Wheel setup HELP!!!!!!
Old Mar 16, 2004
straightfaced's Avatar
straightfaced is an unknown quantity at this point
I need some last minute help from you guys and girls
If i get 17 inch rims and 205/40/17 tires will it fit the same way and height as my stock tires with my sportsline spring kit i dont want to take away my lowered effect
If anyone has the same setup please help me out. or anyone with some suggestions.
Thanks.
Old Mar 16, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
due to the tires it will look less drop cause there wont be alot of rubber, so you will see a GAP. try 205/45 that will look alrite.
Old Mar 16, 2004
MadWheel's Avatar
Premium Boosted Member
use this link...
http://www.7thgencivic.com/modules.p...tor&file=index
If the tire is slightly too small, ur results will be a drop (obviously).
You WILL have a minor drop with those tires. And your speedo will be 4% too fast...
Old Mar 16, 2004
what type of setup do you have because the tires i want dont have the size 205/45/17 only 40 series
Old Mar 16, 2004
MadWheel's Avatar
with those tire settings ur speedo will be a lil over 4% too fast.
I have Parada Spec-2s. 215/40/17 (2.89% too fast)
Old Mar 16, 2004
dont the 215's rub
Old Mar 16, 2004
Kloverz's Avatar
you wont rub, but i say its best with the 205
Old Mar 16, 2004
MadWheel's Avatar
i dont have rubbing isssues, and I didn't rub when i had the h&r suspension either... (1.75" drop)
Old Mar 16, 2004
isnt that the same drop as my eibach sportsline kit
Old Mar 16, 2004
i didnt think this would turn out to be such a hard decision
it either 215 45 17 or 205 40 17 with the 40 series my car is going to loose height and with the 45 series it will stay the same. What would you guys do.
Old Mar 16, 2004
Kloverz's Avatar
its all on you i depend if you are going performance,looks or as long as its okay. 205 will be nice, 215 is what you are looking for.
ill go with the 40 series why cause 45 is just to much rubber for me.
Old Mar 16, 2004
thanks bro
What do you think about loosing a bit of the drop do you think that it will effect it that much or am i just tripping for no reason
Old Mar 16, 2004
Kloverz's Avatar
okay now i see what ur trying to say, you wont lose no drop you will sit higher, okay put it this way, i used to run on 205/40/17 its cool but i have a body kit i still scrath with my drop neuspeed sports same as urs ebaich. but now im currently on 225/40/18 man im high up there about a good two inch the drop is still there but my car just sit higher and i have no gap, with the 205 17 i have gap, i hope this help
Old Mar 16, 2004
yeh yeh thats all good bro you helped me make my decision i owe you one thanks.
Old Mar 16, 2004
MadWheel's Avatar
You're sittin up there cuz you put 18s on man, so the same tire size on 18's is theoretically .5" higher off the ground.
A smaller diameter tire will make you sit lower on the ground. A 205/40 series on a 17 is smaller/shorter than a stock EX 185/65.
A 215 is SLIGHTLY thicker and you'll have very minimal drop to the ground. Take into consideration your ride comfort.
Old Mar 17, 2004
yeh I ended up buyin 18's with 215/40 series tires
It ran me about 1900
Old Mar 17, 2004
thanks
Old Mar 17, 2004
MadWheel's Avatar
np
Old Mar 17, 2004
Kloverz's Avatar
So you went with 18inch rims huh 215/40 thats is a good setup i hope you will like the ride, mine is good im not complaining.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
Tedverseti
Apr 23, 2020 01:45 PM
jedi
Aug 3, 2015 04:26 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
Theshwartz35
Jul 17, 2015 11:13 PM
