi's Avatar
Oishi is an unknown quantity at this point
toughie...you can try a hellicoil or a rivnut but i don't think it is meant for liquids...i think they're mainly used for stripped "dry" threads...
Old Oct 15, 2004
hobbes1985's Avatar
hobbes1985 is an unknown quantity at this point
Nah. The dealer is just trying to get money out of you. I changed the oil myself the first time and every time after that. I never had any problems with the threading.
Old Oct 15, 2004
jameStype's Avatar
Thumbs up
thanks for the info hobbes. i'll do my own oil change. just need to buy some washers and i'm set.
emich
Dec 11, 2015 12:20 PM
mrwhos
Aug 11, 2015 02:03 AM
fecrni
Aug 8, 2015 06:15 PM
Q-Bert
Jul 19, 2015 09:09 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
