DIY Hyperblinker
Old Jun 1, 2004
civic2uner's Avatar
DIY Hyperblinker
Who has done this? if you have is it hard and does it really look good?
Old Jun 1, 2004
civicvtec1ps's Avatar
Search and Learn
http://2k1civic.com/forums/showthrea...Y+hyperblinker
Hyperblinkers are seriously annoying and pointless imo.
Old Jun 1, 2004
7thGenerasianCivic's Avatar
I did it. Not hard at all and it does look good. I'm not annoyed just yet...it's been months.
Old Jun 1, 2004
ImPulse's Avatar
clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky...
I like, Click.... Click.... Click....
clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky clicky
gets annoying
Old Jun 1, 2004
civic2uner's Avatar
gets annoying
lol that is annyoing and its just a little taste. lol
Old Jun 1, 2004
civic2uner's Avatar
but things like this i wonder now days... since altezza lights and rice ect. is so pop in the main stream, if you go to a show are you gonna get down voted because it is so mainstream that is what the judges look for?
that sux! i guess ill just be down voted.
Old Jun 1, 2004
civic2uner's Avatar
o well guess it dont matter lol
Old Jun 1, 2004
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
easier to get led turnsignals. they automatically give u hyperblinkers
Old Jun 2, 2004
02civic_rida's Avatar
true!,
but i didnt use our stock flasher to create hyperblinkers, or replace the lights, i have another way and it works greeeeeat, if ur interested let me know
Old Jun 2, 2004
civic2uner's Avatar
what did you do?
Old Jun 3, 2004
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
Originally Posted by civic2uner
what did you do?
Don't know what he did, but you can always take your 7443 combo parking light and signal bulbs which has 4 metal connections and bend 2 of the connections back so you're left with 2. When I did this it resulted in no parking light and only signals at a hyberblinker rate. At least this is what I remember doing before just getting led's, it's been awhile so I don't remember which connections I bent. Just get a test bulb and try it...
Old Jun 3, 2004
FALKEN's Avatar
Civicforums Junkie
ive done this hyperblinker modification for some of the Arizona members when we would get together for a meet...very easy to do (snip, snip)
Old Jun 3, 2004
civic2uner's Avatar
i guess all i wanted to know is, is it worth it? do you like it. is it rice?
Old Jun 3, 2004
acidbaby's Avatar
The Beez Kneez
pointless really!
maybe if you could get only your hazards to blink fast that would be tight.
Old Jun 3, 2004
well the way i did it, you can adjust them.... so u can make it go normal, or lil fast , fast, faster, fast fast, so u could adjust them for the HAZARDS.
Old Jun 3, 2004
CivicHX01's Avatar
Originally Posted by acidbaby
pointless really!
if you do it the way i did... then the hazards will blink fast as well... the same speed as the signals
here is the old thread... but the pics are gone
http://7thgencivic.com/forums/showth...y+hyperblinker
basically what you do is
1. take out the signal relay under the steering wheel (the black box near all the fuses)
2. open the relay up
3. unsolder the "R1" resistor (it has "133" on it to indicate 133k ohms which is the stock value, its also the smallest one)
4. solder some short wires to the ends of where the resistor was connected
5. soldier the resistor to the wires
6. you don't need the plastic cover anymore, it shouldn't fit anymore so just leave it off
7. plug the relay back in, the wires will be hanging depending on how long you cut them...
i put 45k ohm from radio shack (.99 cents for a pack of 5)... this comes out to about 6x fast.... rule of thumb is, the lower the resistance the faster it will blink...
theoretically, if you put a resistor higher than 133k (like maybe 150k ohms), it should blink slower ... but i've never tried so i'm not sure if it'll work...
i plan on adding another 45k in series to slow it down a bit and maybe make it around 2-3x faster than stock...
i did this to my cousin's 03 si as well... but we were short of resistors so i just used a pair of 22k ohms in series that i had laying around in my room (i used them to increase the voltage of my processor for overclocking, but thats off topic lolz...)
so pretty much you can experiment with different value resistors and see how fast or slow you want it...
Ziggy1999
Oct 15, 2015 07:56 PM
General DIY
Sep 25, 2015 08:02 PM
meicalnissyen
Sep 25, 2015 12:12 AM
speedlever
Sep 24, 2015 07:18 PM
henrytn
Aug 11, 2015 10:01 PM
